Case Mod - Complete ⭐ Project: Tweaked Meshify S2
Discussion in 'Project Logs' started by TerHorstCustoms, 31 Jan 2020.
  1. TerHorstCustoms
    TerHorstCustoms Minimodder
    29 Jan 2020
    Thank you for the kind words, I'm flattered :) Its going slow but steady but its all worth it after all the design hours :worried:
    The eagle eye's spotted the GPU's, they make great art to look at :) Bought them all on the used market which my wallet likes :clap:
    There are a total of 10 of them: 3x R9 290's (2 custom painted form a project), 1x GTX690, 1x GTX780, 1x R9 295x2, 1x HD7990, 1x HD7850, 1x HD6990 and 1x HD6970.
    kim likes this.
  2. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    this gets really awesome ... cant say it enough :D
    TerHorstCustoms likes this.
  3. TerHorstCustoms
    29 Jan 2020
    Thank you :) Going slow but steady with the progress.
  4. TerHorstCustoms
    29 Jan 2020
    New small update, the build is getting a ARGB upgrade on the fan side :) A big thank you for that goes out to Noiseblocker for providing this upgrade!
  5. BigShadow
    BigShadow What's a Dremel?
    10 Feb 2020
    Really clean build, congratz
  6. Jangalit
    Jangalit What's a Dremel?
    28 Feb 2020
    absolutely gorgeous
  7. TerHorstCustoms
    29 Jan 2020
    Thank you! Trying to keep it clean when the cables are gonna go in :)
    Thanks :) After loads of design time its now time for the building.
    ifohancroft likes this.
  8. Jangalit
    28 Feb 2020
    yeah the cleanliness of it really adds something to it, keep us updated ;)
    TerHorstCustoms and ifohancroft like this.
  9. TerHorstCustoms
    29 Jan 2020
    I will do that :) Should have time tomorrow to make some covers and modify the top fan bracket a bit. Next big step / milestone for this build would be the distro with build in cable managment, but that will take a while to be made because its build up out of 18 custom parts that need to be milled :worried:
    kim and ifohancroft like this.
  10. Jangalit
    28 Feb 2020
    Yeah it clearly isn’t an easy task, good luck!
  11. Diletta Graziosi
    Diletta Graziosi What's a Dremel?
    27 Feb 2020
    i hope the gpu will not be too hideen behind the fans after you Mount them on the radiator
  12. TerHorstCustoms
    29 Jan 2020
    There will be no fans on that side of the radiator :)
  13. TerHorstCustoms
    29 Jan 2020
    It has taken a while but I had time today to finish the first part of the custom loop :)
    The next update for this build is gonna take a while. This due to some delays on the 18 custom parts for the distro plate with build in cable managment.
    In the meantime there will be a nother small project to do. I also will make a buildlog for that :)
  14. kim
    kim hardware addict
    10 Jan 2016
    :jawdrop: a pure beauty
    ifohancroft and TerHorstCustoms like this.
  15. TerHorstCustoms
    29 Jan 2020
    Thank you :) After all the design hours its starting to get somewhere.
  16. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Hi, yes your mod is simple and efficiency, clean and looking nice to izes !
    Congrats
  17. Hatem
    Hatem What's a Dremel?
    2 May 2020
    I had to create an account just to tell you how sick that setup is... and I must say, that custom distro plate is insane! Looking forward to seeing the real thing :) Fantastic work!
  18. Mojo
    Mojo Multimodder
    18 Nov 2011
    That is seriously cool!
    Kudos on making it so clean!!
  19. TerHorstCustoms
    29 Jan 2020
    Thanks great to hear! Unfortunately it wasn't that simple to get it here but after many design hours it got to a point I realy liked. Its just something you need to accept as part of the buidling fun ;p
    Thank you! It my first time doing a custom loop and using a disto (+ designing one). After many revisions I'm quite happy with the look of it. I can't wait to get it in my own hands :)
    After all the design hours I'm extremly happy how its turning out. Still more to do but it could be one of the most clean builds that I ever have done :)
  20. TempeMod
    TempeMod What's a Dremel?
    1 Apr 2020
    Really clean! Can I ask you what camera are you using?
