Project Uber Comp Upgrade (Updated 02/03/05)
Discussion in 'Project Logs' started by Robster, 31 Jan 2005.
  1. Robster
    Robster What's a Dremel?
    11 Dec 2003
    Well been a while since i posted anything here been one of those crazy years lots going on but oh well thats life.
    But i am back doing some mod stuff i have a couple projects that will be starting up next month but till then thought i would post this upgrade to and existing comp.
    Here are the specs on the system as it is now
    The system specs are as follows
    Dual 3.2 gig Intel Zeon Processors
    Intel Workstation Motherboard
    4 gig of Reg DDR Ram
    36 gig SCSI Drive for the operating system
    120 gig SATA Drive for storage
    Plextor SCSI Burner
    Lian LI PC 70 case (Black)
    Soundblaster Audigy 2ZS platinum Sound Card
    Saphire X800XT Platinum Video Card
    All this is WaterCooled
    Water cooling parts
    Swiftech waterblocks for both CPU.s
    Swiftech MCW20-R Chipset Waterblock
    Swiftech MCW50 Videocard waterblock
    Typhoon Single Bay Res
    Eheim 1250 Pump (317GPH)
    HWLabs Black Ice Micro 2 Radiator
    The idea behind this is to upgrade the existing water cooling system to a new radiator as well as some electronics to monitor the whole system
    The new parts that will be going into this will be from Aquacomputer out of Germany here is a link to there site it is mostly in German AquaComputer
    I have been watching the forums for a while and see lots of people using these parts so figured i would give them a try see if they are worth it.
    I got these parts from SNTMods out of California they seem to be the only supplier in North America here is a link to there site SNT Mods
    Well now on to the pics i don't have any of the original build but will post some of the way the comp is now once i get some.
    So now on to the parts
  2. Robster
    11 Dec 2003
    Parts
    Well here are the parts after much time and waiting finally got them here
    UPS was not very nice to the box
    Well lets see what we have in the box lots of little boxs with lots of cool stuff
    Now lets get to the fun stuff thee actual parts
    well lets take a closer look at the peices going into this
    The display so we can make sure the system is doing what it is supposed to
    the harddrive cooler so we can eliminate a few fans on the system
    The new pump with the electronic controler
    The new flow meter for the system
    And last but not least the new Radiator
    I also got the water temp monitor but forgot to take a pic of it oh well that will come later
    Here is all the extra wires and connectors for this system
    All the extra parts for the display
    Well that is it for now will be posting some more here right away
    So hope you enjoy
    and Happy modding
  3. Muon
    Muon What's a Dremel?
    1 Dec 2004
    ouu, good start, aqua-computer rocks, wheres the case ^^
  4. Robster
    11 Dec 2003
    Got looking through some old pics here and found a pic of the comp back when it was first done
    I will post some better pics of the comp just don't have it here right now but bringing it in this week to start on it.
  5. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    wow this looks nice. I like the new specs. *sigh I want them. (5200 aint cutting anything anymore - dont laugh)
    [Offtopic] Nice table! also it seems like a nice looking room too! [/Offtopic]
  6. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    4 gig of Reg DDR Ram OMFG!! are you serious?? that amount is like 2 years ahead from now!
    the hardware is tight! and the watercooling looks like a million bucks!
    I am amazed that just one 120mm rad can provide sufficient to cool all that crazy hardware! can you post the temps you got? and what fan and on what voltage it is running?
  7. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    It's a Dual Xeon, the more the better :D Only thing that worries me are your temperatures, 2 x Xeons, a Chipset and an X800XT PE on a single 120MM radiator as Acid has mentioned :eeek:
  8. Firehed
    15 Feb 2004
    The water temp in a system usually doesn't rise more than 5 degrees from the rad out to the rad in... you have to remember it's completely different than air cooling in that way.
    Like the parts... let's see some modding! Looks promising!
  9. Xarig
    Xarig What's a Dremel?
    26 Feb 2003
    Robster - I'll be keeping a close eye on you :eeek: looks like you're using many similar parts as myself - the past result suggests that your skills :dremel: will do justice to the lovely kit :D
    Keep up the great work :rock: , I'm subscribed
  10. Nexxo
    23 Oct 2001
    True, but it is not the water temperature that is important. It is the temperature difference between the water and the blocks. The less difference, the less heat transfer. Also the rad will have an upper limit to how much heat it can displace. I predict those Xeons will peak at about 50C at load.
  11. Robster
    11 Dec 2003
    Yah i have been thinking about that myself the system is running on a single rad with dual 80mm fans so thinkiing i might keep this rad in the loop so will have 2 rads instead of the one
  12. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    looks really promising. gonne have an eye on this one
    -supscriped-
  13. keir
    keir S p i t F i r e
    5 Oct 2003
    fork man. gonna be a sweet system when ur done :thumb:
  14. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    think so 2
  15. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Oh my god! The HW! Nice man.
  16. Robster
    11 Dec 2003
    Yah i will post the results once i get the system back together just tore it down tonight so will see.
  17. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Wow...
    Erm, wow...
    Looking nice, that's just some serious stuff under the hood :hehe:.
    Looks nice though, I like how you have a lot of schtuff interfacing through the external drive bays ~ makes everything more fun :idea:
  18. Gabe
    Gabe What's a Dremel?
    19 Jan 2005
    dang that sure looks sweet, make the neighborhood jealous why don't you.
  19. Robster
    11 Dec 2003
    Time to start work
    Well started on the comp the other day
    Got all the old stuff out so we can start with a clean slate
    The computer next to it has a full water cooling system with pelties on both the CPU and the Video card That will be later.
    Here we go time to drain the system and see what we have.
    Here we are all cleaned up all the parts gone and time to clean up a few things and start putting all the new stuff in.
    Going to keep the swiftech blocks with this so no need to remove these.
    Well first thing we need to look at is the pump as i am going to keep it in the same place as the old pump will need to fix the old drive cage
    Because of the EMShield on the new pump i can't install it the old way so had to cut the drive cage back
    Here is the pump and drive cage installed to see how it will work still have some more work to do on this but give you an idea how it will turn out.
    Here is a shot of how the components will look in the case not to sure but going to be doing something with this as well as it still does not have a total clean look that i would like.
    Well that is it for now not much done but will have some better pics as well as somemore work on this.
  20. Robster
    11 Dec 2003
    More cutting
    Well got around to working on this a little more had to do a litte more dremel work nothing major here just needed to make a little room for the second rad because the bottom of the cage for the powersupply was limiting the Raditor and wouldn't let it go high enough for it to line up and mount.
    But first lets protect this a little because we are not going to actually pull the motherboard
    Here is what we have after a bit of cutting.
    Lets see how the rad fits.
    Well nowhat that is out of the way lets fix these fans so that the air can actually flow a litte better.
    Now the last piece to cut We need to make room for the top radiator as this one will just fit in the top of this case.
    We this was not the best cut i have done in a while but not really alot of room here for a dremel and a cutting wheel even with the extension but oh well no one will see it
    Lets see if that will help the radiator fit any better
    Still a tight fit but thats ok it is in there now
    Short but to the point now to make the new backing plate to mount the rad and such.
