Case Mod - In Progress Project WiiPC
Discussion in 'Project Logs' started by Marmotta, 26 Jan 2010.
  1. Neji
    Neji What's a Dremel?
    3 Jan 2006
    Great stuff. I wanted to try this but never came across a broken Wii. I think you're going about it in a much better way than I could have anyway. Can't wait to see you finish this.
  2. Marmotta
    Marmotta What's a Dremel?
    2 Jan 2008
    Tried that already:) I think the card detection pin on the Wii SD card slot is recessed, which makes it near impossible to solder. I don't want to take it apart to solder to, incase I mess up the push-push spring. I might just order one of these:
    http://www.sparkfun.com/commerce/product_info.php?products_id=204
  3. Marmotta
    2 Jan 2008
    Been working on the rear I/O connections - got the USB ports, power and fan hooked up fine and am now working on the VGA connection, which is great fun, as you can see:
    For some reason the connections on pins 6 and 12 (which are usually both ground in the Wii, but I was using them for ground and V-Sync) weren't getting a signal, so I had to reposition them and add pins to the AV connector from another component cable. It now displays on my monitor, but with a ghosting effect. Anyone know what could be causing this?
  4. Snaek
    Snaek What's a Dremel?
    10 Jan 2004
    I love the fact that you're using all the original ports and such. Hopefully you can get everything working properly; it'd be very cool.
  5. Marmotta
    2 Jan 2008
    Sorted the VGA issues and made a bit of progress. Completed the rear I/O ports and almost done on the front ones - just have the niggling SD reader to finish.
    Power, VGA, audio and sensor bar:
    USB:
    I/O stuff in place:
    With motherboard:
  6. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    Mate that is nuts, good lucky it looks awesome!
  7. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    Looks very good so far. I like your cable work to preserve the looks.
    What motherboard is that?
  8. Marmotta
    2 Jan 2008
  9. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Hows this going?
  10. bulldogjeff
    2 Mar 2010
    lol I've just been doing exactly the same thing:D
  11. Marmotta
    2 Jan 2008
    Long time since I've updated this, but it's definitely on the backburner for the timebeing. I decided that the motherboard just wasn't powerful enough and still had some minor issues with the VGA signal. Hopefully something in a Core 2 Duo configuration that I can afford will come along before too long.
