Wow mate, looks nice. You inspired me a lot. Maybe I'll use some of your ideas, if it's okay with you I'm not going to clone your case
Awsome i mean completly that is what i call a case everything jsut fits together perfectly. That is funny that you used a washer machine(or dryer) to make that side panel thing. How did you cut that your fan grills did you use a dremel if you did that is completely awsome i mean completely.
How about Delvie's Plastics Inc. ... http://www.delviesplastics.com/fluorescent sheets.htm Alonso ... You are an Artist in every sense of the word ! Continue to astound and amaze us, my friend DB
Alonso, you said somewhere about this 'famous mesh'... Where did you get it? Because I have been planning a from-scratch case that's mostly mesh, but I have no idea where to get it. I was actually considering getting a paper-rack thingummy from Ikea and cannibalising it for mesh. So unless you can help me, I think I'll do that soon. Cheers, --M.V P.S. you're mods are soooo $&%^ing nice!.. /me attempts to steal Alonso's l337 skills
that is just some amazing and creative work. i really like the cd and dvd drives and the fan mod. i can't wait to see more work, keep on moddin'!
now i understand how he comes up with these amazing idea he's on cocain!! i dont know ne other reson people grow out there pinky nail other then to dip into the powder
thanks all ... thanks DB @infered101 : all cuts are dremel's made @munkeevegetable : I've bought the mesh here in Paris in a store call "castorama" ......you're at the antipode maybe u can't find what u search at mnpctech.com. @invader crack : I prefer things more smooth......open mind too
nice i really like how everything turned out for you and the orange on black looks really good with the blue lighting going on
This time I've worked on the LCD positionning , it's a crystalfonts 4 lines , blue. mounted it on the "roof" of the musketeer. in the background u can see my BPSF (Black painting screw factory) :-D I added 2 plexi sheets (looks like the opticals drives) and 4 blues leds (2 up plexi + 2 down plexi) I added 2 switch open/close for the cdrw and dvdrw (they are mounted on screws - i'll be back on this part next update cause i need to finish 1 or 2 things before) New front plexi, here is the musketeer inside ceiling... a little mess Then i mounted 2 leds support for cdrw and dvdrw activity and a switch for LCD on/off. some night view with a cool lighting cya all
Holy mother of butt-crap, freeking awesome work dude. FREEKING awesome. You should win the noble peace prize or an emmy or something for your case mod.
Dude your skills are freaking amazing, awesome plexy work. I'm in the process of putting together an all plexy case but not experience with plexy at all. What kind of tools are you using to cut your plexy, I love the flame over the name idea. thinking of using a layered plexy on mine for a similar affect. Your pc is a work of art, as usual you ROCK
thanks for the plexi cuts i use a dremel with regular disk, then i use a small file (hope that's the good word) and then i sand with 600 to 1200 sand-paper.
Harley Davison of PCs hes got dremeling skills hes got soldering skills hes got sanding skills . . . and hes got creativity damn, this guy has been gifted !!!
