Hi everybody, after my first mod Pure, I start my new project, White Crow. Project plans: - Small case, volume about 8 liters, 20x20x20cm - Scratch built from stainless steel and 1mm steel Colors: - Glossy white front, top and back - Side from fumed plexiglass - Squares on top and front, from fumed plexiglass - Orange backlight - White, gray and black sleeving Hardware: - CPU - Atom - MB - Intel D410PT or maybe something else - PSU - Enermax Pro82+ II 525W - HDD - I need to buy new one, maybe two SketchUp Project: Some photos of work: Greetings, Peter
Hello again Yesterday, I turned the frame, as you can see. Also I pulled out motherboard tray from another case. I pulled out hex mesh as well. On the picture 4 you can see 2 sheets of steel, on the left shining stainless steel and on the right 1mm steel sheet. Tomorrow I'm going to start cutting the sides of case. And sorry for my poor English. Thanks guys!
Small update: I cutted motherboard tray, but I will enter the small corrections. Also I fitted all parts together (I wanted to check if the CPU fan will come).
Hi, another update today. This time I cutted and finished HDD mount, and that tradition has been done, I present some pictures of the work and the effect: Thanks If I had money I would buy new PSU like pico. But I do not have any, so I will use the PSU which i won in Mod Contest Vol.2. It will also fulfill the functions of case ventilation. And I think it's "a little" over top but I have no other PSU. On the days I'm going to write to a certain company, and ask whether sponsors a project, I hope to convince them. Greetings Peter
