Scratch Build – In Progress Project ZOE
Discussion in 'Project Logs' started by Zesti, 31 Oct 2011.
  1. Zesti
    Zesti Aluminium + file
    9 Feb 2010
    Thanks guys. :)
    Glued parts looked good after the night - I'm happy how it worked out. Feels sturdy and looks clean. :thumb:
    Glue itself is meant for house building etc. and can be used with almost any material. I'm not absolutely sure what type of glue it is since 'MS-polymer' says nothing to me. :D
  2. Zesti
    9 Feb 2010
    Got the Antec Kühler today. Looks ok'ish, but it will need some modifications to look better.
    Took a couple of quick photos:
    Soo.. How to modify this? My first idea was to add heatsink over the pump, but it turned out that all the heatsinks I have are too small. So maybe just a simple aluminum part with chamfered edges and a logo?
    A quick render to show what I'm thinking:
  3. Axly
    Axly slo-mo...dder
    7 Nov 2003
    This looks really nice!
    Going back to the beginnning to look this through again. (some excellent photos here too)
  4. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    that will look soo nice :)
  5. Zesti
    9 Feb 2010
    Thanks Axly and KoSoVaR^. :)
    I got another L-profile cut and glued. Also sanded many parts, drilled holes and made a truckload of other thing. And the result of all that work looks just like before. :duh:
    All those small things aim for having shell cut and bent this weekend. It's a major part that has to go right and hence preparing takes quite bit of time. So hopefully everything goes well and the next update is a good one. :)
  6. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Looks really beautiful :).
  7. timmmay
    timmmay What's a Dremel?
    9 Jul 2005
    I hope you noticed that your jigsaw blade was in backwards before you started cutting!:eyebrow:
  8. Liighthead
    Liighthead What's a Dremel?
    26 Nov 2011
    :duh: how is it in backwards? o_O
    btw nice work OP :D
  9. Zesti
    9 Feb 2010
    Umm, it's not backwards.. Look at the teeth.;)
  10. timmmay
    9 Jul 2005
    Oops! My bad! :blush: I'm used to the notch going inside the saw. (I looked up Bosch saw blades and saw that these are different than I'm used to.)
    Consider my statement withdrawn.
  11. digitalerr0r
    digitalerr0r What's a Dremel?
    30 Nov 2011
    keeping an eye on this one looking good (=
  12. Zesti
    9 Feb 2010
    I used most of the day bending the aluminum shell. It was way harder than I never imagined. :duh: I started with one meter long and 178mm wide strip.. Which I accidentally cut to 179mm and I had to sand one millimeter away. What a boring job. Then I started to bend it and it took forever to get right. In fact first bend was 5mm in wrong place and I had to move the bend those five millimeters. Second bend was a bit easier, but it was still darn difficult. I almost gave up couple times when every bending and fitting seemed to go to wrong direction. But in the end it came out very well - I'm happy.
    Oh, and for bending the shell I had amazing tools: leather gloves and spray cans which had the right radius. :hehe:
    So much scratches.. :blush: But worry not, everything's going to be sanded lightly before painting. Those are also reason why I wanted to keep the protective plastic on the shell. ;)
    In the next picture one screw is missing.. It was loose and dropped into the snow. Couldn't find it anymore. :D
  13. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    a thing dreams are made of!
    weather looks great as well ;)
  14. KoSoVaR^
    19 Dec 2010
    is this reality ? I dont think so :D!
    Damn that looks hot!
  15. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Looks incredible ! ! !
  16. alain-s
    alain-s Minimodder
    12 Jan 2011
    Lovely Zesti the bend looks perfect :D
  17. Yariko
    Yariko What's a Dremel?
    26 Jul 2010
    Now you have to wait for the spring so you can find the screw and finish the project :( :lol:
    Awesome work with the bending :)
  18. Zesti
    9 Feb 2010
    Thanks guys! :thumb:
    Logically next step would be continuing with the chassis, but there's more complicated parts ahead. Not as bad as bending the shell, but I felt it was time to do something smaller and easier. :D
    Soo, you remember the render about cooler top? Well, I made the logo for it:
    Not bad for a first try.. :) And now that I look at it, I might do another one for the front panel.
  19. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Lovely work so far, I like your style!
  20. KoSoVaR^
    19 Dec 2010
    thats just badass, simple and clean !
