Scratch Build – In Progress ProtoHype - (paused)
Discussion in 'Project Logs' started by The_Gnu, 13 Aug 2009.
  1. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    I' glad you found it to :) There will for shure be some serious milling when it's time to carve out the front. Got this huge piece of alu in my closet just waiting for me to bring it to the workshop :)
  2. Cheapskate
    13 May 2007
    :naughty:OOh, Yeah baby. Tell me more!
  3. The_Gnu
    12 Sep 2005
    Well, just a 7kg piece of 650x200x20mm alu that will be milled down in a heatsink pattern with some holes and slots :). It's next after the sanding is done.
  4. The_Gnu
    12 Sep 2005
    Well, been a while but heres another update of the work in process.
    Im starting to see the end of this top and bottom pieces that have been haunting me forever.
    The rough shaping is done and tha basic radius of the pieces are done. Whats left is the finishing wetsanding to get it all really smooth. Sanding down all those small steps I milled to the right radius took me roughly 10 hours all together. I started of with a file and when I got close to the shape I wanted I finished of with the "finger sander" as I call it. Not the biggest update of this log because all those hours of sanding don't produce a lot of good action shots.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    FINALLY all the lines are gone..
    (CLICK TO ZOOM)
    Still need to cut away the excess material on the sides but you get the idea.
    (CLICK TO ZOOM)
  5. Attila
    Attila still thinking....
    22 Feb 2008
    Haha, I know what you mean.:) Great work, but don't you have to make another of
    these for the front?
    By the way, I went back and had a quick look through the log again. The ring on top of
    the optical drive is particularly fine, indeed beautiful. ;)
  6. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    How did I miss this log?:jawdrop: Awesome design, and looks well on its way to fruition! Subbed
  7. The_Gnu
    12 Sep 2005
    Hehe I can see what you mean:thumb:. Regarding the front.. it will be made out of one single piece of alu and it will be flat with round edges and milled grooves. Therefore, no pain in the ass radius to carve out and hopefully I can use the mill one the whole piece. Theres just one problem. I think the front is too large for my rotarytable, and to make the round corners I think I will have to build some special rig using a normal hand router.
    Well my updates havn't been that regular so that's probably why :) Thanks for the comment and sub:thumb:
  8. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Really appreciate the detail picts! From the "finger sander" as you call it, to the last pict! And that last pict is the money. Shows the feathered edges with gaps at the end to the filled product in the middle. Damn fine work! X100! Multiple reps to you.
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Sure looked a lot of elbow grease to make the lines vanish & become smooth, awesome chunk of progress GNU :rock::jawdrop::thumb:.
  10. The_Gnu
    12 Sep 2005
    Thanks, glad you like the pics since I was not shure they were good enough.
    Yeah my hands were a bit sore afterwards. Thanks:thumb:
  11. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    looking good as always ! :thumb:
    must have been a hell of a job to sand everything down !
  12. The_Gnu
    12 Sep 2005
    thanks :) yep..I thought the machine would speed up the process alot but that wasn't the case, so there was some elbow grease needed for shure :S
  13. Cheapskate
    13 May 2007
    No radius on the face?:sigh:
    Give it a week. You will forget about how tough the filing was.:D
  14. The_Gnu
    12 Sep 2005
    Exactly.. from the side, the face of the case will have the same curvaceous profile as THIS persian cat.
    I had thoughts about making it the same curve as the top but desided to keep it flat since a curve would probably make it way more complex and harder to do by hand.
  15. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    don't forget me, Gnu ;_; - Quote from ProtoHype
  16. The_Gnu
    12 Sep 2005
    Haha don't worry. I'm actually redesigning a new backplate for this project right at the moment, and I'm also trying to figure out the design of the case foot. So it's still in progress just that there isn't any machining taking place and not much to show. But updates will come in a near future for shure.
  17. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    AARGGGH Skimlinks.
  18. The_Gnu
    12 Sep 2005
    what tha..I hate those. It seams like it dissapeared when I edited the post. Is there anything I can do to avoid them? Or how does these things work
  19. Dahl1n
    Dahl1n What's a Dremel?
    16 Jan 2010
    I dont wont to wait more time to see the bakplat :( i want to see it now m8 hehe good luck m8 and cant wait to see the result on it ;):) //Dahl1n
  20. The_Gnu
    12 Sep 2005
    haha easy now... I can see why you have this special interest in this backplate ;)
