Case Mod - In Progress Project : Urban Camo on CoolerMaster Stacker
Discussion in 'Project Logs' started by M600, 20 Jun 2008.
  1. M600
    M600 What's a Dremel?
    20 Jun 2008
    First of all, i wish to apologize for my bad english :) That's not my main language
    Materials needed :
    [*] Scotch Brite
    [*] Sandpaper at 360
    [*] Sandpaper at 500
    [*] Sandpaper at 1200
    [*] Primer
    [*] Sanding Machine
    [*] Compressor 200L at 6.5bars
    [*] Booth Weinmann
    [*] SATAjet gun (for the primer)
    [*] Iwata gun (for the basecoat)
    [*] Devilbiss gun (for the clearcoat)
    Already done :
    [*] Dismount the Stacker
    [*] Sanding all the surface
    [*] Put some primer on all the structure
    [*] Sanding the primer
    [*] Painting the structures in Black
    [*] Making the mask for the first coat
    [*] Put the first coat (Dark grey)
    [*] Drying
    [*] Making the mask for the second coat
    [*] Put the second coat (Medium grey)
    [*] Drying
    [*] Making the mask for the third coat
    [*] Put the third coat (Medium Brown)
    [*] Drying
    [*] Making the mask for the fourth coat
    [*] Put the fourth coat (Light grey)
    [*] Drying
    [*] Sanding the little 'défault' / 'mistake' (don't know the right word)
    [*] Clearcoating
    [*] Drying
    [*] Remount the Stacker
    [*] Remount the rig
    [*] Remount the watercooling
    ToDo :
    [*] Be proud of my work :D
    Rig :
    [*] Asus Maximus Formula
    [*] Intel Core 2 Quad 6600
    [*] 4 x 1Go Crucial Ballistix Tracer PC8500
    [*] GeForce 8800 GTX 768Mo
    [*] GeForce 8800 GTS 320mo
    [*] Carte Netgear WN311T
    [*] Asus Graveur DVD
    [*] 640 Go Western Digital
    [*] 250 Go Western Digital
    [*] 500 Go Samsung
    [*] *Laing pump + Top Plexi XSPC
    [*] *Tank 5 1/4 XSPC
    [*] *Black Ice Stealth 240mm
    [*] *NexXxos XP Silver
    Dismount the Stacker...
    Preparing the panels
    Hiding the structures and mounting the panels
    Booth on, waiting for basecoat...
    Coat 1 done.
    Coat 2 done.
    Coat 3 done.
    Pause :lol:
    Unmasking :eeek:
    Coat 4 done.
    Coat 5 done.
    And now...
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Wish you like it ;)
    Best regards.
  2. Hardpetas
    Hardpetas Spain Modder
    10 Mar 2008
    Good Paint Job!!!!!!!!!!!!!!
    Bye
  3. charlesbeams
    charlesbeams TRANCEFORMer
    10 Jul 2007
    haha i like how it looks :)
  4. ComputerKing
    8 Sep 2006
    WOW dam, you paint like pros. ;) also you have the place and tools :rock:
  5. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    WOW, thats just... wow :p
  6. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    wow very nice paint job :rock:
    and awsome HDD wireing:thumb:
  7. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    both the above say it well. Absolutely amazing! well done :)
  8. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    :thumbs: Very nice inside! The outside looks great, too!
  9. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    wish i had a paint booth to use!
    why you running a 8800GTS and a 8800GTX? i am guessing multiple monitors for a serious flight simulator?
  10. M600
    20 Jun 2008
    Thanks for all your feedback :)
    Yes, it's a multiple monitor setup... Not to play, not to use for Flight Simulator, not to work... Just because i'm a lazy ass bored to do "Alt+Tab" to switch between multiple windows :D
  11. Colossous
    Colossous Minimodder
    28 May 2007
    That camo finish really suits the Stacker - liking your style :thumb:
  12. SupReme
    SupReme Message is over there ->
    20 Jun 2008
    Well done paintjob! I agree with Colossous, it really suits the Stacker!
  13. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    man this looks sick as! man that's a seriously nice paint job! are you like a professional airbrusher or something? and the inside :jawdrop: its like super clean!
  14. Nerblix
    Nerblix What's a Dremel?
    18 Jun 2008
    super sweet paint job :D very clean WM too :lol:
  15. emir_
    emir_ What's a Dremel?
    3 Aug 2007
    Very nice job ;). Can you post a macro picture of the surface?
  16. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Wow. That's alot of taping/masking work. Well worth it based on the results though :thumb:
  17. Coldon
    Coldon What's a Dremel?
    14 Oct 2006
    absolutely gorgeous! you know what your next project should be: digital camo :p
  18. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Probably one of the nicest camouflage paint jobs i've seen tbh and as already said it really suits the case :cooldude:
  19. Farmboy UK
    Farmboy UK Hungry for knowledge
    19 Apr 2008
    Wow such a good paintjob, you pulled it off perfectly. Inside looks great too, nice HDD wiring
  20. skullen
    skullen Minimodder
    31 Oct 2007
    Very nice :thumb:
