Scratch Build – In Progress Project : Zotac ITX Rebox -12th Feb - Completed - MOTM nominee
Discussion in 'Project Logs' started by bugeye, 8 Nov 2011.
  1. bugeye
    bugeye Sleep Deprived
    16 Aug 2011
    Thanks guys :)
    Quick mock up of the vent .
    I'm going to send the drawings to the laser cutters this afternoon :) So I'll know soon if making a few of these is feasible .
  2. fractal arc modder
    fractal arc modder What's a Dremel?
    12 Aug 2011
    Your work is excellent mate very good job.
  3. narcotic
    narcotic What's a Dremel?
    15 Dec 2011
    These are looking great, just wondered who does your laser cutting?
  4. bugeye
    16 Aug 2011
    :) No one as yet I'm just getting prices for the cutting . These are all cut by me .
  5. Jipa
    5 Feb 2004
    Huge kudos for the patience with all those jigs, mock-ups and testing! I know just how huge a pain in the arse it can be to try to get accurate bends on acryl, and you've really nailed it!
    Keep up the good work.
  6. OmightyOne
    OmightyOne Minimodder
    7 Nov 2011
    love the colour scheme so far. keep it up!
  7. narcotic
    15 Dec 2011
    are they cut by hand?
  8. bugeye
    16 Aug 2011
    Thanks :) TBH that's been the interesting bit the case is really basic the challenge has been figuring out how to make it in the simplest way . The strip heater and the jigs make the bending pretty much fool proof .
    Thanks , I'm not sure I'm going to use the purple though . It's semi translucent which means you can see the shadow of the internal part of the case .
    Combination of by hand and using a router with a straight edge , like this ......
  9. bugeye
    16 Aug 2011
    Little mini update . I've got my first set of parts back from the laser cutters . I'm very pleased with them :D Unfortunately I'm not going to have time to much with them for a bit but it's one step closer ;)
    Front and back .
    Base .
    Cover .
  10. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Look'n good bugeye!
  11. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    looking nice - subbed
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    I'd purchase one for sure from ebay for sure. What internal options are you proposing for holding drives etc
  13. bugeye
    16 Aug 2011
    Thanks guys :)
    There is room under the mobo for a couple of 2.5" drives , you can see the mounting holes in the picture of the base . You can also fit a third drive to the inside of the vertical part of the base , you would have to use velcro or similar as the mounting screws would interfere with the cover .
    So room for 3TB :)
    It will also take a 50mm low profile fan if needed .
  14. narcotic
    15 Dec 2011
    can you tell me where you got the corner bit for this case please?
  15. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Sweet little case! and that diy strip heater is great, need to make one my self :thumb:
  16. Brightham
    Brightham What's a Dremel?
    26 Dec 2010
    I`d uy one of Ebay to , if they come on sale there :)
  17. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Looking good man ! Got myself a nice little heater also, just started playing with it.
    Soo cool, really addictive once you get the hang of it.
    I had the bulging out issue also (sorry for the flashback) I actually had it when underheating the plexi also. The outer parts would cool off to quickly making the bend harder while the inside was still warm enough and bends easily. Teh dif between the 2 made the plexi bulge out I think.
    Anyway subbed and looking forward to your further work !
  18. bugeye
    16 Aug 2011
    They came from a perspex case that I got from ebay . I haven't managed to find any from another source , in fact I'm not 100% on what they are called :( I can find similar things but for making flight cases etc so much to big . If you every find any let me know :)
    Thanks :) Strip heater is well worth the effort .
    Or just pm me on here :)
    I think getting the temp right helps a lot but what makes the biggest difference is using thinner acrylic .... you can hardly see it on the 2mm .
    Update wise .... I have been making progress just not much to show . I've been tweeking the laser cut version sizing and sorting out the hardware like switches , cables and fans ......
    Hoping to have the final prototype finished with everything installed pretty soon :)
  19. bugeye
    16 Aug 2011
    So I've finished the prototype :) and the first batch of acrylic is at the cutters should have them back at the end of this week and I can start making some of these .
    I'll take some better pictures soon but until then ......
    I left the I/O plate at home so that's why it's missing :)
  20. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    How in the world did you get such perfect bends??
