Cooling Prolimatech multi-compatible GPU Cooler
Discussion in 'Hardware' started by boiled_elephant, 18 May 2010.
  1. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Link.
    Anyone ever used one of these and can account for quality or performance? I'm considering buying one as my HD4870's stock cooler is now struggling to keep things below 50'C on idle, where it used to idle at 40. Besides which, I've heard rumours about how good aftermarket coolers can be and I'm intrigued.
  2. Jipa
    5 Feb 2004
    I have one waiting for its turn, but haven't got around installing it to anything. It sure FEELS good, very solid construction, weights a ton, etc. That said, also the Accelero S1 (rev2) with any quiet 120 mm fan will be an excellent choice, and probably cost a bit less as well.
  3. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    from what iv read the thing is mahoosive, and also doesnt cool your VRMs. so it keeps your gpu temps down but your VRM temps skyrocket.
  4. boiled_elephant
    14 Jul 2004
    I don't have a readout for my vRAM temps and I've never thought to check it. Is there an aftermarket cooler you'd recommend that would take care of both?
  5. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    I really need some decent cooling for my gtx275, it managed to get to 102* last night while i was playing with the torque3D demo!!
    My main issue is with bit struggling to find a good one from the lot they tested, im reluctant to try anything, full water cooling isnt an option atm, Is that Prolimatech actually any good?
  6. barndoor101
    25 Oct 2009
    if its for the 4870 try the akasa vortexx neo.
