projekt : ..:: ALPHA Orange::.. re-start soon :D
Discussion in 'Project Logs' started by alonso_bistro, 15 May 2004.
  1. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    Great! love the fangrill you've got there pal! keep up the good work :D
  2. ATi Loyalist
    ATi Loyalist Who throws a shoe?!
    9 Nov 2003
    Hello Alonso, nice to see you here too!
    i love your work, keep it up, its absolutely amazing! :rock:
  3. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    thanks friends
    ATI , that's the magic of internet ;)
  4. BadKarma
    BadKarma What's a Dremel?
    4 Feb 2004
    your doing a great gob with that dremmel man. i like the way u used the mesh in that side pannel :thumb:
  5. daydreamingknight
    daydreamingknight What's a Dremel?
    9 Jun 2002
    I love the look you're going with, nice dremel skills too!!
    Very nice work!
    DDK
  6. TomboyMS
    TomboyMS What's a Dremel?
    6 May 2004
    You do quality work and your designs are unique as well. Very nice. :thumb: :thumb:
  7. alonso_bistro
    19 Feb 2004
    Next step is the work on the other side..
    Started with the draw of a new cut - on an old door case -
    The result:
    The cut on the door:
    With the 'inevitable' mesh :)
    and.......... :worried:
    believe me or not , i made the cut in the wrong side !!!!!!!! :duh:
    2 solutions
    - finding a new door :worried:
    - making another cut in the good side :dremel:
    i decided to go with the second :)
    something like that:
    after a new black paint....
    and a P1200 sanding :thumb:
  8. H2O-G33K
    H2O-G33K What's a Dremel?
    25 Jan 2003
    Nice recovery! That actually looks really nice - good job :) The other side lookes great with the mesh / chromed / black look.. keep it it!
    :clap: :D :clap:
    The only thing I'm not to sure about is it kinda looks like the silver surround of the 'Alpha' worded doesn't match the hole cut in the case side.. ? I think if I were you I'd open up the hole a little more.
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    agreed - but couldn't you just put that panel on the other side of the case?
    Really like your Hole+Mesh work.
  10. Cannon^Fodder
    Cannon^Fodder What's a Dremel?
    13 Feb 2004
    :eek:! nice moddin dude
    i just looked at this and was like OMG! my case is gonna end up looking very similar. I've been planning a case for a while now, involving sanding down the case to its steel, using mesh + a radiation fan grill :hehe:
    Well i won't let this stop me, i'll just see how i can make it differ to this :)
    keep up the wicked work :D
  11. alonso_bistro
    19 Feb 2004
    Yes the door is not finish - i agree with u for the hole size - i'll rectify it for the next update
    the other side is already in use by my little meshy dude :D
  12. alonso_bistro
    19 Feb 2004
    hi :D
    This afternoon i worked on my musketeer - the original was too matt !! - and worked too on a (maybe) new side grill
    after black paint and gloss paint.
    much better !!
    New side grill:
    cut of a ring in the rest of the cut of the front 120 blowhole (clear ??).
    black paint on the screws.
    the ring on the case.
    over the ring a classiq grill black painted.
    salvage of an old FM radio grill :D
    final :)
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    good point!
    The new work looks great - nice fanguard!
  14. Goblin Tinkerer
    Goblin Tinkerer What's a Dremel?
    24 May 2004
    What are your plans for the mistake hole?
  15. alonso_bistro
    19 Feb 2004
    for the moment .....no plans . I've added a black painted mesh, and i 'll add some plexi. - maybe another cut ... i really don't know :)
    add 3 pics with a test red lighted fan
  16. PsychoI3oy
    PsychoI3oy Minimodder
    13 Apr 2004
    now why didn't I ever think of using a speaker grille over a fan? :duh:
    looks awesome, though the normal wiregrille in there with the outer ring of the other grille and the speaker grille looks a little overkill. maybe try it with just the ring and the speaker grille?
    then again, who am I to give advice to someone that so obviously knows what they're doing.
    keep up the good work man, this is gonna look awesome (assuming you use the same tools and imagination that went into The O) :rock:
  17. alonso_bistro
    19 Feb 2004
    update , i worked on the front :
    1 flaming (I can't resist :D )
    1 cut to insert the card reader.
    An Orange paint -
    The LCD is my old 2 lines green :( , i'm waiting for the money to buy a cool blue one ;)
    a little halloween look :D
    In the future I'll paint the card reader , add light to the front plexi.......etc etc.
    for the color - nothing decided yet
    and ideas for the top.....
    sorry for the peoples who hate ORANGE :D
  18. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    I f00cking love it !!, i think it looks amazing, I realy like what you have done =] :blush:
  19. Shinymod
    Shinymod What's a Dremel?
    20 Dec 2003
    nicely done mate!! i have a beantech igloo 3, it's pretty similar (in stock form anyway!!) i love the big intake, and the shinyness (of course :hehe:).
    nice recovery from the upside down cut.. you wouldnt believe the number of times i've cut things backwards only to transform them into something better :D
  20. naelq
    naelq What's a Dremel?
    14 Oct 2003
    good work! :clap: :clap:
