Project: WET WEEKEND
Discussion in 'Project Logs' started by fatty, 19 May 2005.
  1. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    heheh, sweet dude, real sweet. I want one:(!
    GL!
    - S
  2. vapb400
    vapb400 What's a Dremel?
    24 Feb 2005
    i was talking about the resevoir. I know alot about watercooling, but nothing of chilling. Looks sweet, good luck!
    I understand you couldn't run it without the compressor, but could you add a radiator into the loop ALONG with the compressor? and only use the radiator during normal usage, or for some reason does having the compressor completely stop the loop.
    I'm reading up on these, so hopefully that is my last stupid question :)
    Mod on!
  3. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    as told to me in another forum: a radiator would only raise the temperature of the water nearer ambient.
    basically, the radiator would add heat when chilling, neglecting the usefulness of the chiller in the first place. ( it makes sense... i think )
  4. fatty
    fatty Minimodder
    12 Jul 2004
    The black box the res or heat exchanger holds about 1 to 1 1/2 Litres of water so it takes a while to heat the water but it still would get hot without a rad
    Ok more pics fitted in the mach1 case
    With the mach 1 covers on
  5. fatty
    fatty Minimodder
    12 Jul 2004
    The chiller has been sold off and the chap who is now fitting it to a system is doing some testing here is some initial testing
    He had to stop due to condensation because of the 8 degrees
  6. orenc17
    orenc17 What's a Dremel?
    16 Oct 2004
    Can Someone explain me why the GFX isnt cooler with the same cooling as the cpu?
  7. c.u.later
    16 Apr 2005
    1 to 1 1/2 litres??? bloody hell, wondered why it took so long to fill and bleed. this is looking a great mod so far, hope it goes well for you,
  8. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    Looks great, makes me tempted to go back to water :D
    How do you stop the condensation ?
  9. vapb400
    24 Feb 2005
    4070MHz! Try and see if you can get into windows at that speed, cuz that would be a world record!
  10. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    @ Vapb400.. that wouldn't be a world record.. If I remember correctly there was a dude who had his over 6 ghz. Not stable at all but still..
    Nice idea + I love the temps.. keep up the modding :rock:
  11. frodo
    frodo What's a Dremel?
    1 Nov 2003
    yeah 6ghz on a p4!!! DUH! a record for AMD 64 maybe :D
    i love this, looks really good, downside is the condensation and what not!
  12. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    lets see his settings for that clock, and some CPUZ validation.
  13. kio_liex
    kio_liex What's a Dremel?
    8 Oct 2004
    4Gig on a AMD64, nice... but don't think that you can run at that speed, Tom H. is the numer 1. i AMD overclocking (my openion), he has a system that cools et dow to -110 C and thats on full load... I think his record i 3.5-3.6Gig on af FX55...
    BTW. nice cooling...
  14. vapb400
    24 Feb 2005
    currently the AMD record is 4005 on an FX-55 from Sampsa and Kamu at XtremeSystems.org
  15. Tulatin
    16 Oct 2003
    if you frowse around XS a little, you'll find a p4 that hit 7GHz.
  16. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    insulate the tubes and the blocks
  17. fatty
    fatty Minimodder
    12 Jul 2004
    The guy that now owns the unit is swapping out the tubing for rubber tubing but he didn't have a spare hdd so thats why there is no cpuz or windows so it probably wont be stable lol but he has saved the speed in the bios and rebooted a few times if the cpu didnt like the speeds it wouldnt let you into the bios at all but until he gets a windows instll then no idea on the speeds....
    As for insulation the tubing is going to be changed when I ran the setup with the danger den uv reactive tubing I had no condensation at 2 degrees what so ever only on the block ....But for the other parts I am sending him some armaflex tape and pipe covering it will be bulky but it will hold in the cold as well as stop condensation
  18. bjones247
    bjones247 What's a Dremel?
    30 May 2004
    This is a pretty interesting idea. I'm not much into water cooling, but I think this could be really good. Subscribed. :thumb:
  19. SAS91
    SAS91 What's a Dremel?
    22 May 2005
    I followed this on the EP forums, very well thought out and v.practical. Im sure phil is having a lot of fun :)
  20. frodo
    1 Nov 2003
    yeah, loadsa people have had 6-7ghz (fugger being #1 atm iirc) but not with an AMD64! all those "records" are for an intel based processor, fugger's was with an LGA775 P4
    that is a record for an AMD64 but since it doesnt/wont boot into the OS i doubt it can be classed as a working record, so :(
    i love the idea though :D im going to be making a bong cooler over the next few weeks, to see if i can beat my triple rad setup
