Projet Sexy Titanium (Lian Li V2100s) 30/04 Contest
Discussion in 'Project Logs' started by rachit, 29 Dec 2004.
  1. rachit
    rachit What's a Dremel?
    5 Jan 2004
    Hello !
    First sorry for my english im not very good, cause im from belgium ! then
    my project Must be smart ! Elegant!
    I choose a big tower the Wonderfull Lian Li V2100s ! A big and Strong tower.. really nice !
    I'm going to put a watercooling in it..
    The configuration:
    -Asus P4B533
    -P4b 2.4ghz d'origine
    -512mo Pc3200 Corsair
    - :idea: 9200se
    -Hdd System western Digital 80go ata
    -Hdd 120go maxtor ata
    -Graveur Dvd Pioneer
    -Alim Hiper Type-R 480w Titanium
    -Lian Li V2100 silver :clap:
    Watercooling:
    -Pompes: 2 * CSP 750
    -Cpu: Block Alphacool Nexxxos Pro fix P4
    -Nothbridge: 1A-NB
    -Carte graphique : non watercooled (because it is too bad)
    -Reservoir Cylindrique 50cm plexi transparent
    -Radiateur Black Ice Pro
    -Tubes 10-8 Transparant Reactif UV - Bleu
    -Embout all plug and cool 10-8
    Then i takes some pics of the lian li.. you can look the quality :eeek:
    Next Pics of the project later :thumb:
    do you like it?
  2. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Can't say that the case is small. Btw, where did you buy it from?
  3. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    nice case :)
    Looking good Keep it coming
    morgan.
    [Edit]
    Are you actually going to incorperate Titanium into the project or is it just a name?
    [/Edit]
  4. rachit
    5 Jan 2004
    I Commanded it In September ! in watercooling.fr i reiceve it Today Morning...
    It is from Asia ! We dont see a lot of 2100 because it is normally only for server and it cost a lot of money :wallbash:
  5. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    :blush: Now that's some sexy titanium indeed!
    Besides the watercooling, are you planning on modding it as well?
  6. rachit
    5 Jan 2004
  7. piloux
    piloux What's a Dremel?
    12 Nov 2003
    Hi Rachit ;)
  8. ReFredzRate
    2 Sep 2002
    Modding does not necessarily mean painting ;) But I love the playstiation LCD idea. I'm still working on a 4x20 LCD, but I think that's already broken :(
  9. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    :eeek: you ordered it in september and it only arrived today?
    that's some unreal wait, can't wait to see this project unfold. where are you planning on mounting the psone screen? this could look really nice if you mod it with a sleek and clean look :D good luck and have fun
  10. rachit
    5 Jan 2004
    i have also a lcd 4*20 bleu on my other mod ! i think i can put one in it..
    but i dont know why i talk about a lcd from a ps0ne because the resolution is too poor.. i bought an very expencive case.. i think i can buy and expencive lcd...
    why not an 14-15" on right of the case... ! but i think i will take a Liliput 7"
    like this http://www.izzotek.com/produits/images/NW619VB1.jpg and put it in the front of the case...
    yeah i waited since september.. i dont know how i can do that!
    about the 2 csp 750 i m going to put in the lian li ! i waited 7 mouth !!!!! that is really impossible..
    :jawdrop:
    hello piloux :hehe:
  11. Isuo
    13 Oct 2004
    Actually it's not. See, my lcd was ready to be fetched yeterday, but I didn't call so now I have to wait a week or so, because the new stuff will normally arrive on mondays, but... THat never actually happened to me, but that is what you will get used to hear if you live in Belgium or Fance.
    EDIT: went to that site rachit pointed on and there was this 170mm fan that needs 26watts (1.1A) and I'm just asking does a normal molex handle this? I remember someone once telling me that molex' can handle up to 10A, but you can never be too sure
  12. rachit
    5 Jan 2004
    hi isuo ! im from belgium
    i dont know why u talk about a 170mm.. on the lian li they have only 120mm !!!
    could you explain.. what you want to say :eyebrow:
  13. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Depends which power supply you're using. PSU's have different amounts of A on each channel (12V/5V/3.3V). A fan like that will draw it's power from the 12V line, i.e. it's the amount of A on the 12V line that determines this. A single fan taking up an immense 26W is quite scary, then again, it is quite big.
    @Richat: Isou's question wasn't directly related to your mod, so don't worry about it :)
  14. Isuo
    13 Oct 2004
    Thanks, but you still think a molex(12v) can handle tthe load?
    And rachit, as azazel already said, I'm not talking about your mod. I'm talking about the 170mm Papst fan here http://www.izzotek.com/ventilateurs.htm
  15. rachit
    5 Jan 2004
    ok isuo sorry
    i didnt understand exactly what u say
    but now i understand !
  16. Isuo
    13 Oct 2004
    No prob. Btw, where do you live rachit? Near Brussels?
  17. rachit
    5 Jan 2004
    not really :)
    im near liege - huy and waremme ! and u?
  18. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    If the molex plug itself will sustain any physical damage? No.
    A molex plug consists of one 12V and 5V line, and two 0 (ground). It draws its power from the power lines I mentioned in my first post. If the PSU deliver 15A on 12V, and component powered by one molex plug draws 15A, there's almost nothing left for other hardware, etc. Bad example, but I hope you get the point.
  19. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Lets see some modding then! This isnt a "hello im from europe too" thread :hehe: :D
  20. nissmo300
    nissmo300 What's a Dremel?
    19 Aug 2004
    updates?
