Projekt: Ceramic 30July2006
Discussion in 'Project Logs' started by Vito Corleone, 30 Jul 2006.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Yeah, having 3 identical pumps in-line won't increase the flowrate very much, but it WILL increase the headrate.
  2. Vito Corleone
    Vito Corleone What's a Dremel?
    10 Oct 2005
    @Klikka_bZerk
    as i wrote it will take a while
    i still need some parts, some for the pumps some to get a good lightning
    if all is finished ill test the res :)
    @scifi3018
    if the three pumps are not identical the difference will be so unimportant that you would not see it
    i understand your apprehension but i dont think so
    but you cant get pumps in parallel and the res in series
    two res would be complete full and only one would work right ;)
    parallel is a very bad idea in a watercooling circuit
    water allway flows the way of the slightest resistance
    so there might be some parts in a water circuit where the water has a good flow and some have no ;)
    (very challenging to explain with my english...)
    ill try and well see ;)
    @hydro_electric_655
    there is no problem
    at 80°c there will be no form of warping
    the temperatures are much higher ;)
    Vito Corleone :)
  3. accro
    accro What's a Dremel?
    21 Aug 2005
    Is that plexi UV-orange? What's up with that heating in oven?
  4. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    He explained it some post ago. Is to preparing the plexy for glueing.
  5. Samurai75007
    Samurai75007 What's a Dremel?
    27 Oct 2004
    Cool lookin.
  6. accro
    21 Aug 2005
    Oh, thanks.
  7. Gambler
    Gambler What's a Dremel?
    16 Jun 2006
    Hey quick question...where in all hell did you get that hacksaw mount? I have been looking for one for the past two years!!
  8. boardsportsrule
    boardsportsrule What's a Dremel?
    9 May 2004
    So I am working with plexi glass alot with my current case. I am curious as to why you temper the plexiglass? after it cools does it cut better? thanks :)
  9. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    Please read the thred before asking questions that alread have been asked in duplicate :)
  10. boardsportsrule
    9 May 2004
    yes, i read the thread, thank you. he says it is for cracks, so they do not occur, so i am asking for clarifacation as to if tempering it will make it less susceptable to cracks, easier to glue, both, or even flame polish the edges some??? i looked on the web for more info but it doesnt appear to be a common thing so i am wondering what his reasons are. thanks :)
  11. hujambo_Bwana
    hujambo_Bwana What's a Dremel?
    2 Aug 2006
    Drilling plexy
    Vito
    Have you any plexy drilling/tapping experiance? Just asking because thats going to be a major part of my next mod.
  12. Vito Corleone
    10 Oct 2005
    @BlaZ3R
    yes its uv-plexi orange
    @Gambler
    i bought it in a normal home improvement store in germany
    @scifi3018
    thanks :D ;)
    @boardsportsrule
    the tempering is just to avoid cracks while glue (acrifix 192 from röhm) is hardening
    its just to avoid them, not more
    the edges are polishes by hand not by flames
    i thing it looks much better than a flame polishing
    @hujambo_Bwana
    i think i learned a lot by just trying
    if you have some questions, just send me a pm
    if i can, ill help
    Vito Corleone :)
  13. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    There is some serious kick-ass goin on in this thread! :rock: :rock:
