Case Mod - In Progress Project: XBOX Supreme
Discussion in 'Project Logs' started by kier, 25 May 2011.
  1. kier
    kier -----------------
    1 Mar 2011
    Sponsored by:
    Presenting:
    Hi fellow modders, it's kier again.
    I was looking a long time for this Lian Li case, the PC-XB01
    I knew he was EOL, but there is always someone who has this one.
    So the search continued.
    Did this case is really a beauty and offers quite a few opportunities because
    Xbox is not really big and little more content, while the Lian Li is quite large.
    It therefore offers opportunities for an expanded water cooling setup to installon the CPU and the GPU Proccesor.
    After some research, I accidentally found a lovely Lili with a good friend:
    Gnoom172.
    Gnoom I owe you one
    Also He had a nice Watercooling set for the Xbox. Which is very sweet, but too little for me.
    I was then also noted by wwwicked a nice set from the famous Highflow shop ;)
    It was the XBOX PRO Dual 40 Watercooling Kit
    Also very nice. But for a large case like i have now it’s actually too small
    So after some fitting and measuring, I found out that it is quite possible for the following parts:
    EK-Multioption RES X2 - 250 Advanced
    Laing DDC-1 MCP350 12V
    Black Ice GT Stealth 120 Black
    Nanoxia DX Series 120MM DX12
    Hmm, I think the color combo is gonna be again black / green uv......I like it ;)
    And 2 x a EK-Supreme HF Nickel CPU Block
    The Supreme's will fit nicely. I just need to mod the brackets, but this will definitely be nice
    With this beautiful List I went to Freddy, and Highflow is again prepared sponsor this build
    Freddy / Highflow thnx again very much
    To start with I have some photo’s taken from the beautiful Lili
    These are the victims that I had left from a distant past. ;)
    And I could not resist to test the little sweet set
    With the set is nothing wrong, but would like some more extreme than this, what will succeed. I know it for sure.
    So this is the start of a my new build.
    Grtzzz. And to be continued
  2. KidMod-Southpaw
    28 Sep 2010
    Kier is back! This looks promising.
  3. stuartwood89
    20 Aug 2008
    Looking forward to this!
  4. bulldogjeff
    2 Mar 2010
    Is back? I don't remember him leaving. That make 3 projects on the go now...lol
  5. kier
    1 Mar 2011
    Update!!!
    Today and yesterday got some very nice stuff in of my belgium neighbors and High Flow
    Yes, I had some luck ............ Ac Ryan acryl still in there shop;)
    Uv green rules ;)
    The size of the side panel taken
    And put some nice UV strips in the back
    Both sides and just the right size
    Placed the acryl and lights out
    Also placed the sidepanel
    And the effect is quiet nice
    The other side is coming the same with some adjustments, transparent window and hole in the side panel.
    And today got some nice stuff from Highflow
    The Black Ice GT Stealth 120 Black radiator
    A nice EK acryl top for the Laing DDC-1 MCP350
    And the MCP350 pump
    And my favorite fan, the Nanoxia DX 120MM DX12
    Also not to forget, the 2 EK-Supreme HF Nickel CPU Blocks
    Placed the EK acryl top
    And this is what's coming in xbox
    After all this picture taking, it's time to Dremel the bracket
    marked the pieces
    After some filing and grinding
    And put it together again
    Number 1
    Both Supreme's side by side
    That's it for now. Weekend is coming more ;)
    Grtzzz.
  6. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    looking good!!
  7. jamsand
    jamsand Minimodder
    21 May 2011
    I'm not sure why you'd want to watercool an xbox since the cooling would cost more than the xbox bt it will look eic! looking forward to this one
  8. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Holy watercooled xbox!
    Like it :)
  9. kier
    1 Mar 2011
    Update!!!
    I found out that the radiator does not quite fit nicely. When i put him on the inside and place the fan on top it came too much into the case. So I moved him to the outside. First marked the holes for the fittings.
    After drilling the holes placed the radiator
    Placed BP Fittings
    And placed the fan
    Power on
    I love the looks of the Nanoxia uv green
    The total is still quite nice, the radiator is pretty slim. But not finished, something beautiful is coming my way from Mnpc , but that’s classified
    I also have painted the mounting hardware for the dvd and hdd black
    And I’ve started to work an the other side. In this I want the uv green edge back again. So again sawn another piece of green
    And then mod the original panel
    The intention is that there is a window in the same shape as the original
    Tape on both sides .....
    Draw some lines
    And after some cutting and filing:
    Tape off and he's done.
    Now it is obviously not good to have a green window. Windows should be transparent, no color allowed. Therefore I used the green plate and did some more cutting
    First, mark and drill holes in the corners for the jigsaw
    And again some sawing
    First I placed and fixed with bolts to put everything in place
    After that I had a mold for the transparent acryl.
    And the result
    And put everything in place. All that work for a green edge, lol
    But I like it
    And the window just transparent
    Total shot...........you like?
    Next update, I’m gonna let you see the loop of the water cooling ;)
    See you then, I hope
    Grtzzz.
  10. -Jv-
    -Jv- What's a Dremel?
    29 Mar 2011
    It's simple but it looks great ! Great job on the window too, I would've solved it the same way :D
  11. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    This looks awesome man!!
    Subbed!!
  12. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Awesomez! :D
  13. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Nanoxia uv green fan was perfect choice :D
  14. stuartwood89
    20 Aug 2008
    I was planning on making my own 360 case, but this look so much better. I love the green UV accents. I thought I grew out of UV, but it's so nicely done here. Well done!
  15. kier
    1 Mar 2011
    Update 30-05
    Here we go again....update time
    Had the tray of the Xbox board disassembled and painted it black
    This is better than the aluminum look.
    Exchanged the original rivets for black ones
    scotch tape on it from damage the paint
    Nice flat and black
    Also did some brainstorming for the window and got some nice ideas presented. I am going to try engraving this time.
    So after some practice and see some movies
    For the lines I use a diamond point bit
    And for coloring / Shadow effect I used a diamond tip
    First some practice on a scrap piece and then ............. the real work
    with a steady hand you'll do quite well. The first angle
    In the dark, and an LED strip behind
    And yesterday, the second part done. Pretty funny this engraving ;)
    And that was the update for now......you like it? I know I did
    Grtzzz.
  16. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    its an xbox .. but dam its a very predddy xbox now: Congrats
  17. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    man this work log is evil
    evil i say
    now i want to stuff a 360 in my stalled project
    wonderful
  18. mnpctech
    21 Apr 2003
    The etching is perfect, nice work kier :thumb:
  19. kier
    1 Mar 2011
    Update 02-06
    Today did the final touches to the engraving. Like this engraving thing
    we gonna do this often ;)
    The black painted parts are also placed back
    And I was brainstorming for the watercooled components. Pump and the 250mm Reservoir
    The EK Supreme's with BP fittings
    Reservoir next to it
    We fill under the xbox drive. This gonna make a plate with a hole for reinforcement
    He goes from the pump in to the first block
    And from the second block he goes into the radiator, and from the radiator back to the reservoir.
    And two last pictures of the hardware with window
    This is it!!!
    Grtzzz.
  20. mark1903
    mark1903 Minimodder
    27 May 2011
    The etching on the window looks amazing!!!
    +1 rep
