Project:Uchikoma (ebot take 2)
Discussion in 'Project Logs' started by AJB2K3, 18 Jun 2007.
  1. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Well when i brought my ebot
    i had plans to do a Tachikoma theme to it but life got in the way and set stoped that however time is now back on my side and i have been able to restart the project.
    Ill make this clear from the start, it will be nothing like this oneTachikoma mod
    Mine will just be a suttle mod to make it look different.
    I have chosen to do the Uchikoma/fuchikoma because it (IMHO) more closely matches the Ebot.
    Striped of most of the pannels (opps i broke the screw hole in the slimline drive tray (and hopes thats all i broke :worried: )
    Front and left pannels
    top and right pannel
    Ive striped of all the natty little trim pieces to re use later
    and now for the progress missing from the old log (BTW mods feal free to delete old log)
    The pannels are now got 2 layers of plastic prime even though i took the picture before i applied the secound coat :duh:
    Whats next? well i hpe to get the priming done then i can work on the detail before applying the colour to the pannels.
  2. AJB2K3
    12 Dec 2005
    Yah update
    Ok so despite the rain i got some work done today.
    First the roll bar (if you can call it that)
    I then got some paint and tryed some parts out
    OK???? :confused: :confused: thats supposed to be green? :confused: :confused:
    As it stand the hardware consists of
    2 GIG processor,
    250 GIG hd,
    1.25 GIG ram (yah i havent got the second stick yet)
    ATI X1900 graphics Yes it is running realible on Ubuntu, more better then my 6600 Gts is :jawdrop:
    Medion tv tuner (must upgrade to a digital and dump my tv).
  3. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    lol, green to the colorblind.
    Nice project.
  4. AJB2K3
    12 Dec 2005
    Thanks
    NOOOOOOOOOOOOOOOOOOOOOOO!!
    [​IMG][​IMG][​IMG]
    :wallbash: :wallbash:
    WTF happened here
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Well sanded it back and resprayed it. lets hope it looks better tonight !
  5. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    looks like the paint reacted with something that was already on the surface ...
  6. AJB2K3
    12 Dec 2005
    Second layer now trying to fix that but its getting there
    The colour of the panels is nearly finished and i can soon start on clear coat how ever i still need to dissemble the back panel ready for painting.
  7. FR34K
    FR34K What's a Dremel?
    1 Feb 2007
    I hate when that happens.
    good luck with the rest of the painting. nice looking case :thumb:
  8. AJB2K3
    12 Dec 2005
    Little bit of update.
    Side panels and top have been clear coated but the top need to be sanded and painted (bluming rain)
    Roll bar is now painted
    Front panel with finale colour coat but with roll bar removerd ho ever its since be re-attached an clear coated.
    But here's a preview of my next project
    Currently working on a card template for new project.
