Displays PS4 on Dell U2412m?
Discussion in 'Hardware' started by chewbaccas_nan, 29 Dec 2014.
  1. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
    Hi all, haven't posted in a while.
    I was thinking about buying a ps4 and hooking it up to my Dell u2412m, would this be a bad idea? If it's 1200p would the play station upscale to fit the screen? What about input lag etc?
    Cheers.
  2. TheMadDutchDude
    23 Aug 2013
    Doing a quick Google search; it may either stretch the image which would make it seem a bit distorted, or the monitor may put it in a letterbox format which means you'll have black edges in order to maintain a 1080P aspect ratio. There's only one real way to find out. Plug it in and let us know! :D
    Input lag? It'll be the same as if you were gaming from your PC.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The U2412m does not have a 'preserve-aspect' or '1:1 mapping' menu option, so you will have a stretched image when feeding it 1920x1080. The PS3 cannot output 1920x1200, so unfortunately there is no solution.
  4. chewbaccas_nan
    27 Jun 2011
    So, if it does stretch/upscale the image, do you think it will be noticeable?
  5. GeorgeStorm
    16 Dec 2008
    To some people yes to others probably not, only way to know for yourself is to try it and see :)
  6. jinq-sea
    15 Oct 2012
    Having done this with the 360 some years ago, I noticed that circles weren't circular, but were oval-shaped. It's not that bad, though!
  7. chewbaccas_nan
    27 Jun 2011
    I'll have to try it out and get back to you!
  8. RedFlames
    23 Apr 2009
    Based on using my 360 with a 2412M [over VGA] and running games at 1080p -
    1080p stretches to fit so you end up with slight distortion rather than letterboxing... personally i'd rather have the letterboxing but as jinq-sea points out, after a while you'll probably not notice...
