PROYECTO RIN AHUMADO (Smokey Rim) Here I will present/display the product to them of the recycling in this one case the raw material concentrates in autopartes used since all the material used in this modding is waste. The construction of this Modding is to be able to take advantage of the rejected pieces a car to be able to mix them with the recoverable technology of a PC. Author: NEO360 Name of the Moddin: SMOKY RHINE PROJECT. Definition: The smoking is a cooking technique that consists of putting under foods originating realised fire smoke wood of little resin level. This process, besides giving flavors smoky serves like conservative extending the life as foods. Thus it is indeed the painting that the Rhine decorates is a smoking with a white bottom I hope is of its total affability. TECHNICAL CARD: The used parts are the following: Rhine Honda Civic model 98 this was “Is the Rhine of an Honda Civic that I injure in kilometer 33 course to Pinotepa Naciona Oax. Tornilleria: EXPLORER model 92 “This light truck was hit in the Zacatepec section the Level ones highway Putla Pinotepa Oax.” Handle: Honda Civic Hose chisgueteras of a 2000 DODGE ESTRATUS Motherboard Support mini cabinet HP model 4531 Bir them Ford Ranger 94 - 96 Transparent micas: Covers of box of CD. Reconstructed parts: Motherboard: Mark MSI Model K9N6PGM2 (repaired Failure electronic) Hard disk: Maxtor mark (repaired Failure electronic) Source of Power: 350 Watts. (Capasitor Failure) New materials: ¼ White painting (Automotiva) 1L. Thiner ¼ of Universal Praimaer. 4 Pijas 11/2” Memoria Ram 1Gb. Procesador AMD 3200 + Sempron Times of construction: A month with fifteen days altogether. Technical details of Yield: Vibration: 0 Null Temperature: within the case 22º c. Noise: Null Weight: 9 kg. Process Pieces to use Note: The Rhine presents/displays a one double product of the ideal shock for the base. Ayudante y piezas Medir placa que soportara la Motherboard, para poder hacer los barrenos tanto de placa como de salidas de cables etc. Important to mention that each large drill was created in a time of a day since aliacion of the Rhine is very dense. Design of ignition lights. Design of ports usb. Wiring of LED and ports usb But that said aki the finished work finishes to all pos I do not present/display aki it: Already mounted everything and seeing the yield beginning the painting process. In front of the PC Opposite side With Light Flanks Finished Finished of being able Source Terminado de manija de carro Terminado para conecciones Finished bir them logo and ports Terminado Puertos USB Finished Lights At night
Cool idea, but I wish you'd have use a bigger wheel and better speced components. Also wished it was all black.
