Project X-1 (rev.a) [Update 24-05-'04] [ON HOLD]
Discussion in 'Project Logs' started by magicpixel, 11 May 2004.
  1. magicpixel
    magicpixel What's a Dremel?
    11 May 2004
    Project on HOLD.
    -=====-Sorry all, have got allot to do latley and my project has to be haulted for a while.
    When I get back to it, I'll let you all know.-=====-
    Hi all,
    Along with this being my first post here,... it's my first mod too :D
    This'll be a 'milk run' for my next workstation I plan on building(no point in trashing a new machine,.. I am a newbie remember).
    The specs of the rig are:
    C3 full tower 'smoked' acrylic case
    Asus A7M266-D Dual mobo
    2 AMD 2000+ MP
    1GB DDR
    1 IDE 200GB HD 7200rpm <-- (-- edit--NOT 200MB :rolleyes: Thanks Balder )
    1 IDE 120GB HD 7200rpm
    2 SCSI 36GB HD 10000rpm
    Haven't decided what DVD/RW to get yet so I'll stick with my 12x CDRW :worried: :D
    Anyway my case arrived a couple of days ago and to my horror, the bottom end of the mounting blocks(on the front panel) had become 'unstuck'. :waah:
    A better view (slipped a card between so you can see what I meen)
    Time to give our patient his 'shot'.
    Awww all in bandages.
    Ok, ok already! I know it's not a mod, just a quick fixbut hey :D .
    Just a quick fitting to see how well my Zalman ZM-WB2 waterblocks sit in place.
    Looks pretty cool huh?,...
    ... and then I noticed that the motherboard had NO mounting holes in it :wallbash: GREAT!!! Now what?,...
    Yup, you guessed it :dremel: MUHAAAAHAHAHA!,.... gulp :worried:
    SUCCESS!!! YEEHAAA!!!,... ahm,.. sorry about that.
    So that's about it so far. Unfortunatly I don't have much spare time anymore so this project is going to be slow.
    Anyhow, I have to be off. I'll try and update this as much as possible.
    Thanks all for taking the time to drop in.
    Cheers,
    Chris.
    Pics,... FIXED! :D
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    Welcome to bit-tech
    Looks good, Can't wait to see the finished result
  3. PsychoI3oy
    PsychoI3oy Minimodder
    13 Apr 2004
    does the mounting for that waterblock get in the way of the agp slot? it looks like a very tight fit if not
  4. r3Q
    r3Q Minimodder
    31 Jul 2002
    dude. i cant believe you drilled out those holes =)
    i didnt realize that that worked. :jawdrop:
    welll... i might go ahead and get that DFI lanparty then ;) BWAHAHAWHHAW
    looks great BTW
  5. magicpixel
    11 May 2004
    The board (Matrox Parhelia) clears the bracket by less than 1mm. I'm not going to leave it at that though. There's lots of excess I can dremel off the bracket.
    Chris.
  6. PsychoI3oy
    13 Apr 2004
    probably a good idea, wouldn't want to wiggle a monitor cable and short out the back of your (rather expensive) video card.
    looks like a fun project, haven't seen too many watercooled dualies around here :)
    (edited to remove pic in reply)
  7. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Looks like the case that orac used... watching for more. Ahh! Drilling a MB :sigh:
    Good Luck
  8. magicpixel
    11 May 2004
    Thanks mate.
    I wasn't too happy with the idea to be quite honnest with you. Kind of like jumping in the deep end from day 1 :D
    Yeah it's a C3 fulltower like G-gnome's Orac only mine's the BlackIce 'smoked' From clear computer case.
    Come to think of it, G-gnome's Orac is the reason I'm doing this. I hadn't a clue that case modding was even done 'till a freind pointed me to his 'masterpiece' right here on bit-tech. :jawdrop:
    Thanks for all the replies guys
    I'm starting to really like this place :rock:
    Chris.
  9. Alexia
    Alexia What's a Dremel?
    17 Apr 2004
    Very... oh so very brave of you. Mmm... dualies. :blush:
  10. steff79
    steff79 What's a Dremel?
    10 Dec 2003
    :jawdrop: that hole drilling is painfree... are you sure the board still works? mod on...
  11. magicpixel
    11 May 2004
    Yup I'm using it right now. :D
    Actually I did get a scare out of it. the first time around it wouldn't boot. Pulled out everything and put it back,... nothing
    Turns out, all it needed was a BIOS reset, go figure. :eyebrow:
  12. woodshop
    woodshop UnSeenly
    14 Oct 2003
    man you got balls. :hehe: :hehe:
    looks nice i just priced those cases too.. if mine came out of the box like that for that price i'd be giving them h*** on the phone.
    nice so far thoug please keep the pics comming.
  13. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    OMFG, thats realy crazy :jawdrop: drilling holes in youre motherboard, glad it worked.
    I like clearcases, as long as the internals are nice and tidy, I'm gonno follow this one :thumb:
    [funmode]
    The only thing, buy som bigger harddrives, i dont thing that youre 200Mb will do muck good.... :hehe: [/funmode]
  14. magicpixel
    11 May 2004
    You gonna hate me for this but,.... This is just a milkrun for my new workstation.
    I'm planning on replacing everything except for the graphics card and the 2 SCSI drives. Gonna leave them for SYS drives.
    The mobo will be replaced with a dual 64bit one
    CPU's 2 AMD Opteron 248's
    4GB DDR ram
    and last but not least The 2 IDE's will go and be replaced with 4 250GB SATA drives for a grand totall of 1TB!! WOOHOO!! but that'll be around x-mass.
    Overkill you say,... well yeah but it's not a gammer. I do 3D animation and a lot of video editting for a living so I need the power and the space :D
    Cheers,
    Chris.
  15. Balder
    4 Jul 2003
    Hhehe, the point was, I hope it 200Gb, not 200Mb... etc..
    But still looks promising :)
  16. magicpixel
    11 May 2004
    :duh: LMAO!! I totally missed that :D
    I'll go edit it hehe.
    Cheers mate.
  17. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    good job! extremely brave of you to drill your mobo! :dremel:
  18. IaKoVl
    IaKoVl What's a Dremel?
    31 Oct 2003
    Dude , u r 2 crazy 4 me :jawdrop:
  19. Carbon
    Carbon Banned
    8 Jan 2003
    Man, drilling your board is crazy but i like it :D !!! ill defo be poping in here a few times
  20. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    ouch that is a tight fit.
