Case Mod - In Progress [Projekt] The modding.fr 's Rogue - 14-07-08 "The yellow update"
Discussion in 'Project Logs' started by alonso_bistro, 4 Jun 2008.
  1. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    Hi Bit-tech lovers :)
    Back to modding with a new victim. This time it's a NZXT Rogue, the one I've reviewed a few months ago for NOKYTECH
    Not sure about the final result, like every mods I've done, it's in improvisation mode.
    I would like to thanks sincerly....
    Noky from NOKYTECH.NET
    Joan from CRUCIAL
    Olivier from DOCMICRO.COM
    This Rogue is looking very good :)
    It's made with 3mm aluminium!!
    Déshabillage
    Differents views
    Transformation µATX in ATX
    The µATX mobo tray. I've decided to go with an ATX setup, some modifications needed... :)
    I'll need to enlarge this side...
    and this side too....
    and here too.... :)
    After a dremel cut
    This support come from an old case.
    ok, fit in place perfectly :)
    Then I cuuted the old mobo tray to recover the part where the modo is in place.
    Adjustment of the new part
    This new tray will be positionned on the original one.
    This tray come from an old case
    after a black paint, this is the new extractible ATX mobo tray.
    The front door
    Now we attack the personnalisation of the front door with a MODDING.FR dremel cut :)
    beleive me, 3 mm it's very thick!
    sanded with 400 600 800 1200, I waiting for 1500 and 2000 for a better look.
    ah and for those who don't know her let me introduce you nourchka, nounouche for her friends!
    That all for the moment
    Thanks for reading (and I know how hard it is to read my english....)
    bye
  2. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    A fellow Rogue modder! Nice work man!
  3. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    That front door came out looking great, nice work on the polishing too.
  4. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    hey man nice work on the polishing!
    those rogue cases look to be pretty good to mod.
  5. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    Nice work on the front panel.
    Also nice work on the back end.
    Thats pretty sweet polishing you got going there ..
    Now if my missus could polish that well ... ID BE A HAPPY MAN!
  6. Cheapskate
    13 May 2007
    Are you going to go crazy with it? or will it still look like a rogue when you are finished. -either way I can't wait to see what you do.
  7. Jipa
    5 Feb 2004
    These things have potential (as craigbru has so kindly proven), definitely looking forward on thise one! Nice cuts on such thick material... And a nice little zoo you have there.
  8. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    nice work man :thumb:
  9. Farmboy UK
    Farmboy UK Hungry for knowledge
    19 Apr 2008
    The Rogue seems to be a really nice case. Keep up the good work. Nice dog also!
  10. alonso_bistro
    19 Feb 2004
    @Cheapskate : even if I try to don't go crazy....
    Thanks all, and thanks for my chubaka... :D
  11. jhanlon303
    7 Sep 2006
    Nice case :rock: . and really cute Chewbacca dog too.
    I like both.
    John
  12. alonso_bistro
    19 Feb 2004
    For this update I've worked on both side doors. Same punition 3 mm!! ...
    The shape of the cut is ment to remind the shape of the modding.fr logo :D
    This mesh is for testing only.
    ... and for showing you my cool converses :D
    cya next update :rock:
  13. x06jsp
    2 Apr 2007
    nice :thumb:
  14. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I like it, another Rogue mod...damn I like this case!
    Also, nice dog...
  15. Cheapskate
    13 May 2007
    Sorry! I meant 'crazy' in a good way.:D -like with your fun junk builds.
    Nice vents.
  16. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    nice job man...now i feel like i have to do something to my rogue
  17. alonso_bistro
    19 Feb 2004
    A small update which is not a real one, just a presentation of a part of the setup.
    The mobo is a Foxconn P35A
    The processor is a Q6600 g0
    The ram is Crucial Ballistix Tracer DDR2 8500
    I'm searching for a new video card, if I can't find a new one I'll use my old 8800 GTS :)
    Mobo in da box!
    The ram arrived - Big thanks to Joan from WWW.CRUCIAL.COM
    Another part of the setup arrived too - the Q6600 G0 come from WWW.DOCMICRO.COM
    For the cooling I decided to run with NOCTUA!, I have reviewed the NH-C12P a few days ago for NOKYTECH and I have really enjoyed the test result and the look!.
    The 120 mm from NOCTUA are REALLY quiet and I decided to do a full NOCTUA cooling :D
    (thanks Jakob ;) )
    Let's go with a little cut. We can't speak about "the french touch" without a frog!! here it is.
    This part will go on top of the box, better explanation in the next update.... :D
    cya !!!
  18. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Nice work on the case so far. I have this case brand new on desk side me just waiting to be modded. I think im going to mod it and install a atx setup in it like you. :) just got to get a case for the parts.
  19. jhanlon303
    7 Sep 2006
    Really nice work so far! I like the casework and the frog looks like my blue Azureus PDF.
    I'll be watching this.
    John
  20. The boy 4rm oz
    10 Apr 2008
    Great work so far buddy. Loving the idea of another Rogue mod.
