Project Vortex
Discussion in 'Project Logs' started by :: kna ::, 11 Jan 2003.
  1. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Ok, well I figured I may as well get started on walking through Project Vortex. It's going to be a long slog because of the amount of time have to work on it, however if I get it in then I'll be inclined to finish it :)
    Project Vortex was born the day I discovered that with an Eheim pump and old CD spindle, you could make a persistent vortex which looked the mutts nuts. It then occured to me how awesome this would look inside a case.
    Here's a little prototype I knocked up.
    As you can see, the vortex effect is quite visually impressive. You need to have the water coming in at an angle to create the turbulence which will start the vortex off.
    One problem it suffered from was the fact that it would eventually work it's way into the pump and draw air into the impeller. As we all know, air in your watercooling rig is not good, so moving a piece of tube into the res meant that the vortex would stop at the tube and stay away from the pump.
    A natural progression from that is to move the pump further away so that the vortex is free to go all the way down to the bottom of the res.
    As we need to not only house the res somewhere, but we want it to be big and impressive in order to look good, I'm going to be using a Lian Li PC-71 for this project. which has enough space in there to house it all.
    That's the starters, More later on..
  2. relix
    relix Minimodder
    14 Nov 2001
    wow! Nice found! :eeek: :eeek:
    Let's just hope nothing will go wrong with those "ghetto"-like components ;)
    Will you put some LED's inside the water? LED's! LED's! LED's! heheh :).
  3. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Man, that looks really really cool! You should get some UV water dye or something. Nice job, puny human.
    [edit] OOO!! UV LEDS AND UV WATER DYE!!!!! GO ON!
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    This ones gonna go down in moding history if it works well... :D
    just happened to discover that? Jeeez man!
  5. ouija
    10 Nov 2002
    Yea, he was actually trying to build a torture device
  6. Madyeti
    Madyeti Supermodder & sig shrinking victim
    1 Dec 2002
    Lol @ ouija
    Sweet idea. Can't wait to see this in a case! It's such a neat looking thing. ~Davy
  7. :: kna ::
    15 Mar 2001
    Well, ok.. I had the idea and then got the spindle, which happened to fit perfectly inside the pump.
    I was actually thinking of just making a vortex to have 'sat around' then figured it was a bit of a waste :)
  8. olv
    olv he's so bright
    23 Sep 2002
    :jawdrop: looks wicked. I'll be really interested to se how this turns out. Nice idea, truly original
  9. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    4 words
    garden force water feature:clap: :clap: :clap:
    sorry could not resist
    its gonan look cool when its finished
    bling bling baby
    :hehe:
  10. :: kna ::
    15 Mar 2001
    Ok, part two. This is going to be a little disjointed as I'll just do bits as I get to them.
    What I want to do first is set it up working as best I can with the old Swiftech kit I have, then get a proper 1/2" system in.
    First things first. A quick trek to Thorite to pick up some brass barbs. I need three (at the mo), two for the Eheim and one for the res output. I will probably need a fourth when I decide how the return feed is going to come back to the res.
    One of the barbs is mounted in the base of the CD Spindle. There's some Teflon (PTFE) tape around it as I tried that first, however it didn't really work and a good squirt of Silicon sealant made sure it was watertight.
    Moving onto mounting. I decided that it's going to go in the drive bays. I'll worry about a CD-ROM later on, for now the most important thing is being able to see the vortex. I've made a perspex base to allow the res to stand free in the case. Perspex obviously so that I can do something with lighting :)
    [​IMG] [​IMG]
    We're going to need a hole in it, and a fan grille had the perfect size, so might as well use it :)
    That's all for now. Probably three more pics tonight.. then more modding.
  11. iSteve
    iSteve What's a Dremel?
    3 Jan 2002
    Pretty decent :) Is it actually possible to make a vortex go a bit even thru tubes ? THAT would look definitely wicked :)
  12. ouija
    10 Nov 2002
    Maybe possible
    Definately difficult
    Definately not good for the cooling aspet of things
  13. :: kna ::
    15 Mar 2001
    Right, with a hole drilled in the plate, I can now test the res in the PC-71.
    I'm going to do a dummy run of everything and get the system working perfectly before I start doing any fatal mods. No point cutting big holes and then realise you don't want something somewhere :)
    I need to mount some feet or something on the bottom of the res, so that it will sit comfortably on the plate, but for now, you'll see the idea.
    [​IMG] [​IMG]
    Obviously I can't get a CD-ROM in there, however that little gap below will more than happily house a baybus and LCD :)
    Right, back to work.
  14. txi
    txi What's a Dremel?
    26 Apr 2002
    wicked!
    <waits further updates :D
  15. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    Hey ::Kna::, looking at those piccies, would there be enough room to stick in a Laptop CD drive? you could even wedge one down the side cos the spindle on the drive will hold the CD in place... Looking sweet man! You need to mount a "wall" of CC's behind the res and get Macro to knock you together a circuit to flash them in a row so it looks like the light is "rotating" with the water :D
  16. tk421
    tk421 Idiot.
    15 Jan 2002
    i was gonna suggest a notebook combo drive too ... looking at my pc-71 and your pix ... there might just be room to squeeze one in ...
  17. mashie
    mashie The one and only
    15 Mar 2002
    Looks promising, however I would move that plexi cylinder forward so it will have 1/3 of it outside the beezel. Then when you add some bright red and yellow LEDs underneath it you can also enjoy it from the side :)
  18. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Looks sweet so far mate :D good old Tommy Wrights to the rescue ;)
  19. ouija
    10 Nov 2002
    Mashie thats a good idea. Instead of viewing it thought a window, you mean the cylinder is basically a curved window? That would be sweet
  20. mashie
    15 Mar 2002
    Yes, the cylinder would act like a curved window.
