Project :: Waveline (09-06 = Hardware Installation)
Discussion in 'Project Logs' started by Guest-23315, 3 Apr 2006.
  1. Guest-23315
    Guest-23315 Guest
    well everything sorted, a now Block is monted on my X1800XT- the card now wyas about the same as it did with the stock cooler.....
    heres a piccey of the Block with the flash from my phone camera, it sooo shiny!!!
    And the block mounted-
    well, tommorow my parents are bringing me the rest of the hard ware, so even more photos!!!
    AJ.
  2. J0d3r
    J0d3r What's a Dremel?
    13 Sep 2005
    I love that EK blocks, they look very awesome.
    regards
  3. Guest-23315
    Guest-23315 Guest
    well heres an update-
    after wining my rowing race at the regatta, i came back to this...!
    ooohhh bubble wrap-
    160Gb Hitachi deskstar TK250
    1Gb of DDR-500 RAM
    UV Cold Cathodes-
    Floppy Bay Res, with UV LEDs-
    Nexus fan controler to go with the pump-
    and of course.......
    Food!
  4. Jipa
    5 Feb 2004
    I wouldn't mind if my parents also bought hardware for me :(
  5. Guest-23315
    Guest-23315 Guest
    they don't. Its just it was sent to the wrond adress
  6. Jipa
    5 Feb 2004
    ummh k, didn't understand but :) I'll go to sleep, been awake for 35hours.
  7. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    where does it say his parents sent it, am i being blind lol, or were u just reading between the lines ;)
  8. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    yuck.. highland spring.. tastes like soda water.... or is it soda water? just plain naaasty.
  9. Guest-23315
    Guest-23315 Guest
    this help at all?
  10. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    where did you get that floppy res?
  11. Guest-23315
    Guest-23315 Guest
  12. yahooadam
    21 Mar 2006
    floppy res seems like a nice idea to me, quite small and compact, but what size tubes will it take, other then that, waiting to see some stuff installed :)
  13. Guest-23315
    Guest-23315 Guest
    it takes G1/4" threads, so im shoving some 1/2" barbs in to complete the loop...
    i will hopefully get some piccys of it later!
  14. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    wow great hardware going into this mod then!
    who do you row for because i also row?
    what regatta did u win?
    sorry for off topic but was intrested
  15. Guest-23315
    Guest-23315 Guest
    Eton rowing lake, rafts on the river,
    eton regatta F block coxed doubles b-final
  16. rowin4kicks
    5 Feb 2006
    wow well done on that
    i take it you go to eton then?
  17. Guest-23315
    Guest-23315 Guest
    possibly.....
  18. Guest-23315
    Guest-23315 Guest
    well heres todays update....
    ive got the Res mounted with the frount screws, but havn't got the bit of aluminium with me, so it doen't look to good... also, theres a clear / uv blue acrylic raditor shroud / box to go between the fans and the rad....
    another pic. of the res....
    And the RAM goes in.... (looks like Mushkin Redline, and is DDR-500)
    and in goes the 160Gb Hitachi deskstar....
    Installing the cables for the Vantec Mexus CPU (pump) control and Temp display..
    sensors on the HDD,
    The CPU
    and the *case* temp is put on the outside of the rad where the cooler water exits..
    and a lovely large mass of boxes....
    heres how we are at the moment.....
    it seems i need some more barbs and some cable tiding stuff, then its pretty much done..
  19. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    There seems to be a slight gap on each side of the DVD drive, you can see the light shining through the gaps... It is just me or have you noticed that, because if you put a interrnal LED in there it'll shine through, could look cheap and lack precision... its probably just me or the photo and it'll turn out great
  20. Guest-23315
    Guest-23315 Guest
    no, its cos its not fully tightened....
