Projets M.P. (pro AMD?)
Discussion in 'Project Logs' started by loki66, 30 Aug 2004.
  1. loki66
    loki66 What's a Dremel?
    30 Aug 2004
    hello. I comes you present my MOD. The projects M.P. Firstly, painting. Airbrush inside
  2. loki66
    30 Aug 2004
    Again..
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    remel:
  3. loki66
    30 Aug 2004
  4. loki66
    30 Aug 2004
    no panic, i have finished :hehe: 4 now... :naughty:
  5. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Wow the paint looks awsome... good job
  6. Slayer the Unholy
    Slayer the Unholy What's a Dremel?
    19 Aug 2004
    I agree that paint job is superb, how about you do one for me :thumb: :sigh: I wish I could paint like that.
  7. r3men4nt
    r3men4nt What's a Dremel?
    12 Nov 2003
    That has to be the craziest paint job ive seen on a case
  8. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    did you use an air brush ?
  9. Silenced`
    Silenced` What's a Dremel?
    28 Aug 2004
    the paint effect look nice :jawdrop: you can even see your reflextion in it :eeek:
  10. AMDRules
    AMDRules What's a Dremel?
    11 Sep 2003
    :jawdrop: Wow !
    That's a great painting you have created....can't wait to see how this project evolves !
    :dremel:
  11. TheSchumi
    TheSchumi What's a Dremel?
    13 Aug 2004
    Woooooow !!!!!!!!1
  12. cerberus
    cerberus What's a Dremel?
    23 Sep 2003
    Simply amazing paint job you got there. Nothing more I can say.
  13. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    wow that paint is absoluty stunning!!!!!!!! and it's the best prosseser company out there, can this get any better!!!!!
  14. Audigy
    Audigy What's a Dremel?
    25 Aug 2004
    nice case.... my guess is that you like AMD more than Intel or am i stupid? :wallbash:
    nice paint its mouth dropping :jawdrop:
  15. loki66
    30 Aug 2004
    Tanks all.
    So, i have the problem. i have de fu***** choice...
    Choice number 1:
    Choice number 2:
    Assembly photoshop
    Help meeee :waah:
    More pics tonight :naughty:
  16. msb
    msb What's a Dremel?
    25 May 2004
    I think those are best of those options, but I don't like about that green ledfan, maybe green uv-fan or something other will be better :)
  17. loki66
    30 Aug 2004
    the two images are not compatible.
    option 1: one only fan on with dimensions
    option 2: 2 fan in top, and 1 on the side panel.
  18. r3men4nt
    12 Nov 2003
    In my honest opinion i have to say go with option #2 it just seems to fit with the rest of your theme better than the dragon would.
  19. Audigy
    25 Aug 2004
    i pic the first one, your great!
  20. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    i would go with choice #2 but liek you said don't use that fan, infact my sugestion is that you should not put any fans IN the AMD logo, i think it would hinder the look
