Windows Project XP
Discussion in 'Software' started by 123, 26 Apr 2003.
  1. 123
    123 Makes No Sense
    20 Apr 2003
    scoob8000?
    scoob8000, thats nothing compared to my AMD K7T Pro @ 700MHz!
  2. FNG
    FNG Minimodder & sig shrinking victim
    19 Apr 2003
    Well actually.
    I dont know what i could do with xp as explorer.exe alone seems to need 4times the amount of memory as a win2k machine. I have on the other hand used windows 98 on a 486 DX2 (66mhz) and it ran fine although i actually did have 32megs of RAM. your best bet 123 is to try win98 and find yourself a few more megs of memory. You could also go for a unix type OS. perhaps freeBSD or linux (redhat or mandrake).
  3. 123
    123 Makes No Sense
    20 Apr 2003
    FNG, Thanks!
    I an downloading Red Hat, but I am keeping the setup the same.
  4. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    redhat won,t work since 7.2 needs at least 32mb of ram and 6.1 needs 16mb...
    maybe if you put an old linux distribution...
    win 98 needs 16mb of ram too
    you ain't gonna get far with 8mb of ram... sorry
    BUT win95 needs 8mb so I think it's about the only one you can put on that mummy :D
  5. Nexxo
    23 Oct 2001
    Dude, I got W95 on a PII 266 with 64Mb RAM and it just gets by. On 8Mb? Make yourself a cup of tea everytime you click a program icon... :p It works, but it works s l o w l y ...
  6. Tribal Dragon
    17 May 2002
    yep!
    I think that win 3.1 would be better ...
    or just use the old msdos
  7. FNG
    19 Apr 2003
    123 try to get more ram
    With so little ram you'll also cause excessive swapping killing your computers usefulness and wearing out your harddrive. I strongly recomend finding more memory to use on that machine. the more the better. Each application you use eats memory and with out more ram you will use swap space on your HD.
  8. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Your only chance of running anything short of DOS, is an LFS system, even then, you'll not get a GUI, as that requires to much. I believe teh smallest LFS made was about 85 MB, and ran off 12 MB of RAM. Which means with a bit more stripping, and more swapping you might jsut pull it off.
    Otherwise, just dump that computer in a river somewhere.
  9. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    Its been said before, Win 95 will fit and run ok, win 98lite will go too, but anything over windows 98 is a pipe dream, especially with the ram. The windows XP installer will reject the computer because it is lower than a 266 MHz proc, and wine ME will do the same because it is lower then a 150 MHz proc, you could however install it on the Hard disk from a faster computer, then try to boot into it fromnt he P 75 machine, it might just work. albeit slow, realllyyy freakin slow.
    IMHO you can run win 95 on a 386 with 4 Megs, just, were talkin 5 minutes to boot through to the windows startup screen type slow.
  10. ReverendFränz
    ReverendFränz What's a Dremel?
    29 Apr 2003
    As a semi experience multi os hacker, i would like to put a small amount of fresh air into this topic by making the outrageous claim that it might be possible.
    as far as not being able to fit anything but dos on, thats utter malarkey, any number of scalable solutions exist. slightly older versions of FreeBSD, are of course what i would use, but thats just my Daemon lovin leaking out. there are several possible linux configurations for smaller architectures as well as a number of propreitary embedded type os's. As far as XP pro goes, that is in fact impossible.. however, microsoft does provide another solution; XP-Embedded. It uses the same binaries as xp pro, but in a compleatly modular format. this allows you to select what you want to install and what you dont.... I have successfully configured and installed images ranging from 80-170 mb, with the kernel, hardware support, Direct x 8 (over half of that is DirectX, i think) and a few custom apps. And the xp kernel is much much larger than any compareable unix kernel for embedded systems...
    just my two cents
  11. v3rt
    v3rt What's a Dremel?
    20 Apr 2003
    98 'chugged' on my 133, 1.5gb HDD, so good luck...
    [^_^ // Dan]
  12. herbs
    herbs Nobody but us chickens
    7 May 2001
    Lets be truthful this is either a joke or a noobie, in that case *nix os'es will be way beyond him/her. The only real choices will be older windows or dos or OS/2 operating systems, but s/he hasn't said what s/he wants to use it for, then someone can recommend what s/he should plump for.
  13. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    v3rt, hush i put up with 98 on that same 486-100 for close to two years.. then i bought a "300mhz" (note the quotes) cyrix m2 processor.. thought that was "fast".. lol
    123, if you are serious, what is the point of doing this? to crunch seti? you wont have any cpu cycles left.. lol
    -scoob8000
  14. [UHL]Tank
    [UHL]Tank What's a Dremel?
    22 Oct 2002
    lol
    i have successfully installed and run Windows XP Pro on a 133mhz P1 with 32mbs of ram. don't tell me i can't do something, cause ill find a way to do it just to prove you wrong.
  15. herbs
    7 May 2001
    Re: lol
    I bet that was an enjoyable experience running that system.
  16. Nigel
    Nigel What's a Dremel?
    7 Mar 2003
    For my two-penny-worth....
    If you just like the Win 95/98/ME/XP look, then why not install Windows 3.1 with the Calmira shell? Great utility that in it's present form makes a dashed good facsimile of Win 98 etc. The system resources are therefore low too.
    Also there is a whole web-site dedicated to getting Win 3.1 onto a single flopsome (and also minimising Win 32-bit O/S installs). Rats! I can't find the link for you!! Thought it was in my favourites. But it was certainly live a couple of weeks ago. Try Google. I'll post it if I find it again. Mutter... mutter... mutter...
  17. Vikram
    Vikram Banned
    7 Oct 2002
    Re: Project XP Home Page
    Stupid site tries to make you install Gator spyware components ....... Beware
  18. 123
    123 Makes No Sense
    20 Apr 2003
    Get Popup Manager!
    I tried to go there, and it stoped the gater crap from comming up, witch this is the fist time it worked! To get Popup Manager, Click here. , and then install it and upgrade it to the latest vertion, then, go to: http://www.4x4vodofx.bravepages.com/index.html and it should disapear. NOTE: PLEASE GO TO THE POPUP MANAGER OPTONS AND TURN THE ":) "OPTON OFF. (IT CAN BE VERY ANNOYING.)
    __________________________________________________123
  19. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I think its time you crack open the many 3.1 disketts and start inserting as this is the only OS that will work :D I mihgt have a copy somewhere :D
  20. I Got windows me on a 486 with 8 megs of ram before just make sure you type setup.exe /nm then it ignores the systems speed but im not sure about winxp
