PROJECT: V 1.0 The first attempt
Discussion in 'Project Logs' started by 25188201, 6 Apr 2005.
  1. 25188201
    25188201 What's a Dremel?
    5 Apr 2005
    OK so i'm completly new to this whole modding thing, i swapped my laptop for a mates old modded system (thanks RobbieGSM :thumb: ) and now i'm hooked :D
    The original case
    All i've done so far is swap all the internals from one case to another (a Cooler master 201b sx2)but thats not enough, so heres a log of my first ever atempt to mod a system :eeek:
    Forgive me if the descriptions are a bit dodgy i'm still working it all out
    ok so the system is:
    AMD athlon 1700
    ATi 9700pro graphics card
    2x cd/dvd/rw one cooler master one unknown
    40Gb & 30Gb HDD's
    and some blue neons stuck in there for good luck
    The New cooler master case
    Fist of all i plan to tidy up the insides as it's a right old mess and have a new colour scheme by replasindg the fans with some New Xxion UV reactive Fans and some green Dual Cold Cathode tubes, next up are some new IDE cables to match and a Super Flower Master 4 Fan Controller and Temp Sensor to keep it all under control.
    Once thats all sorted it's time to upgrade to a AMD 64 processor and a bigger faster HDD, i dont really use the system for much gaming so i'm happy with the graphics card for now. but after looking around the internet for awhile theres so may possibilitie on what i could do i dont even have a full plan as i'm learning new things all the time, so i'll just have to keep you all updated.
    Any ideas or advive would be apriciated.
  2. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Welcome to the board Tom. :thumb:
    Can't say much, it looks great how it is now!
    if you get a 64bit cpu you will need a new mobo and maybe ram.
  3. 25188201
    5 Apr 2005
    Ok so i've decided to upgrade the processor and mother board fist so there'll be a AMD64 3200 processor and a Super Flower Master 4 Fan Controller coming tomorrow.
    I have also ordered all the new fans and cathode kit, they should be here next week, just need to find some decent fan covers ( all the ones i've found so far have been tacky or just boring).
    Ii'll get some pics up when it's all in there,
  4. 25188201
    5 Apr 2005
  5. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    ok get this if you can
    athlon64 "venice" 3000 or 3200 should do the trick
    mobo: DFI ultra-d
    Video: can keep that if you want or get 6600gt or ati x800xl
    hdd sata 160 or 200gb are quite affordable right now just a couple of bucks more.
    perhaps a better psu, i think all depends on your budget.
    im looking forward your first attemp i'll post mine soon : :dremel: :rock:
    Good luck and may the force be with you
  6. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    messeg your cable .. do something on the front maybe another controlpaneel not that thing you have!! :hehe:
