Project U.S.S.R. - Water Cooling Oddity
Discussion in 'Project Logs' started by Captain Slug, 8 Apr 2004.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I have been, in a sense, "commissioned" to fabricate this case for a forum member who wants both an extremely unique, but also quiet and outlandish water cooled machine. He came to me with some undeveloped ideas and I used my knack for conceptualizing an idea into a finished plan. Here's what we hashed out over discussion, and several hours of reworking detail features.
    Essentially this is a case made to encourage modding to the extreme. The primary case material will be 0.25" sheets of polycarbonate. The most specfic design feature is the round resevoir dominating the center of the case. Red UV dye will be used to intensify the water-cooling appearance, and 2 6" UV cold cathodes will be placed onto the resevoir's forward support arms. As well as two 12" UV cold cathodes in the bottom sides of the case. Add some red UV reactive molex plugs and fans and this machine has gone completely nuclear.
    Both optical drives are in the top of the case and the owner plans to window both drives. All IDE and power cables will be routed up the left side of the case in one large bundle using Spark Plug Wire Seperators
    [​IMG].
    Since 1/2" Hose clamps are ridiculously expensive, I will be making my own out of 1/2" polycarbonate scraps. They should help keep the tubing orderly and obsessive clean.
    Once my part of the project is completed, all remaining work will be on the shoulders of it's new owner. And trust me, he plans on going beyond the extra mile on this one once he gets his mits on it.
    This should be the first in-progress project log I've ever done and should prove to be alot of fun.
  2. slimjim_jjh
    slimjim_jjh What's a Dremel?
    31 Oct 2003
    I love you :p
    my PC:rock:
  3. Captain Slug
    25 Nov 2001
    Mmmm, you don't see red very often. It's my lighting color of choice. UV comes in a close second.
  4. Hephaistus
    Hephaistus What's a Dremel?
    11 Mar 2004
  5. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    Looks like this may be a good one
  6. Timdog
    Timdog What's a Dremel?
    7 Sep 2003
    I'll be keeping an eye on this mod. I think that red may soon replace blue as the color of choice for case modding.
  7. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Welcome back to the Bit cap! aint seen you around lately
    Looking good :thumb:
  8. pranks7er
    pranks7er mange tout
    25 Dec 2002
    thats gonna be kool if all works out, like the idea, have 2 watch and see how its done now
  9. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
  10. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    could you size that pic. down a lil, its a tad big.
  11. Temo Vryce
    Temo Vryce What's a Dremel?
    19 Mar 2004
    Dang Captain it looks like you are going to make on lucky member very very happy. I only wish it was me. :D
  12. Captain Slug
    25 Nov 2001
    hehe, if anyone else wants on made it would be practical to have me do it at the same time as this one...
    PM me if interested.
  13. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Ya know, if you have the Inlet towards the top-side of the ball coming in at an angle, and the outlet on the very bottom - you could end up with a cool-ass tornado effect in the res. :D Of course, might cause some bubbles...
    Can't wait to see how this all turns out!! :thumb:
  14. Captain Slug
    25 Nov 2001
    It's setup that way, the inlet is near the top pointing in the same direction as the outlet on the bottom so it should create a nice whirlpool no matter what level you fill the res to. It would also be pretty fin to put a spiral patterned ball into the middle of the res to se it spin around...
  15. naelq
    naelq What's a Dremel?
    14 Oct 2003
    WOW, a great project! (or at least should be! :D)
    let's see, how well/bad can you express the U.S.S.R! :p
    GOOD LUCK! :thumb:
  16. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Niiiice. I am going to keep an eye on this one. :dremel: [ Edit: ] Oh, and speaking of representing the U.S.S.R., that spherical rez reminds me a bit of a plutonium core that I saw once in a movie. Supposed to be ex-Soviet, of course.
  17. Twunka
    Twunka What's a Dremel?
    12 Feb 2004
    just where does the water go if the res leaks or a res barb leaks or something
    straight to the mobo lol
    but all in all i likeies alot
  18. Captain Slug
    25 Nov 2001
    At pressure it really wouldn't matter where the motherboard was since the leak would spray. And if you don't leak test your system, you're setting yourself up for a nearly suicidal experience.
    Either way I'm recommending that my client that he consider using Fluid XP+ which is a non-coductive water-cooling liquid.
  19. Twunka
    12 Feb 2004
    pure genius there now all i have to do is water cool my system lol i'm a noob wen it comes to water colling
    and spelling
