Project Vort3x
Discussion in 'Project Logs' started by TheMunky, 19 May 2005.
  1. TheMunky
    TheMunky What's a Dremel?
    19 May 2005
    Hey guys, this is my 1st post here, as well as my 1st dedicated mod. The basis for this modding project is integrating a pretty big squirrel cage fan into a case. Here are some pics of it (wip). Tell me what you think (+ or -). Ty :rock:
    Here's the case to be modded:
    Hacking it to make space for the fan:
    Video card w/ CPU hsf:
    Front of the case:
    PSU:
    What I want the front to look like:
    Painted:
    Case w/ fan primed (sorry, couldn't find the bondo pics)
    Case w/ fan installed painted blue:
    Close-up: [​IMG]
    Fan under a black light: [​IMG]
    more to come....
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Very nice work on the paint, good colour too.
  3. TheMunky
    19 May 2005
    ty ;P
  4. jerb111
    jerb111 What's a Dremel?
    25 Oct 2004
    Hello fellow CT'er!
    nice work so far, looks slick one question however,
    is that anodizing spray you used on the PSU? if so where did you get it, it looks great! :hip:
  5. advance
    advance What's a Dremel?
    18 Apr 2005
    I gotta say my favorite part is the PSU, great job all around!
  6. TheMunky
    19 May 2005
    Thanks guys. The spray paint is metallic blue, purchased @ a local hardware store.
  7. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    I really like the paint, but have you tested the fan yet? Squirell Cage fans can be rather loud...
  8. TheMunky
    19 May 2005
    Yep, its surprisingly quiet and pushes a ton of air :)
  9. streetknight
    streetknight What's a Dremel?
    23 Sep 2004
    nice work. what vid card is that?
  10. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    That fan is setup incorrectly. Cross-flow fans exhaust 90 degrees opposite the intake. In order for that to work you would need to rotate it (from above) 90 degrees counter-clockwise. Then make a 90-degree reversal duct to channel the air in the originally intended direction
  11. TheMunky
    19 May 2005
    Well the fan is pushing air to the left (over the components).
  12. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    Nice, any specs?
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    interesting.
    do you have any way to measure the noise volume of the fan?
    or can you compare it to something else?
  14. BrokeEnthusiast
    28 Mar 2005
    The fans probally have specs online where he bought them
  15. Captain Slug
    25 Nov 2001
    Yeah... but that's not my point. My point is this:
    Once you put the side panel on the fan will just be circulating the same air that's already in the case. You need to duct the inlet of the fan in some way so that it can draw in fresh air from outside of the case. Don't modify the actual casing of the fan in anyway, or it will just become a noisemaker. As the fan is setup now the inlet is highly restricted by the drive cage and isn't outputting anywhere near its normal level of airflow.
  16. Captain Slug
    25 Nov 2001
    If you want the fan to intake from the front at its best possible performance level you will have to duct the inlet like so.
    1. Cut the drive cage to expose the whole inlet
    2. Make a duct like this out of whatever kind of material you would prefer.
    3. cut excess from front of case.
    Or you could make an intake on either side of the case. If you want the intake on the motherboard side just flip your fan upside-down so the inlet is facing the other way.
  17. BrokeEnthusiast
    28 Mar 2005
    What did you do to make that arrow thing? thats really cool
  18. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    Har thats what I was wondering. "nice cas... ohhh photo editing!" .... but the case does look nice!
  19. Rufus-Seal
    Rufus-Seal Guest
    I don't like the case, i think it's ugly..:( But there is much modding to do, so i will see if the case is completed, if i am gonna change my opinion.
  20. Captain Slug
    25 Nov 2001
    The same outdated program I used to recolour linework. Paint Shop Pro 5
