Got some smooth Alu stuff here as I said mate...Will give you it tomorrow....only if ya bring in those 4 switches I need though
They sure do m8, bought it ages ago, well I bought a GF3 Ti200 but if borked and when I took it back to the shop they had ran out of stock, so they gave me the Ti4200 Special Edition. Got it running at around 325/620
wow that looks uber sexy i have the same watercooling kit as you and i hope mine performs as well! few questions though.. where did you get the gpu block on its own? Also, im a newbie to watercooling so when you change your water every few months or so, how would you go about doing that? Just take out one of the hoses and let the water run out?
You can get the GPU block from www.overclockers.co.uk Ive already drained it a couple of times, getting it up and running, all I did was remove the tube going into the res, hold a basin under and start the pump.
The silence is deafening. The silence is deafening. I have now attached the two rear fans, the PSU fan and the radiator fan to the rheobus, all now running at around 7V. The pump is sitting on some foam padding and the hard drive is sandwiched between plenty of foam padding. Temps are around 31ºc - 33ºc Idle and 33ºc - 36ºc Load Now for the first time ever I can hear my HDD which I previously thought was silent, I can hear the platter spinning, when I say hear its almost inaudible, but how to get it even quieter? Water-cooling is the dogs
