Scratch Build – In Progress [Projetc] Nautilus - Laying down some carbon...
Discussion in 'Project Logs' started by lenne0815, 4 Jul 2010.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    its gonna be similar to this once i get the shapes done
  2. mav2000
    mav2000 In Training
    16 Oct 2010
    Wow...this is going to be one great mod....keep going.
  3. lenne0815
    4 Jul 2009
    I REALLY TRY :D right now the mdf just lays around in the workshop and silently yells at me: *whisper* "rooooouuuuuutttteeeeeee meeeeeeeeee rooooououuuuuttteeeeee meeeeeee"
    Ah, btw did i mention we now have a plasma cutter and going to hook it up to the cnc soon ???
  4. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
    Bump!
    Any updates on this one?
  5. ArgOs
    ArgOs What's a Dremel?
    15 Jan 2011
    wow!!! updates now is a great project.
  6. lenne0815
    4 Jul 2009
    im sorry, still nothing new here, this will take some time... :(
  7. Cheapskate
    13 May 2007
    Doh!
    Suckered in.
  8. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    I is GULL-IBLE too....dratt.... :D
  9. lenne0815
    4 Jul 2009
    Ok ok... V3 is running, so after figuring out that the 12mm bit holder MIGHT not hit the mold while routing ( im still not exactly sure, gonna be fun to route them... )
    I glued all the parts together:
    Using 10mm drill bits for the reference holes
    to be continued....
  10. LooseNeutral
    13 May 2010
    to be continued.... :clap: Nice to hear from you Lenne! :thumb: Interesting looking mold. what's next ? :dremel:
  11. lenne0815
    4 Jul 2009
    Routing the rough mold, then sanding and laquring it a couple of times to get a nice surface for laminating...
  12. lenne0815
    4 Jul 2009
    Guys, it did actually work :) ******* awesome :D
    This was just the first roughing pass, ill do another finish run on it.
    i took some video footage aswell but i still have to edit and upload it...
  13. lenne0815
    4 Jul 2009
    Finished routing the first mold;
    Clamped the rough mdf block down
    Bracket for reference
    Edge finding
    Finished first roughing pass
    Second fine pass
    Polygons from the drawing, unfortunately when i did the nautilus drawing i still worked with poly meshes and not nurbs surfaces ;)
    And after the last restmill pass
    got new working shoes :D
    Video
  14. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    ( or wood in this case ) :thumb:
  15. Cheapskate
    13 May 2007
    It's a mold. A little mud and sanding will fix the polygons.
    I'm just glad this started.
    Set up another comp nearby so you can model for contest #6 while you babysit.:D
  16. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    The mold looks amazing itself, now put some carbon fiber on that bitch :lol:
  17. lenne0815
    4 Jul 2009
    Its not exactly a david hidden in the mdf... its much better :D
    the bad polys sit in between the top and bottom half of the case covers anyway, ittl be cut away later ;)
    soonish... first: tedious sanding, soaking in epoxy, tedious sanding, fillering ?, tedious sanding, fillering, tedious sanding, laquing with an "indicator" coat, tedious sanding, clearcoat....
    btw guys any ideas for the big "ring" part of the case material wise ? It shall be laquered glossy white when its finished, alu would be to expensive / would take to long to route i think, any ideas ?
  18. confusis
    confusis Kiwi-modder
    5 Jan 2006
    vacuum formed plastic?
  19. lenne0815
    4 Jul 2009
    hmm, i dont think that that would be sturdy enough ?
  20. LooseNeutral
    13 May 2010
    Don't stop now Lenne... "soonish... first: tedious sanding, soaking in epoxy, tedious sanding, fillering ?, tedious sanding, fillering, tedious sanding, laquing with an "indicator" coat, tedious sanding, clearcoat"
    .....you're on a roll! :p :D
