Project: X-LU [5/31/07]
Discussion in 'Project Logs' started by Mohikan2004, 31 May 2007.
  1. Mohikan2004
    Mohikan2004 What's a Dremel?
    31 May 2007
    This is my very first case project ever done. well, ive been working on making a gaming pc console type to compete against my friends Playstation 3 and Xbox 360.lol. But i want the case to have the looking of a game console. I couldnt find a console looking case on my local pc store or online, so i said i should make my own case from scratch, so i started skeching my ideas in 2004 and never brought it up until today. Some will say it looks like a PS3, but i came up with this design long before ps3 came out, im surprise ps3 looks similar to this design. Finally! this case will come to life after 3 years being in sketch. The case will be constructed
    of brush aluminum. This sytem will be a dedicated gaming only installed with GAMEEX from Atari to N64 loaded with a total of 15,000 roms, and 55 pc games from 2005 to 2007 with no-cd patches. Windows will not boot directly into desktop, instead will boot directly into Gameex by doing a registry tweak, so no windows desktop will be behind it. Will be connected to a 45'' HDTV display, some games will be playing at 1280 x 720 and 1900x1080 at max settings, and using xbox 360 wireless controllers, and 5.1 surround sound. My goal is to keep system uder $600 dollars.
    MSI K9N4 Ultra-F (new - $59.54)
    1GB PC2-6400 DDR2 DIMM Memory Kit (new - $61.89)
    AMD Athlon 64 X2 3800+ Dual Core Processor (used - $58.00)
    Fortron Source AX450-PNnb (new- $49.99)
    eVGA GeForce 8800 320 mb GTS Video Card (used - $240.65)
    Hitachi Deskstar T7K250 250GB Hard Drive (new - $53.00)
    Total $523.08 w/tax and shipping
    thank to ebay (new and used hardware)
  2. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    That's a pretty sweet front end. Got a link?
    edit: nm, i'm a muppet, didn't read.
    Might want to add some actual progress, so the mods don't bin it!
  3. Evenge
    Evenge Minimodder
    16 Sep 2006
    Looks nice and interesting!
  4. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    looks awesome and it will be if you can pull it off!!! wot are you going to make it out of??
    cheers josh/gingermonkey
  5. Mohikan2004
    31 May 2007
    Its going to made out of Aluminum brush metal.
  6. x06jsp
    2 Apr 2007
    nice! wot will the inside structure be made from? alu bars or angle section or what??
  7. Mohikan2004
    31 May 2007
    yes, the inside structure will be made of aluminum bars.
  8. x06jsp
    2 Apr 2007
    klkl!!
    good to see youve got it all planned!
    if your in the uk i highley reccomend www.hindleys.co.uk for any materials ond tools! they are very cheap!!
  9. beesbees
    beesbees What's a Dremel?
    29 Apr 2007
    This will be awesome if it goes to plan!!
  10. TNash
    TNash What's a Dremel?
    12 Mar 2007
    cool idea, nice design!
  11. mattthegamer463
    26 Nov 2004
    Looks awesome, reminds me of a project I was going to do with a compaq desktop PC before the motherboard went POP.
    I had designed my own interface program using VB, unfortunately it sucked. The project failed shortly after. I may take a new crack at it with that fancy new GUI program though. Thanks
    I can't wait to see this in action, its got a PS3 feel to it, very sleek. I like the wave in the top.
  12. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
    kick a$$ will be watching this one ;)
    (subscribed)
  13. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Really cool idea; hope it goes well! Will be watching...
  14. ottzen
    ottzen What's a Dremel?
    28 Nov 2006
    Ooooh, me like :D
    I like the "dip" in the top!
    //ottzen
  15. Noobkiller
    11 Jun 2006
    What happened to the project! Not to be mean. but are you still working on it?
  16. x06jsp
    2 Apr 2007
    yer we want updates:thumb:
