Project: watercooled Lian-Li
Discussion in 'Project Logs' started by -Slayer-, 21 May 2006.
  1. DeNs
    DeNs What's a Dremel?
    3 Mar 2004
    Possibly the dye used? Any metho used in the loop? Only other thing I could think of is overtightening but generally these are more likely to be some kind of reaction.
    Bad luck man :( Anything damaged from it? To he honest I really doubt the safety of using only zip-ties for fastening hoses. A lot of people have no issues with it but I always like to use worm-drive stainless steel clamps :)
    Good work on getting those dual loops going and getting it all put together.
    ---dens
  2. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    its possible the extra weight of the tube has just broken the acrylic ... maybe better support / less tight tubing runs would be better
  3. el rolio
    el rolio What's a Dremel?
    14 Mar 2006
    nice stuff! and yea tubing torque cracked my plexi res threads too, it happens! nice work, but you should consider (not red, but) a different or slightly differnt color for hte other loop. its a nice effect.
  4. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    The red looked like rust after you drained it. I would say there was something in your loop maybe alchohol? It cracks plastic and reacts with other things. But most likely you over tightened or to much strain on them.
  5. CC-R
    CC-R What's a Dremel?
    8 Aug 2006
    by the colors one sees better where which goes
    i dont know is that right i´m german :rolleyes:
    kann einer der Deutschen mir sagen obs richtig ist kann nicht so gut englisch
    hab ich bei goggle eingegeben :rolleyes:
  6. Mr_SCSI
    Mr_SCSI What's a Dremel?
    13 Apr 2004
    You mean...
    By using the two different colours you can see where each loop goes?
    and yes I actually liked the different coloured loops, even if it was an accident or more a teltale that something was wrong.
  7. Zds
    Zds What's a Dremel?
    3 Nov 2005
    Or replacing the piece with fittings with thicker acrylic, or another layer of the thinner stuff. Should increase durability and decrease torque.
  8. CC-R
    8 Aug 2006
    Yes :D
  9. -Slayer-
    -Slayer- What's a Dremel?
    17 Dec 2005
    Update 2/9-06
    Here is some final pics on my project. I hope you like it :)
  10. accro
    accro What's a Dremel?
    21 Aug 2005
    Now it's nice, how about flow rates?
  11. Jipa
    5 Feb 2004
    I really liked the loops when they were different colored :eek: Looks cool now too except I'd possibly change the cable ties to some proper clamps.
    And about your sig - there's no reason to be sorry for your english as most americans can't spell either :D
  12. randomz
    randomz What's a Dremel?
    31 Aug 2006
    lol, so true
  13. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    always think about how much better your english is than their swedish ;) (or dutch in my case, or whatever language you can speak and other people can't)
    love the inside look :rock: nice and cosy :D How much liters does your loop take? :eeek:
  14. -Slayer-
    17 Dec 2005
    I think the flow rates is not so bad but i´m not sure.
    The loops takes about 2-2,5 liters :D
