Projekt: Custom Wooden "Snedker" Computer: Updated:23/11/2005 (56k Warning)
Discussion in 'Project Logs' started by Mr. Hugi, 10 Sep 2005.
  1. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    very nice work. Sorry to hear about the breaking of the panel, good that it came out okay with the glue.
  2. Goth
    Goth What's a Dremel?
    17 Oct 2004
    Hugi, where did u buy ur parts ? soon gonna make an mod too, so i have to buy the parts already
  3. Mr. Hugi
    Mr. Hugi What's a Dremel?
    10 Sep 2005
    by parts you mean hardware right? almost all the hardware i have, i ordered on danish websites from all around denmark... I dont know if it is an avantage to order hardware from denmark when you are living in estonia... but anyway the main site is www.edbpriser.dk, here you can find anything related to computers. and it also help you find the cheapest solutions and tells you whitch hardware to order form the different sites.
    have fun!
    P.S new pics soon!
  4. Mr. Hugi
    10 Sep 2005
    Another update
    ok guys, heres another update. more work done, and the case is actually readt for assembly!!!
    the front with the fancontroller mounted. i also made the button for der dvd-drive
    made the power button in the front, looks kind of nice
    just anoter pic close up
    mounted the psu on the backpanel
    my fillport...
    drilled the hole for it and mounted it as well
    two wentgrills i bought
    the wentgrills will be mounted on the side panels, one one each panel.
    placing the grill
    marked the grill and where to cut
    done
    the wentgrill mounted, looks pretty good
    the two side panels w. the grills mounted
    a little piece of plexi to hold the side panel in place
    another pic from the backside
    thats it for today, finally this modd is almost finished, well all the hard work is done. only the assembly left and some sanding, and some last finishing touches.
    see you next time. bye!
  5. Mr. Hugi
    10 Sep 2005
    weeeee.. another UPDATE this mod is flying! :rock:
    ok, i stated assembling the case yestoday...
    heres all the parts
    assembeld the backpanel and bottom
    the frontpanel in place
    top in place
    putting some pressure on the dovetails with a clamp or two
    hammered the sidepiece in place
    a LOT of clamps!! :eeek: just making shure the dovetails are tight and nice
    anoter pic of the same...
    clamps removed, looks nice so far
    pic from the other side
    with the sidepanels on
    the other side
    after 1 HOUR OF SANDING it looked like this
    closeup of the joint
    overall wiew of the case after sanding
    ok, the end of this mod in within reach. only need to give the case some varnish and some final details and some more sanding and some more varnish... :sigh:
    c ya´ ( thanks to jazzle for the small correction)
  6. Mr. Hugi
    10 Sep 2005
    no comments at all? :eyebrow:
  7. s29feb
    s29feb What's a Dremel?
    29 Oct 2005
    Have I got a wood for wood?
    mmmmm think I have!
  8. Lemmingzappa
    Lemmingzappa What's a Dremel?
    8 Nov 2004
    nice work
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    looks very good.
    But one comment - you have a mixture of very smooth round corners and very sharp corners which seems a little odd. (sorry I didn't spot this earlier!)
  10. Son1990
    Son1990 What's a Dremel?
    4 Nov 2005
    Love what you did!
    I think you should have made holes for the fan contoller knobs but either way, this is awsome! Im really digging the rounded corners as is everyone ealse.
  11. jokkos
    10 May 2005
    looking vvery good.
    I think the mix of rounded and sharp corners is nice, adds some variety.
  12. Goth
    17 Oct 2004
    ÜBER NICEE MOD ! luv this mod, i love cases that are made of natural materials ... very nice work . keep it going, u have a natural talent !
  13. B.Psycho8
    B.Psycho8 What's a Dremel?
    8 Aug 2004
    looks awsome, cant wait to see the end :D
  14. MiLwOrkZ
    MiLwOrkZ What's a Dremel?
    6 Feb 2005
    OMG Looks so SWEET.... I really wish you would have used a wood with more integrity though! But i know you used it due to your abundance of it you love of it and the ease of working with it! Keep up the great work bud!
  15. Mr. Hugi
    10 Sep 2005
    ehmm... a quick question... does it make any difference if i put my grafik card in slot 2 on my mobo or does it have to run in slot 1? its just because that if i run it in slot 1 the mobo waterblock is in the way for the gpu, and the other way around... :duh:
  16. Goth
    17 Oct 2004
    Hugi, do u have 2xPCI-E slots `? if u have then u can put it in slot 2
  17. Gaoske
    Gaoske What's a Dremel?
    10 May 2005
    :clap: Respect to a craftsman :clap:
    My former employe had I wood-department behind his shop. I sometimes had to make something for custommers over therer. I know how hard it is to make some "real" wood (not MDF or something) to fit exactly the way you want.
    Therefore my respect is even bigger for this result!!! :hip:
  18. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    Found this by googling a Dangerden block ^_^ and I saw there weren't any updates..
    So... what happened to this mod? :sigh:
  19. Mr. Hugi
    10 Sep 2005
    actually the mod is fininshed and working...(writing from it right now) just forgot to upload some pics from the finished projekt (thanks for reminding me). so here is finally the finished projekt:
    the case in normal light and setup
    my new fangrill. i wasnt quite satisfied with the old one so i made a new one, also in pine as the rest of the case
    a look at the side-window
    w.o. the side panel on
    closer look at the mobo and gpu
    my hidden dvd drive out
    the case in darkness
    another one of the side
    my "small" subwoofer. CERWIN VEGA :rock: !!!
    the whole setup as it is now
    ok folks, thats it. that was the final update (for now..) hope u enjoyed it. see u for my next "for fun" mod in the future. i think i will call it the CONCRETE computer!!!
    bye!! :lol:
  20. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Nice finish to a nice case. I love the blue color of your water looks awesome.
