Scratch Build – In Progress Proxima - Almost there! (28-12-2014)
Discussion in 'Project Logs' started by Razer2007, 13 Sep 2011.
  1. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Update #08 :: Reservoir is here and installed!
    14 January 2012
    Click image for facebook page
    Custom reservoir, designed by me, made by E22 (Editor22 on the forum). You have been teased a bit with this res, and now here it is. It's made specifically for this case, and would look stupid in any other case imho.
    E22 made the res out of a solid block of clear plexi and some 10mm sheet. The front lid is milled with a 3mm lip on the sides so that the "window" sits flush with the panel it's mounted on. E22 also made the custom 0-ring from white cord to fit with the watercooling tubes I'll be using.
    Thank you very much E22 for this wonderful product. It came out perfect!
    Waynio likes this.
  2. bugeye
    bugeye Sleep Deprived
    16 Aug 2011
    Very very cool :hip: really like that it's built in and not bolted on :)
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    I like it m8!
  4. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Beautiful. Can't wait to see it finished.
  5. Razer2007
    18 Jul 2010
    Well, it is bolted on but also part of the case, if that's what you mean. Thanks!
    :thumb:
    I love the reservoir!
  6. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    That is one sexy reservoir! Nice work guys.
  7. Waynio
    Waynio Relaxing
    20 Aug 2009
    The res is awesome & really looks right at home there Razer :) nice colaberation with Nate :clap: this is shaping up to be a heck of a beauty :thumb:. rep
  8. Razer2007
    18 Jul 2010
    Thanks you two! The res really makes a big difference!
  9. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    lyk maar goed ou pal.
  10. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    This mod will look really awesome when its done!!! Mod on bro ! :)
  11. KidMod-Southpaw
    28 Sep 2010
    That's a beautiful res, fists the case wonderfully, but that's what it's meant to do! :lol:
    Looks great.
  12. Razer2007
    18 Jul 2010
    MAAR goed? Hehe jk. Baie dankie
    It most certainly will! Thank yo.
    Hehe yeah. Thanks man.
  13. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    The reservior looks great now that it's in place Danelle! been a really fun process going from the initial concept design to this finished piece, have fun with it :)
  14. Sarakon
    Sarakon The German
    11 Feb 2011
    Awesome res and super snug fit :D cant wait for more
  15. Razer2007
    18 Jul 2010
    Howdy :D It was quite a journey and I think it turned out perfect, just as I designed it :)
    Hope are patient :( Matric is starting so that means work work work
  16. Sarakon
    Sarakon The German
    11 Feb 2011
    No worries, good luck with that btw...Have you started the school year yet? Cause they like to slap you with projects right on the first day :p But matric is ok if you payed attention in classes...
  17. Razer2007
    18 Jul 2010
    We actually started working on Friday, but we go a set test and project table each term. I know I'll do well in matric, the challenge is just to get 6 distinctions, then I can get a car.
  18. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    fits in nicely, well done :thumb:
  19. Sarakon
    Sarakon The German
    11 Feb 2011
    A challenge indeed...You should convince them that you can get a car if you get nominated for MOTY :D
    Razer2007 likes this.
  20. Razer2007
    18 Jul 2010
    :thumb:
    You...are...a..GeNiUs!! +rep!
