Scratch Build – In Progress [Project] Urban Camouflage [Updated 28/5 =)]
Discussion in 'Project Logs' started by Overminde, 3 Apr 2012.
  1. Overminde
    Overminde What's a Dremel?
    15 Sep 2011
    After a project that was only posted in Portuguese forums we decided to try and extend boundaries so here we are to try our luck on Bit Tech.
    Like I said before our first project was well accepted in the Portuguese Gaming community so we will be trying to exceed the expectations on our next project that goes by the name of “Urban Camouflage”.
    Our project has the intention to restore an old server case, that even bein a bit old has some excellent finishing touches. Just like our past project we will be using a full water cooling system on a case that has no kind of support for it.
    All the case water blocks will be personalized, the paint job will be done in Urban Camouflage so will the radiators and the major components inside the Case. The side panel will have an acrylic window to show the motherboard.
    Has a newbie in Bit Tech I hope you guys can throw some opinions and critics that can make this project grow =)
    News will come soon so stay tuned.
    Our Sponsors for this project are:
    NOX -
    Corsair -
    .: SYSTEM :.
    • [Case] – Old server case
    • [CPU] - AMD Phenom x6 1055T
    • [Motherboard] - Asus SABERTOOTH 990FX
    • [Memory] - GSKILL PC3-14900 8GB Sniper CL9
    • [SSD] - 2x Corsair Force GT 120gb :thumb:
    • [Graphic Card] - XFX ATI Radeon HD 6950 2GB
    • [PSU] - NOX Hummer M 750W :thumb:
    • [Optical Drive] - N/A
    • [Mouse] - N/A
    • [Keyboard] - N/A
    • [Phones] - N/A
    • [OS] - Windows x64 7 Pro
    .: COOLING:.
    • [CPU] - Personalized Block By ModGamer
    • [Motherboard] - Personalized Block By ModGamer
    • [Graphic card] – Personalized Block By ModGamer
    • [Radiator] - N/A
    • [Pump] - N/A
    • [Reservoir] Personalized aluminum reservoir By ModGamer
    Some Pictures of the Case still in one piece and it all disassembled. Hope you like them and sorry if you don't understand something i say since I'm not English
  2. jhanlon303
    7 Sep 2006
    Nice case and good start.
    I watch.
    john
  3. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    sabertooth = subbed
    mod on:dremel:
  4. Overminde
    15 Sep 2011
    And some hardware starts to arrive ;)
    Fans NOX NX 120mm
    Heheheh seams that there is something more in the box and not just fans :D
    PSU NOX Hummer 750w Modular ZOMG :D hehehhe
    Hope you like them and let me just thank NOX Xtreme for their help specially Rogelio, hope you like this.
  5. Rosas
    Rosas What's a Dremel?
    17 Feb 2012
    Like It :)
  6. Overminde
    15 Sep 2011
    Nox fans will have a custom paint job with the same color as the Case itself.
  7. Overminde
    15 Sep 2011
    One more shipment , small in size Big on Quality :D
    Big thanks to Corsair specially Gareth.
  8. Rosas
    17 Feb 2012
  9. Overminde
    15 Sep 2011
    The catia render of the case ;)
    This is the case in its original state we re going to start the design now to implement the modifications
    Hope you like it
  10. dirky90
    dirky90 Minimodder
    19 Mar 2012
    raid 0 i presume??
  11. Overminde
    15 Sep 2011
    Ho yeah :D already tested them, they are soooo FAST :D :rock: :clap:
  12. dirky90
    dirky90 Minimodder
    19 Mar 2012
    I bet, I have a raid 0 vertex 2 setup at the moment. not sure if i should upgrade but thats by the by.
    keep up the good work!!
  13. Overminde
    15 Sep 2011
    Sorry for the late reply ;) well i dont know whats your setup cause to really take all of this babies you need a good sata III controller i can get almost 1gb/s of speed from them :D im really happy with this setup and my sata controller isnt the best for them. See a pic from Atto benchmark i did bellow:
  14. Overminde
    15 Sep 2011
    Some more of the drawings
    This is the "mid plate" that will divide the water cooling system radiators from the botherboard
    It will have a preventive draining system so any drain will not fall on top of the motherboard or in the graphic card.
    Chapa já aplicada na caixa.
  15. Overminde
    15 Sep 2011
    We are proud to announce PikaPedra as our sponsor, PikaPedra is an airbrushing store that also does painting jobs follows a picture of the paint job he will be doing on our case, Thank you very much Pedro from http://www.PikaPedra.com/
    PaintJob:
    PiKaPedra:
  16. failariel
    failariel What's a Dremel?
    7 Feb 2012
    nice!!! good work
  17. Overminde
    15 Sep 2011
    Thks mate :)
  18. Overminde
    15 Sep 2011
    Radiator fit tests:
    2x Black Ice 360mm in sandwich, with 6 fans NOX NX 120.
    Its time to disassemble and clean it all up=)
  19. Cown
    Cown Minimodder
    25 Feb 2012
    Looking good, love the fans :)
  20. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    yeah old server cases are cool :)
