Project: watercooled Lian-Li
Discussion in 'Project Logs' started by -Slayer-, 21 May 2006.
  1. OldY
    OldY What's a Dremel?
    10 Mar 2006
    Never seen those water blocks before, I think they are a ramplex block for memory!, cpu!, northbridge! and voltage reguator?
  2. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Yes, theres the ram block and teh two blocks at the bottom are for DFI Voltage regs and the top one for the north bridge.
  3. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Funky looking water blocks...
  4. -Slayer-
    -Slayer- What's a Dremel?
    17 Dec 2005
    Yes Fr4nk has right :thumb:
  5. koola
    koola Minimodder
    11 Jul 2004
  6. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
  7. koola
    koola Minimodder
    11 Jul 2004
  8. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    I really like the case! Good job on the Grill!!!
  9. -Slayer-
    17 Dec 2005
    Update 22/7-06
    Today I have worked with the placement of the pumps and the valves to drain the waterloop. I also cut out some rubber for the waterpumps to reduse the noise and vibrations and fit it under the pumps. Here is some pics fron todays work and it´s only testmounted on the pics.
  10. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    good job with that grill...nice to see you didn't break any of the web plastic as it looks very thin. Nice looking RAM blocks too. This will be interesting.
    /GNU
  11. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Looks really good.
  12. -Slayer-
    17 Dec 2005
    Update 23/7-06
    Today I have cut out some acrylic to hide all the big holes and just cut out some holes I need for some tubing and cables and I it´s going to be black when it´s finished. I also mounted the big radiator in the top of the case. I changed the T-connector to an y-connector to get some better flow to the pumps. Here is some pics from todays work :dremel: and it´s only testmounted.
  13. antiHero
    19 Jan 2005
    Sweet WC setup! It just looks like the top cd-drive will restriked airflow! Otherwise really nice.
  14. -Slayer-
    17 Dec 2005
    Yes I going to move the hdd block to the top and have the res on the bottom and cd-rom in the center, think thats going to be better
  15. hydro_electric_655
    13 Jul 2006
    I would personally recomend you have the rad on top and the fan sucking air from the outside through the fan.
  16. -Slayer-
    17 Dec 2005
    Update 25/7-06
    Here is some new pics on todays work on my case :dremel:
    Im happy whit the result so far :clap:
  17. Guest-23315
    Guest-23315 Guest
    looks sick!!
    why not use the Lian Li stealth bezels on the DVD drives???
  18. -Slayer-
    17 Dec 2005
    Update 27/7-06
    After a couple of hours and 5m tubing the system is finished :rock:
    It turned out to be more crazy that I thought it would be :D but I`m happy whit the result. Now I have filled the systems up and check for leaks and it´s looks good sofar. It was a bit difficult to fit everything in the case.
    Here is some pics on the system when I`m just finished all the tubing.
  19. Cardan
    Cardan What's a Dremel?
    21 Jun 2005
    wow that actually looks pretty cool with all the tubing like that
  20. simon_C
    simon_C Minimodder
    13 Nov 2005
    yeah now just fill it with some strong UV dye (red maybe ;)) and lght her up! i love the look of glowing tubes in a black case.
