Case Mod - In Progress Project V-series 600 ~ complete ~ last/final update
Discussion in 'Project Logs' started by tjay@TJ, 24 Mar 2009.
grill top or arcylic top look nicer
Poll closed 7 Apr 2009.
  1. acryan grill
    9 vote(s)
    60.0%
  2. arcylic top
    6 vote(s)
    40.0%
  1. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    i just started in modding recently, my 1st build didnt really turn out good.
    now i planning to start my 2nd mod in my free time.
    i bought my 1st lian li 3 month ago. plan to get a blact v350 but not available. in the end i bought a lian li v600.
    bored with the looks of in after 3 month, i started my mod on it.
    mark out the case
    bring out my Favourite tool i just bought.
    cut out.
    in the process of cutting. i used up 15 of my 25 pices cutting disk. :jawdrop:
    need to get more.
    i have no budget on water cooling system.
    only led fan will be in place on the grill to provide the effect.:rolleyes:
  2. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    fast forward,
    more work are being done.
    thanks for watching
  3. Jeddy
    Jeddy What's a Dremel?
    12 May 2008
    This is a mod I will watch with interest
    looks great so far.
  4. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    thanks.
    will post more update soon. currently the top panel and the side panel are being redo.
    picture soon
  5. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    How about a bit of detail on the plexi between the case top and the grill?
    What grill did you use?
  6. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    the grill i use is acryan rad grillz. not a good one...
    hard to find this type of grill in our country. that grill i buy from neighbour country.
    btw i live in asia.
    @Top Nurse.
    the plexi mention
  7. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    some picture i promist.
    redo the top part.
    smother now.
    side.
    thanks
  8. HaSLeS
    HaSLeS The Observer
    12 Jul 2008
    I believe that u have used disks like this http://ecx.images-amazon.com/images/I/517B9XCGF6L._SL500_AA280_.jpg that are simply for non-metal cutting purpose. You should use disks like this http://www.silentmods.com/templates/images/texts/3_7186_pc_window_dremel.jpg and i think everything will be ok ;)
    P.S. Sorry i know my english is crap but i hope that you understood what u was trying to say.
  9. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    yup, the disks come as stock cut of disk. there are 2 type of cut off disk comes with this rtx. the other stock which is so useless break every time i make scratch on the aluminium.
    i think the one u shown http://ecx.images-amazon.com/images/...500_AA280_.jpg is the thin one which only managed to make scratch.
  10. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    picture time.
    i decide to change the design of the window again
  11. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    V600 is a great case
    watchin' your progress ;)
  12. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    yup. it just like a baby v series (v1000/v1200/v2000)
  13. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    picture time.
  14. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    suggestion ?
    psu mounting.
    what do you think
  15. ednismod
    ednismod Minimodder
    15 Oct 2007
    Unless you have a good cable management plan with that location of the PSU, I think it's fine. Nice mod by the way.
  16. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    thanks
    well. the psu is placed there so that big tower coller can be fitted (the only problem faced by this v600 casing).
    cable management would be much problem as all the cable are routed behind.
  17. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Won't the PSU blow hot air into the case?
    Sorry if I missed anything, it's 3am. :eyebrow:
  18. Mokey Mokey
    Mokey Mokey What's a Dremel?
    9 Mar 2009
    The PSU plug would also be on the inside of the case, an eye sore and annoying to unplug.
  19. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    yup, but the psu's hot air wouldnt be as irritating as the limited amount of processor cooling. by mounting this way we can show off the processor cooling.
    similiar mod in our country.
    this guy work are way better than mine. :sigh:
  20. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    opinion needed.
    i should keep the grill on top or i should change to clear arcylic top with 2 x 80/92mm fan?
