Project: Water Cycler - many pictures & Video
Discussion in 'Project Logs' started by ThomasM, 18 Dec 2006.
  1. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    I see the Small Final Fantasy X insiration, am i right :)?
    Water cycler logo = Blitzball team logo ?
  2. ThomasM
    ThomasM What's a Dremel?
    6 Nov 2006
    Is correct! Well recognized;) The Logo suitably, only another text found.
    Belongs it to your taste?
  3. Mighty Yoshimi
    4 Sep 2006
    Of course, i just started a new game today :p, my old 154 hour save i messed up so i'm starting over.
    Is it the Luca Goers, or Besaid Aurochs logo?
  4. ThomasM
    6 Nov 2006
    You know the picture;)
  5. Mighty Yoshimi
    4 Sep 2006
    Luca Outstanding, i always loved those logos, i only remember them from having the ffx guide :blush: (only so i can beat penance)
    Looking fantastic built from scratch!, amazing, fantastic looking!.
    Can't wait for more!
  6. ThomasM
    6 Nov 2006
    Final Fantasy is already a super Game
    ;) today or tomorrow it gives an update ;)
  7. Mighty Yoshimi
    4 Sep 2006
    Excellent i look forward to it very much. Outstanding work. FFXII Not too far away maybe some more inspiration there :p
  8. ThomasM
    6 Nov 2006
    The cooler for the Raptor X needs a good vibration uncoupling.
    Here I position the uncupling-rubber,with dobbleside grubscrew.
    The holes for the screw, to fasten the HDD.
    I hadn´t the time to finsh the polish, I´ll do that later.
    Later I´ll fasten a lining of brushed alu-sheet metal ,on the sides.
    On the top of the(under the plexiglasses) HDD I create something for a good light effect.
    I think the bent is a little to high.
    So I heated it up with a hot air dryer to make it a little smoother and pulled it a bit larger and deeper.
    The result.
    Now I fastened the plexiglasses ,then fastened the mirror-plexiglass on the front and behind the HDD, the lining at the sides under the HDD cooler.
  9. Mighty Yoshimi
    4 Sep 2006
    Amazing really impressed, we're all gonna wanna know the Total build cost at the end !,
    How many Projects have you done?
  10. ThomasM
    6 Nov 2006
    believes me, before this I ONLY times a water cooling built, and a window into the side one chieftecs built
  11. GTS2
    GTS2 What's a Dremel?
    29 Jul 2006
    now i understand why noone wants to reply to my mod... i tried very hard but i did so little...
    this mod here shows the difference between fruitless effort and great results...
    dieses mod zeigt das Verschiedenheit zwischen unfruchtbar(es?) Bemuhung und ernst Ergebnis :)
    du bist unglaublich :D
  12. ThomasM
    6 Nov 2006
    that is an interesting complement.
    Danke!!
    Where is your Mod? Link?
  13. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    Looks very very good.
    Cant wait to see the finsh result. Keep it up. :D
  14. xion
    xion Minimodder
    23 Aug 2006
    just ... wow... i cant imagine the amount of time, money and effort this must have taken; at what stage of completion are you now?
    traurig weiß ich sehr deutsches wenig und kann nicht artikulieren, wieviel Inspiration du mir gegeben hast. die große Arbeit aufrechterhalten!
    (google translation sucks like a vax!)
  15. ThomasM
    6 Nov 2006
    to say with difficulty. I always do over again the nose. and I have also 2 children and woman and a job. why I can not make often further
    yes, the google translation is very very bad.
  16. ThomasM
    6 Nov 2006
    Sorry for doubble-posting.
    and it continues
    The ovals Plexiglasses is now finish.But I white also not yet whether I it to really use is.
    A alternatieve would be also, over the HDD an aluminum plate to make those exactly parallel the same Window has as the Raptor X. Naturally also again polishes;)
    If is finished, I make pictures with all variations, then can write it your opinion in addition.
    So, now to the actual part. roofridge of 3 pictures to the position and mechanical function of the whole.
    A Link http://www.myvideo.de/watch/522057 to MyVideo, provided an assembly presentation video. With current function of the HDD of radiator.
    At the HDD Cooler is of course again some new finished, but I want still fine-work there to make
  17. Glengarry
    Glengarry What's a Dremel?
    10 Nov 2006
    1 word.....
    AWESOME ! :dremel: :thumb:
  18. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Awesome work modder! :naughty:
    What's the producer and the model of the vfd fancontroller?
    Byez :rock:
  19. ThomasM
    6 Nov 2006
  20. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    That fan controller is readily available in the UK from Maplin (order code A23FH ), but they want 30 pounds for it. :duh:
