Modding PSONE LCD info and sites
Discussion in 'Modding' started by bee2643, 22 Feb 2004.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    I know a lot of people have been requesting wiring info on the psone lately, and i can't seem to find links to any site that works and goes through this
    I've aquired a Sony PSONE LCD off eBAY and am looking for a guide or something to wire it up to composite or svideo.
    if anyone knows of any working sites and has pics of everything including the power and voltage, please post them here, i know about a half dozen people on this forum would like the info too :)
    some things people need:
    -circuit board dimensions (behind LCD)
    -wiring diagram
    -quality?
    -tips on wiring
  2. fuzzygoblin
    fuzzygoblin What's a Dremel?
    19 Oct 2003
    i also would find this slighty interesting
    bee2643 likes this.
  3. Morphine
    Morphine weeee!
    23 Feb 2002
    if its a tru sony brand screen, which it appears to be. Then you can actually wire it up to VGA. search the mp3car.com forums for this, its been discussed there a bunch.
  4. bee2643
    7 Mar 2002
    its a composite one
    anyone have anything on wiring it up to composite?
    **and 90% of the links on mp3car forums are broken
  5. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    compsite dont matter, you can mod it to hook up to vga
  6. Morphine
    Morphine weeee!
    23 Feb 2002
    I'll look up the instructions for the mod for ya.
  7. bee2643
    7 Mar 2002
    thank you -very- much, heh
    ive got this psone lcd sittin here ready to go but no knowledge of how to wire it to composite
  8. Disgone
    Disgone What's a Dremel?
    23 Feb 2004
  9. BringItDown
    BringItDown What's a Dremel?
    12 Jun 2003
  10. Disgone
    23 Feb 2004
  11. Morphine
    Morphine weeee!
    23 Feb 2002
    I was hhunting around MPro's guide. It is probably the best one out there.
  12. bee2643
    7 Mar 2002
    disgone: that first link is using PAL and im in north america so itll be NTSC, not sure if you can even schange that in settings...
    mpros guide is a diff make/model so im not sure if its even the same
    and still, none of those links tell me how to use it with composite (RCA if your not sure what composite is)
  13. BringItDown
    12 Jun 2003
    Mpro's guide isnt for the sony brand lcd though :sigh:
  14. WILD9
    WILD9 Been here aaaaages
    13 Sep 2001
    you could use the wireing guide from serio and the powerstrip setup from mpro then, they are interchangeable, the only difference between the ntsc and pal screens is how it interprets the video signal, the wireing is afaik identical
  15. bee2643
    7 Mar 2002
    which guide is his? and is it composite?
  16. bee2643
    7 Mar 2002
    nm i found his 'site' and its down, like 80% of the ather psone sites :waah:
  17. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    :sigh: Typical Sony... locking out people from knowing the "guts" of the products...
  18. SWFREE
    SWFREE What's a Dremel?
    11 Mar 2004
    I NEED MPROS WIRING GUIDE FOR THIS THRUSTMASTER TFT!!! AAARRHH ITS DRIVIN ME NUTS!!! NOBODY ELSE GOT THIS GUIDE!!! PLEASE!!!
    uhm..yeah , can anyone please support me with the infos on modding the trustmaster 5" tft display for direct rgb input? i would be very glad about a link to a similar guide for the thrustmaster tft.. the original sony psone does not help me much.. thx
  19. bee2643
    7 Mar 2002
    thats one of the reasons i made mine lol
    those sites are down 90% of the time :s
  20. SWFREE
    11 Mar 2004
    you made a tutorial especialy for the thrustmaster tft? its so complete different to the original sony one :-/
