Project: Wooden Silence
Discussion in 'Project Logs' started by HQ08-Modder, 3 Apr 2004.
  1. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    Alright i just though of this project this morning and got started asap. Its basically my lan box that is made out of wood and it must be silence. The cpu will be watercooling and the case will have nosie dampening stuff inside the case to reduce nois as much as possible. Unfortuently i don't really want to have a backplate for the motherboard because i want a decent amount of airflow.
    System Specs:
    CPU: 1800+ or Duron 1800+ About 70 bucks
    Motherboard: BIOSTAR M7VIZ Motherboard VIA KM400 + VT8237 Chipset INTEGRATED VIDEO AUSIO and LAN - Price $ 89
    Memory: MUSHKIN 512meg DDR333 BLACK LINE Hi Performance LEVEL2, Rated 2-2-2, 6 Layer PCB with Heatspreader
    Price $ 149
    Hard Drive: Western Digital 120 gig 7200rpm 8meg Cache JB with Data-Lifeguard ATA-100
    Price $ 139
    PSU: Vantec ION 400Watt $118.00
    Cooling:
     Revision 3 VGA Silencer $32.00
     ZM-NB47J $10.00
    2x Zalman 80x80x25mm fan, comes with 4 screws and inline resistor to reduce the speed of the fan, Normal mode: 36.5 CFM 34.2dB(A) 3000rpm. Noiseless mode (using resistor): 20.6 CFM, 20 dB(A), 1700rpm, $ 10 each
    Why no video card, well im gonna use my current one instead.
  2. HQ08-Modder
    14 Nov 2003
    First Update
    Today i set out just to get the base of the case completed. So i went looking in the workshop for some decent wood and found a nice base which needed to be cut. I marked out my dimension needed and glued some nois dampening sheets on. Then i test fitted everything except mobo, cpu etc.
    Overall
    Heatercore
    Hard Drive Foam Silencer
    Cd-rom Foam Silencer
    PSU and Where My heto 2800 pump will go
    The height of the case
    Also my watercooling setup follows:
    Heatercore out of a Commodore
    Boris CPU waterblock
    Heto 2800 silenced :)
  3. lamcdonald
    lamcdonald What's a Dremel?
    1 Mar 2004
    Looking good! :thumb: Don't know if the HDD will like the foam though :worried:
  4. HQ08-Modder
    14 Nov 2003
    Yer im not sure what else i could do to dampen the sound of the hard drive without it whining at me because its a) too hot and b) its loud.
    Got any suggestion?
  5. HQ08-Modder
    14 Nov 2003
    The Design
    Okay i drew up a basic design of what the case should look at the end of the project.
  6. dream caster
    dream caster just lurking from out there
    1 Jan 2002
    water cooled metal enclosure
  7. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    one suggestion,
    compress those damn images. :nono:
  8. Infraggable Krunk
    Infraggable Krunk What's a Dremel?
    7 Mar 2004
    haha yeah
    you might want to get a thermal probe and see how warm your hard drive gets like that after a defrag, it it gets past 60 C your in trouble
    A similar thing happened to me
    I bought two silent drive enclosures, my WD 120 GB was fine but my !@) GB maxtor drive was over heating, so i wasnt able to enclose it. You might want to get an aluminum plate to work like a heatsink ( that kinda how the silent drive does it)
    best of luck, if you have any questions about sound proofing/sound dampening/sound absorbing Im your man
  9. HQ08-Modder
    14 Nov 2003
    Watercoole Hard Drive Designs
    Alright i've looked through the ocau Water Cooling section and found some nice cooling units for hard drives.
    What ones do you reckon would work better?
    #1
    http://www.users.bigpond.net.au/pippin88/blocks/hdd.jpg
    http://www.users.bigpond.net.au/pippin88/blocks/hdd1.jpg
    #2
    http://home.swiftdsl.com.au/~peterwayne/images/OCAU/Hdd/hdd1.jpg
    http://home.swiftdsl.com.au/~peterwayne/images/OCAU/Hdd/hdd2.jpg
    http://home.swiftdsl.com.au/~peterwayne/images/OCAU/Hdd/hdd3.jpg
    http://home.swiftdsl.com.au/~peterwayne/images/OCAU/Hdd/hdd4.jpg
    http://home.swiftdsl.com.au/~peterwayne/images/OCAU/Hdd/hdd5.jpg
    IMHO the second one looks much easier to make.
    Also i've tried to compress the pics and i've got some thin wood to finish the case tommorow.
  10. HQ08-Modder
    14 Nov 2003
    What can i use to sound proof the inside of my case?
  11. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    Out of curiosity, why does it have to be so quite? And if you wanna see a crazy quite watercooled computer, just take a look at this, http://www.mashie.org/casemods/y2k01.html It is a completely watercooled computer running off of only one 120mm fan, very cool case i must say. But I'm digressing again :(
  12. dream caster
    1 Jan 2002
    Look at this project in BladeRunner site, www.zerofanzone.co.uk. I would try to build a complete enclosure for the hard disk having this kind of watercooling plate as one of its bigger sides; i would use aluminum for the non water cooling sides of the box.
