Project : X-box Stacker (lot of pics 07/10/06)
Discussion in 'Project Logs' started by saiko, 16 Aug 2006.
  1. saiko
    saiko What's a Dremel?
    16 Aug 2006
    Hello everybody. I'm a student from Belgium.
    I like to game alot. But because I'm a student I have to go to university.
    The school is pretty far from home so I have to rent something overthere.
    BIG PROBLEM it has to be cheap -> no tv or cable connection and very small.
    solution build my 2 game stations in one case.
    I started this project about a year ago. So I'll update alot in the beginning.
    But the project is still not finiched.
    I have alot of pictures from the modding.
    this is how the case looks at this moment
    but I'll start at the beginning. (the first pictures are bad quality sorry about that)
    In that time I had a small pc (µatx) and an x-box.
    So I had the great idea to buy a big stacker case en just put the two togheter.
    First I had to take the X-box apart
    then I had to make a base for it.
    I used long motherboard standoffs and drilled some holes in my stacker.
    It was a VERY tight fit.
    then ofcourse I needed the powerbutton,reset,and the controllers in front.
    because the cabels from the x-box motherboard to the connectors were to short I had to solder about 150 wires.
    the dvd unit was a bit harder. There were no holes in the side. But we are modders for something.
    and a total shot at front
    the inside (at that moment still my old µatx
    so the first big thing was realised the x-box was up and running in my pc case.
    With a tv-card I can use my pc screen for the x-box gaming.
    The first plan was to stop right here because I had done what I wanted.
    But once started I couldend stop.
    I bought this 4 inch screen.
    ****I'll keep the tention and will update in a few days
    tired of translating (sorry for my bad English)
    Next few days i'm at a festival. I'll be back sunday.
    I you want more updates I'll see it then.****
    Greetz Saiko
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Great idea. I may just make a new box for my XBOX the stock box is tacky.
  3. DougEdey
    5 Jul 2005
    Will the 4" be big enough to view?
  4. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    nice work neighbor! :p
    [dutch mode]
    Veel plezier op Pukkelpop gast! Of ga je naar nederland voor Lowlands? :)
    [/dutch mode]
  5. saiko
    16 Aug 2006
    the 4 inch screen will be mounted in the 80mm hole on top of the stacker
    and a bigger screen wouldn't fit.
    thx LuitvD. indeed pukkelpop . ideaal wheather for a festival. It's raining cats and dogs.
  6. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    Agreed....
  7. saiko
    16 Aug 2006
    so I'm back from the festival. It was great.
    I'll post another update right now.
    So I removed the fan on top and cutted the stand-offs for the fan mounting.
    then I placed the madcow psone 4 inch screen on-top.
    first test was already great. it showed my x-box background nice and clear.
    since the stacker is standing next to me on the ground I have a clear look on the screen. I'll use it to show my system stats during gaming.
    and offcourse to show-off at lanpary's.
    then I started with the side panel. I wanted something realy simple.
    So not a big logo cutout or whatever.
    and an overview with the old hardware.
    that's it for today.
  8. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Looking good.
    Have you made anymods to the xbox?
    IF you had upgraded the dvd you would of had one that fit.
    What are you using as a psu?
  9. g1zm0
    g1zm0 What's a Dremel?
    18 Aug 2006
    wow cool idea dude nice modding in your case, i am tempted to do a similar mod now lol
  10. samkiller42
    25 Apr 2006
    Your VERY Brave fella, taking an XBOX apart, looking good though, nice ideas and nice touches :D
    Sam
  11. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    its done all the time for chipping, and adding a screen, and so on and so forth
    that's a point, is your x-box chipped ? ;)
  12. hydro_electric_655
    13 Jul 2006
    Chipped lets it do something illegal but i forget what?
  13. HighWire
    HighWire What's a Dremel?
    21 Mar 2005
    I think it allows u to run copied games and such... U can get those things for playstation aswell...
  14. sunnyg
    sunnyg What's a Dremel?
    18 Aug 2006
    yep, i have a little useless lcd screen on my xbox. the chip is usefulll for watching different region dvds
  15. saiko
    16 Aug 2006
    yes my x-box is chiped but I can not play coppied games. (illegal)
    I use it for:
    -xbmc (x-box media center) my x-box is a real media center.
    -shorter loading times for my games (I can put them on my hard disk)
    -bigger hard disk for my music collection.
    more info about the software
    http://www.xboxmediacenter.com/index.php
  16. Blame582
    Blame582 What's a Dremel?
    24 Apr 2003
    this is a pretty cool idea
    but i think the lcd would be cooler if you had it flip up kinda like the game boy advance
  17. yahooadam
    21 Mar 2006
    you can probably upgrade the firmware to play copied discs
    anyway, being able to play games off the HDD means you could play a copy anyway
    I wonder if talking about chipping is allowed on this forum ....
  18. LuitvD
    13 Aug 2006
    why wouldn't it be allowed? :p And why is chipping an XboX illegal anywayz?
    Being able to do illegal things isn't illegal... Actually doing those things is... Getting your xbox chipped for XBMC isn't illegal... Chipping your Xbox and using copied games IS, because copying games is illegal, doesn't mean you did something wrong when you chipped your xbox
    anyways, nice modding, like the window you've made :) keep up the good work
  19. yahooadam
    21 Mar 2006
    i think your right though, but some forums don't like discussion about possibly illegal activities
    like i bet we couldn't plan a bank heist, sure we may not do it, but its a means of doing something potentially illegal thing
  20. Denied
    Denied What's a Dremel?
    28 Oct 2005
    just as a quick aside, just be wary of console chipping conversations. It is not condoned on this forum (i speak from experience, was asking about chipping my ps-one also for legitimate reasons).
    And depending on where you are in this wide world, it can be illegal to chip your xbox.
    That aside... i love the integration of the xbox in to the stacker... nice job man!
