Cooling Pros and cons of Corsair H50/H70 vs air coolers?
Discussion in 'Hardware' started by thelaw, 18 Oct 2010.
  1. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    How much space does the H50 or H70 need for tubing? Would 100mm from the mainboard be enough?
  2. DragunovHUN
    DragunovHUN Well-Known Member
    30 Oct 2008
    Eh? Tubing is flexible. But why would you put it above the motherboard?
  3. Jipa
    5 Feb 2004
    Way to understand and answer the question.
    H50:
    For me 100 mm is out of comfort zone. You CAN fit the thing in that space, but I'd try to avoid such tight bend. The block/pump assembly alone is 56 mm high (from base) so there's really not much time for the tubes.
    H70:
    The pump/block is just 28 mm tall and you could fit it with the hoses to a space of about 50 mm. Again a bit more if you want to avoid stress...
    Aterius Gmork likes this.
  4. DragunovHUN
    30 Oct 2008
    WTF man?:eyebrow:
  5. Aterius Gmork
    25 Sep 2007
    My question was: Can you put a H50 in a case with a clearance of 100mm between the mainboard and an obstacle like a PSU. However my English sucks. :(
    Thanks Jipa.
    So for the H50, how much space would I need to avoid kinking? 120mm? 130mm?
  6. Jipa
    5 Feb 2004
    There's nothing really preventing you from bending the hoses sharply, but having 130 mm instead of 100 would make a great difference (just about twice more space for hoses).
  7. Teelzebub
    27 Nov 2009
    I found the H70 will fit in a tighter space than the H50 because the pipes on the H70 will rotate some on the pump.
  8. SmilerAl
    SmilerAl Terminate with extreme prejudice
    6 May 2010
    This, I can't find nothing on failures with the coolers.
  9. Chicken76
    Chicken76 Active Member
    10 Nov 2009
    Could you post some links? I (and it seems I'm not the only one) can't find any.
  10. Teelzebub
    27 Nov 2009
    LOL your supposed to use thermal paste not nitroglycerin.
  11. zulu9812
    zulu9812 New Member
    21 Oct 2010
    I think a big plus for Corsair or CoolIT sealed water coolers is the silent running (once you swap out the stock fans).
  12. Pete J
    Pete J Employed scum
    28 Sep 2009
    I think you are referring to ones made by CoolIt - they have a pretty bad reputation IMHO.
    The Corsair H50/70 on the other hand? Good as gold.
  13. darkcutuan
    darkcutuan New Member
    2 Nov 2009
    I think tonshardware did an article on air coolers vs water coolers? Would normally source it but I'm on my iPod.
  14. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    My H70 is doing fine on a Q6600 at 3.5 GHz and it's way cooler than the Zalman CPNS10X could manage, even when OC'd even further.
    I would like to do a"proper" H20 install on my i5-665K next... she's currently at 4.495 Ghz...
    dunx
  15. okenobi
    okenobi New Member
    3 Nov 2009
    So how loud are these things compared to a low speed Fenrir or Tranquillo or similar?
  16. thelaw
    thelaw New Member
    10 Sep 2010
    Either that or he was refering to "coolers" in general and posted without actually any real knowledge or evidence.:lol:
  17. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Hi all,
    I am adding an H50 or H70 on my list to Father Christmas cos I have been a good boy this year ;)
    Based on my current set up an H50 is fine, future proofing as much as possible I'm not sure whether the H70 is worth a few quid more?
  18. bw67958
    bw67958 New Member
    13 Jun 2010
    I have the H50 and its fantastic, overclocked my 930 to 4 gig and load temps don't get above 45 degrees. I have the fan sucking air in rather than pushing out.
    I also originally had it in my lian-li PC60 case which is a bit small (had to mod side window).
  19. spicycoky
    spicycoky How is better than Why
    21 Nov 2010
    I agree with you..
    Noise can hide it with your sound of music.. :D
  20. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    LOLZ happens when you forget to change in your bios to set the pwm to always on max... (for the pump)
    RTFM!!!!!!!!!
    NOF said.
