Project YBQ yellow and black Qtec
Discussion in 'Project Logs' started by Balder, 29 Sep 2003.
  1. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    Ok, so I got inspired by browsing this forum.....
    And i want to do something to my rig :rolleyes:
    This is the victim, a cheap plain beige QTEC.....
    This is what i will do:
    Paint it yellow, make a new bezel, paint that one black...
    It will have a window, som lighting (yellow), and maybe one of those bulgin switches....
    More pics to come
    Balder
  2. penski
    penski BodMod
    29 Aug 2002
    Moving to modding just now.
    I'll move it back when you're up and running and have in progress pictures :)
    *n
    PS: the pic doesn't work.
  3. Balder
    4 Jul 2003
    :thumb:
    My host seems unstable, I see the picture now, but it will be moved to a new host soon...
    Balder
  4. penski
    penski BodMod
    29 Aug 2002
    Works now, thanks :)
    *n
  5. pranks7er
    pranks7er mange tout
    25 Dec 2002
    Visit bards project in the project log he modded a Qtec
  6. Balder
    4 Jul 2003
    Jupp I have seen it, I have been reading the forums for over a year :rolleyes: but never posted :hehe:
    Balder
  7. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    It's so cool seeing that more people are modding q-tecs. Snitch is working on one the same size as mine, and yours is just like mine to, only a bit lower. I am looking forward to see what it will look like.
    You mention that you might get a bulgin switch for it. Have you considered doing like I did? I wanted a bulgin switch, but I though the price was a bit steep (140kr or something), so I made one. I even made a Mod guide to how I did it. In the mod guide I used a chieftec bezel, so you could basically just copy what I did. And you could light it with a yellow or orange LED. Maybe having it flash green on HDD activity. (you can't get those bulgins to flash on HDD activity ;))
    Anyway, you have my MSN, so just contact me if you have a question.
  8. Balder
    4 Jul 2003
    Yeah i lookd at your at youres, might use it...
    Flashing yellow/white maybee? :rolleyes:
    Or i might be lazy and buy a bulgin switch :worried:
  9. Balder
    4 Jul 2003
    Update
    Sooo, here are some pics fresh from my digicam....
    The pooor naked thinghy:
    And a litle peak of the "new" beazel....
    the side pannels:
    The top is still drying....
    so now i need to clean up the inside and work on the front..
    \\Balder
  10. bard
    8 Mar 2003
    Cool, yellow! Have you cut anything off the bezel, or have you just unclipped the separate parts? (when you clip them back on you will create scratches in the paint job, so don't disassemble the bezel for painting... What is the window supposed to look like?
    If I were a mod, I would have moved this thread right back to project logs, where it belongs now. Cough, penski!
  11. pranks7er
    25 Dec 2002
    it will soon be i project log im sure -
    [cough] move it back to Logs [/cough]
  12. Balder
    4 Jul 2003
    Bard, yeah cut, you can see the tape (brownstuff) holding the plexi pice ;)
    The window is a B, well was suppose to be a b :blush:
    Do you know where i can get som big pices of plexi in Norway?
    Pranks7er: Yeah hopefully.....
  13. bard
    8 Mar 2003
    I don't suppose the B is for bard, is it?
    You can get plexi from any glass supplier. I've bought plexi a couple of times from Tr√łnderGlass. The last time I even got a lot of plexi for free (left-overs). Where do you live in Norway?
  14. Balder
    4 Jul 2003
    Well, might be B for Balder :hehe:
    Or B for my clan name, biZ
    I'm a CS maniac :rolleyes:
    More pics later today, when the panels are mounted on the case!
    Ohh, plexi for free!! sweet! I live near Eidsvoll, but if you could help me with shiping I will pay you in advance...... :D
    Balder
  15. bard
    8 Mar 2003
    I'm sure you could find a glass supplier at Eidsvoll too. They are everywhere. Any store that sells glass also sells plexi.
    If not, contact me and I'll see what I can do. Only problem is that I actually never have time to visit the glass shop, because it is only open during school hours, and not in the weekends...
  16. Balder
    4 Jul 2003
    I'm gonna check out our local glass suplier, but I heard its expensiv :worried:
    And I have to visit a place to buy some tint, maybee a trip to biltema, so i can get some vinyl dye to :naughty:
    Balder
  17. Confusitron
    Confusitron New Member
    22 Dec 2002
    What is with you Scandinavians and Q-Tec cases...?
  18. Balder
    4 Jul 2003
    Hehe, Their cheap and available :rolleyes:
  19. penski
    penski BodMod
    29 Aug 2002
    Moving back to project logs - looks good, keep it going :)
    *n
  20. Balder
    4 Jul 2003
    New stuff added (nothing major)
    Ok...
    So i got my new thumbscrews and the yellow lights...
    by first the case mounted, no beazle, since its in my lab(garage :D )
    Then some of the new black sunbeam thumbscrews:
    And the lighting in the dark, no flash Blurry....
    Thas it for now.....
