Build Advice Proposed £650 Gaming (1080p) / Photoshop rig - Critique Please!
Discussion in 'Hardware' started by Mk1Slider, 15 Jan 2014.
  1. Mk1Slider
    Mk1Slider What's a Dremel?
    30 Jul 2009
    http://www.scan.co.uk/savedbasket/ae669a5f0a304d92910202e4724f311e
    So here it is, my first proposed build, made with information from both friends and the internet!
    I'm still new to all this, so please anyone who wants to advise me feel free!
    This will be for photo processing Photoshop work, and also gaming on an HDTV, I'm hoping to not have to upgrade any parts for about 3 years (except maybe adding in an SSD at some point).
    So, how does it look? (Be brutal, I can take it!)
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
  3. Xaine
    Xaine Death... destroyer of brain cells
    19 Sep 2012
    Its been a while since I went amd on processor so things may have changed but isnt it worth sticking a CPU cooler in their and going OEM on processor? The new h65 looks nice at a great price
    Last I remembered amd runs hot
  4. narwen
    narwen narwen
    6 Aug 2010
    I would change the GPU to a different make. Photoshop loves loads of ram.
  5. Xaine
    19 Sep 2012
    Amd gpus have more than normal nvidia, or are you thinking professional grade?
  6. Mk1Slider
    30 Jul 2009
    I didn't see an OEM CPU listed (I should have pointed out Im using Scan for everything for their finance option). Will that processor not be OK with the stock cooler as long as im not overclocking ?
  7. Mk1Slider
    30 Jul 2009
    Does the GPU make a big difference to Photoshop? I'll not be doing anything too intensive although there will be batch processing at times.
  8. Xaine
    19 Sep 2012
    Unsure tbh prob worth waiting for a second opinion, last one I had was amd athlon 3000+ and on stock heatsink with no oc it ran at nice temps really
  9. rollo
    rollo Modder
    16 May 2008
    If you did plan on overclocking or adding a second card the psu you have picked would be struggling for the record.
    Photoshop wants memory little else. 8gb would be the min I'd want 12-16gb if truly doing it a lot.
    Pro grade graphics cards Irelivent at this price point.
    Andy or harle both own the CPU in question or a version of it you could ask them how the stock cooler is.
  10. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Not trying to start an intel vs amd flame war here, but doesnt photoshop respond better to ipc rather than more cores?
  11. Mk1Slider
    30 Jul 2009
    I doubt very much that there'll be another card added at any point, but OCing might be something I'd look at in the future, but not at present.
  12. narwen
    narwen narwen
    6 Aug 2010
    Change from xfx to another make. xfx have a bad rep.
    I would add a SSD.
    Photoshop loves Ram.
  13. Mk1Slider
    30 Jul 2009
    I've been advised that at this price point AMD is a better bet from a gaming point of view. But would I be better with an i3? That's really all I could stretch to processor wise.
  14. Xaine
    19 Sep 2012
    Aah. Sorry bud got mixed up though you meant The GPUs ddr5 not ram. In the case of ram I would have to agree 8gb minimum for small stuff but I personally wouldn't go for less than 16. If it was for my job go full 32 as I'd have multiple projects open all the time ,
    If you can't afford the 4*4gb now no harm n waiting a bit
    I would advise upgrading the mobo . one thing buying a new PSU to accommodate second GPU but a mobo to usually just pushes for full revamp and adding a second card in a year or 2 will add some great value longevity.
  15. Mk1Slider
    30 Jul 2009
    Are there any Mobos in the sub £100 price bracket that you would recommend?
  16. Xaine
    19 Sep 2012
    http://www.scan.co.uk/products/asus...r3-sata-iii-6gb-s-raid-sata-pcie-20-(x16)-atx
    That seems fairly good, though I could be wrong but. these both say PCI e 2.0 can't be sure but the R9 280x may not work or at least not properly on that format, not too familiar with and chipsets etc ATM.
    EDIT: deleted Intel option as realised it has no crossfire supp. Either :-( need some more knowledgeable folk to answer that in bud
  17. mrbungle
    20 Sep 2004
    The Asus M5A99X EVO Rev 2.0 is a killer board.
    With FX stuff you really do benefit from a decent board.
    The Asus M5A97 Evo R2.0 is also very good.
    That said if you don't overclock a haswell i5 system is prob in reach. Would be a bit easier too cool too.
  18. Mk1Slider
    30 Jul 2009
    I could probably get an i5 4670k if I shaved some money off the GPU (say £200 limit rather than £250) and case. Is the trade off worth it from a gaming POV? Or is a better card and the AMD a more long term solution?
  19. mrbungle
    20 Sep 2004
    Like a few people, I have both and both play games just fine.
    Is a genuine bit of swings and roundabouts at the moment.
    I love messing with the FX system and in threaded apps/games it is a monster, but the big downer is heat and power. If you turn off all the power saving features they are very difficult to cool.
    On contrast you can overclock a i5 with your eyes closed with a £20 heatsink and budget motherboard.
  20. Mk1Slider
    30 Jul 2009
    See I would like to play about with OCing, even if its just to extend the systems life time, but I've no knowledge of it at all. In that sense the Intel would be the winner, but will a £200 GPU be able to last 3+ years?
    I realise that no system is ever future proof especially at my budget, but ideally I'd like to not have to upgrade anything (barring RAM and an SSD) for 3 years at least.
