Case Mod - In Progress !!! Project White Completed New Pictures on Page 16 !!!
Discussion in 'Project Logs' started by alain-s, 27 Feb 2011.
  1. 0rbibital
    0rbibital What's a Dremel? Stop asking that!!
    28 Feb 2010
    very nice paint job :)
  2. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Think I'd go with the last one, gives a much nicer all round look and more balanced feel to the loop :)
    Coming along great dude, really like the colour scheme and the solid copper tubing :p
  3. The boy 4rm oz
    10 Apr 2008
    Looking good so far, I'm looking forward to seeing more. Congrats on the MOTM nomination BTW :thumb:.
  4. alain-s
    alain-s Active Member
    12 Jan 2011
    Thanks :p
    Here is a small teaser got no time for update but wanted to share this with your guys ^^
  5. Vandalo
    Vandalo Member
    24 Mar 2011
    Very good work alain!!
  6. KidMod-Southpaw
    28 Sep 2010
    Haven't looked at this in a while and needless to say I'm very impressed, I love the power supply!
    Well done!
  7. alain-s
    12 Jan 2011
    First off all i want to tank the Bit-Tech staff for putting my project in MOTM competition.:thumb:
    It is really a honor to be in MOTM competition. ^^
    thanks ^^
  8. alain-s
    12 Jan 2011
    UPDATE 07
    This week i worked on my bay holders. My first design that i have made wasn't really what i expected.
    Picture's will tell the story
    Personally i don't like it. It looks to basic and wouldn't really fit with the rest.
    I started to look for something else then and then i thought to use the original bay holders from Silverstone and redesign it. ^^
    Putted some tape on it and start the drawings
    Cutted it out
    Then the finished product :p
    Mounted it to check if it would fit nice
    And yes it fits perfect ^^
    Cdrom in it
    then the total picture :p
    The next thing to do fix the mounting for the HDD and make a new Cdrom holder
    stefan442 likes this.
  9. The boy 4rm oz
    10 Apr 2008
    Very nice optical Drive racks :D :thumb:.
  10. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    This is MOTM material in the making... Looking quality already, love the bay mod.
  11. alain-s
    12 Jan 2011
    Thanks :p
  12. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    i really like those round shapes !:rock:
  13. stefan442
    stefan442 Member
    14 Mar 2011
    Nice and original :D
  14. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    :jawdrop: <--- This is me
  15. alain-s
    12 Jan 2011
    Thanks
    :p :D
  16. alain-s
    12 Jan 2011
    UPDATE 08
    Time for a update ^^
    it has bin a while when i posted some progress.
    The reason here for was that i wasn't completely satisfied with the original idea of placing the HDD cage against the case.
    This is not really fitting with the rest of the parts. So started to dismantling the HDD cage and
    started to draw some new pieces.
    Dropped 1 piece :s
    Lucky for me that the pieces are going to be painted so i glued it back to getter.
    Here is the pcb from the hotswap.
    This is how it need to look like.
    Sanded all the pieces and putted every thing back to getter
    I even made some HDD cooling (fan will be replaced with a other 1
    Mounted the hole thing against it
    Holes for the cables
    Then i also had to make a new Slimdrive holder
    The mounting mechanism can be changed but i don't know yet
    Like this i can cover up all the cables between the front plate en de plate behind it
    HDD in the hotswap
    This is it ^^ tomorrow i need to get some new screws to finish it off then this part is ready.
  17. Stem83
    26 Mar 2011
    Keeping the design going there. Getting a decent frosted acrylic look is difficult but i didnt see much in the way of lines or uneven sanding so nice work there as well.
  18. alain-s
    12 Jan 2011
    thanks ^^
    But the plan is to paint all the parts in white.
  19. alain-s
    12 Jan 2011
    Update 09
    Small update of the painting and the extra hardware that i got from a friend yesterday.
    First i dismantled my raptor HDD so i could paint the housing.
    I got some 2 component filler to remove the lian li logo's.
    2 layers of primer and after that the white paint
    Then the other parts Before it started to paint those i did some miner improvement on the holes. So the bolts sink in the object.
    Painting ^^
    Putting it all back together.
    Then the hardware that i got to borrow :p
    I got these part from from a very good friend. In the past i modded his Corsair 800D
    Here is a picture of the pc that i made for him.
    The parts that i got where GPU CPU motherboard ram.
    Asus HAD 4870x2
    Motherboard is Asus P5Q PRO cpu is a core duo something :p and the ram dono what kind or speed labels are removed.
    The next steps are sending my Gigabyte P67A UD5 back to the shop to get the B3 version of it.
    When i got my new motherboard i can start to build in all pieces.
    So i can start to cut and bend the copper pipes.
  20. chaclegecex
    chaclegecex New Member
    5 Jan 2011
    Project White Update 21/04 HDD cage ready
    fantastic project mate . but how did you do the 2nd sampl of CF ?? Also any pics of the roll cage , in a built from ??
