Case Mod - In Progress !!! Project White Completed New Pictures on Page 16 !!!
Discussion in 'Project Logs' started by alain-s, 27 Feb 2011.
  1. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thx mate
    But i don't really understand the question.
    Its probably my bad English.
  2. KidMod-Southpaw
    28 Sep 2010
    That all looks awesome, especially painting the housing of the velociraptor. And the circle shapes look effective and original! Well done.
  3. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank ^^
    Today the HDD brackets are ready with the paint so i can show some picture of it tonight.
  4. alain-s
    alain-s Minimodder
    12 Jan 2011
    Shadow703793 likes this.
  5. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Black HDDs is fine- adds some nice contrast & makes the handles stand-out more I reckon :)
    Really like the details on this chassis, gives it that extra touch of class, rather special compared to all the straight edges and long lines you normally see on a chassis..
  6. Cheapskate
    13 May 2007
    This is getting really slick. I like the decorative elements, and how you cut them out of the original drive bay. most people would just chop at a straight line.
  7. alain-s
    alain-s Minimodder
    12 Jan 2011
    Idd maybe its better like this the longer i look at it the better it looks :p
    THx Cheapskate ^^
  8. bulldogjeff
    2 Mar 2010
    Agreed with cheaps, it's got a nice style to it. Nice work dude:thumb:
  9. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thanks Bulldogjeff
    Here is Update 10
    My first set of copper pipes are ready.^^
    And they fit perfect i also placed the PSU on its place to loot at the cable management.
    Here are some pictures.
    I placed the old Motherboard on the tray so i can place my HD 6970 to fit the pipes.
    Taking care of the HD 6970 so i can place the water block on it.
    When i removed the stock cooler is saw this on the power connector.
    The first 2 pipes are ready :p
    Then i also checked for the power cables and it looks pretty good.
    Now i need to wait for my order from Highflow so i can finish my loop with copper pipes.
  10. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
  11. Samaya
    Samaya Lion Country
    2 Jan 2008
    Copper pipes => :jawdrop: dhat are the awesomest :rock:
  12. GCOFIELDD
    GCOFIELDD Minimodder
    10 Oct 2010
    I am really digging those copper pipes man :rock:
    What is the part number of that hard drive mount you are using…?
  13. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    dem copper pipes :jawdrop: :eyebrow:
  14. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    God damn this looks good. That's all i can say.
  15. voigts
    voigts What's a Dremel?
    26 Apr 2006
    What fittings are those that you are using to connect to the copper pipes? They look like Bitspower fittings, but I am unaware of any that will mate to copper.
    That is some really nice copper bending there.
  16. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    Nice copper you have going there!
  17. (FIH) The Don
    (FIH) The Don What's a Dremel?
    27 Jun 2010
    hawt damn :jawdrop::jawdrop:
    is that soft copper tubing you're using?
  18. Nexxo
    23 Oct 2001
    Absolutely. And they are such a good solution the I wonder why people don't use them more often. Excellent bending there. That is where the real skill lies. :thumb:
  19. alain-s
    alain-s Minimodder
    12 Jan 2011
    The parts for the HDD mount came from Lian Li EX-H34B HDD Cage
    The fittings that i am using are idd from bitspower:
    Bitspower Multi-Link (SLI/CF) Adapter BP-WTP-C47 Silver Shining
    Bitspower Multi-Link (SLI/CF) Adapter Mini BP-WTP-C48 Silver Shining
    The copper pipes are 12mm and they fit perfect
    No these pipes are harder then the rolls of soft copper
    For the rest of u all thx i really love that u all like the result with the copper pipes
  20. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    love this mod.
    And, for the corner cut off the gpu: it's becaomse someone messed up, and the first run of those cards all had that corner taken off, by hand.
