Case Mod - In Progress Project: Water Inside: 23/8 | IT'S FINISHED! CHECK IT OUT!
Discussion in 'Project Logs' started by NysoO, 2 Nov 2006.
  1. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    who wants to bet that those case feet poke a hole in something when it is out of workshop
  2. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    I'd be scared to put it on a glass tabletop. Perhaps he has plans to distribute the load across whatever surface he chooses for the case's final resting place.
  3. NysoO
    NysoO Handcrafted
    2 Nov 2006
    They would. Therefor, i'm going to use something like this:
  4. randosome
    randosome Banned
    17 Sep 2006
    odd to see a PC using spikes, thats usually reserved for HIFI
  5. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    A lot of things used in case mods are normally "reserved" for other things. Look at modsquad's project, its half way to becoming a motorcycle and is sweet. I think the spikes look awesome, good job :thumb:
  6. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Really nice :rock:
  7. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    i love the look of those feet, very minimalistic. damn, thats a lot of gigs!
  8. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Update 6/3 - 07
    Ye'allo boys and girls! Time for a new update! :)
    First off, I saw out a cover of aluminum for the back of the case. I will later on make holes for graphicscard.
    I've got a bit unsure with if I'm going to use the baytank. So I made a swiftech minires out of cardbord. It could fit here, but it will be tight. Any opinions about this?
    If so, the plan is to mount a fillport up in the middle of the case, and connect it to the swiftech res.
    I dumped the original startbutton and got my hands on a chromed button. It is actually a doorbell button. But I believe it is quite nice :)
    Polished the sunbeam fancontroller. or should we say "Fun-controller" :D
    Yep, got a bit blurry at the corner. But I'll fix that, don't worry folks! :)
    Since my tube of autosol got empty, i thought it was time to try something new out. Earlier i got a tip from darkened about this product, and, i can say that it is much nicer than autosol. Smaller grains = better finnish = happy NysoO :D
  9. Jipa
    5 Feb 2004
    Great job! I love the front panel as it's pretty much exactly like the one I planned for my last case (never finished though). white leds and aluminum just match perfectly together.
  10. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Damn I wasn't really expecting this to become something very nice but you've definitely surpassed my expectations. Nice one!
    I think you should make a small grill in the front to allow the fan to pull in air better. How about an update?
  11. nry
    nry Minimodder
    1 Nov 2006
    Thats alot of polishing :eek:
    Looks good though
  12. RonaldoR9
    RonaldoR9 What's a Dremel?
    17 Dec 2006
    dam this is one sexy case
  13. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Very nice, keep up the good work
  14. Jeremiah
    Jeremiah What's a Dremel?
    19 Feb 2007
    Absolutely beautiful worklog. Well done, keep it up.
  15. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Update 25/4 - 07
    Resently came back from USA, so got some watercooling-stuff with me :)
    The order from PT
    The CCFL's seem to be pretty strong
    They are lightning up my room pretty good, should light up the case as good as well, don't you think?
    4 logisys White ccfl
    Swiftech 18w MCP355 with Petras top, DD highflow barbs and sleeved cables, Swiftech MicroRes with DD higflow barbs and a modified barb so it will with in the PG7-thread at the top of the res. And ofcourse the DD- Fillport
    Fillport..
    Swiftech MCRes, nice and tiny little fellah
    Watcha think?
    //NysoO
  16. saxman
    saxman What's a Dremel?
    21 Feb 2005
    wow those CCFL's are impressive. I was thinking of using some like that for my case. If you put pads on the bottom of your feet will you do some LED work on those??
  17. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Saxman: The only pad that I'll use for the spikes is some in metall, that matches the spikes, so I wont be able to do any led-work there. But, i think ill put two of the CC's under the case.
  18. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Update 13/5- 07
    I have sprayed a clear-coat on the chassi and tried some new mounting-positions of the watercooling.
    Sleeved the start-button
    Can you see the clearcoat mirror?
    It almost melts into the surroundings :p
    The new pump made it possible for me to mount everything internally, which also will take away the problem with the upside - down mounted rad.
    Have been trying some loops, any suggestions?
  19. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Update 16/6 - 07
    ZZup, the project is actually starting to run to the end. Most of the design and modification is done. But this is todays update.
    Got some critics on how the front fan would get air, so sawed out a hole in the front door and put on some c-strip. In the same time I painted the inside of the door black.
    From the beginning I was thinking about mounting the rad on the outside, therefor I got a ugly hole for the radiatorhose. So, made a aluplate that i mounted with insexscrews.
    New angle :)
    Shine
    Pictures really can't give the real-life experience. The clearcoat and the polish
    doesn't have its real depth.
    The things that are left to do.
    Hole on the top for the fillport.
    Soldering on a 4-pin molex for the frontdoor leds.
    Mounting the glass in the sidedoor.
    Make holes for the sidedoor thumbscrews.
    //NysoO
  20. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    I really really like your front door idea, very well executed.
