Modding PSONE LCD installed and operational!
Discussion in 'Modding' started by bee2643, 26 Feb 2004.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    the problem with your main monitor turning off when you enable csyn id because your editing the settings of that monitor, not your lcd, read my timing section to see how to bring up the right monitor.
    ^^that will fix half your problems.
  2. BladeRelic
    BladeRelic What's a Dremel?
    17 Sep 2002
    yep, he was having the same problems i was having. i also have a feeling this version of powerstip is a li'l buggy. but maybe thats just me :wallbash:
  3. skotbytes
    skotbytes What's a Dremel?
    10 Jan 2004
    Managed to get mine working through composite after a bit of messing with my tv-out settings.
    Have since put the lcd in a modified dvd case, until I get my new pc case to put it into. It's quite good for distracting my son with a movie on the lcd whilst I surf the net on my main monitor.
    I'm not using powerstrip. Would it make any difference?
    Scott
  4. bee2643
    7 Mar 2002
    jees what program is running on it for the system info?
    you should post some information im sure lots of people want to know about it
  5. Lightside
    Lightside What's a Dremel?
    28 Mar 2004
    You can buy NTSC screens on ebay.co.uk for 25quid, Does it make any difference compared to PAL?
  6. bee2643
    7 Mar 2002
    PAL is the european timing standard
    NTSC is the north american timing standard
    PAL displays wont work in north america and vice versa from my understandings.
  7. daz_uk30
    daz_uk30 What's a Dremel?
    5 Jun 2003
    i think that might be a program called samurize he's using for the system info
  8. daz_uk30
    5 Jun 2003
  9. Dash
    Dash What's a Dremel?
    24 Sep 2002
    For any one with a 5" lcd Coollman works geat for system info
    so many things you can do with it
  10. bee2643
    7 Mar 2002
    very nice
    care to post the config?
  11. TheMightySpud
    TheMightySpud Boy Genius
    18 Feb 2004
    Okay, main problem is.......
    I'm not changing the CSync setting on my primary monitor, I'm changing it on the correct monitor (The PSOne LCD), but it just doesn't like me doing it..........My primary monitor blinks out as I said before.
    TheMightySpud
  12. skotbytes
    10 Jan 2004
    yup it's samurize and it can do all sorts. LINKY
    Now I need to think about my plans again as someone has kindly donated me a slightly smaller screen, so I may use one in my pc case with similar info on to the pic I posted and the other for an in car pc project.
    Scott
  13. Lightside
    28 Mar 2004
    Yeah, i know. I was wondering if it makes any difference. Since there is no PAL/NTSC distinction for PC's, but there is for the psone LCD.
  14. WILD9
    WILD9 Been here aaaaages
    13 Sep 2001
    Well im fed up of the crap quality in composite so i think im going to try and sort vga out again. The holy grail of finding a way to force detection of this as a second monitor on an ati card without hot swapping looks like its never going to be found so i guess il have to buy a pci video card to run it off of, what card did you say you used bee? The other thing is my card already supports dual monitors , will adding a pci card to this throw it all off whack or will i just have support for 3 monitors?
  15. kevplus2
    kevplus2 What's a Dremel?
    23 Mar 2004
    good info can be found here for those of you using this as a 2nd monitor if you are new to the multi mon stuff.
    multi monitor forum
    some highpoints to answer your question wild...
    1. dual outputs on one card and adding a pci card will work fine. here is my system with a g4 4400ti and a g2 mx200 ( :rock: )
    2. the basic rule seems to be that you must use 2 cards with the same manufacturers chipset (ati/ati or nvidia/nvidia). a few have been able to deviate from this, but not many. the voodoo cards seems to be pretty tolerable with nvidia cards.
    3. in bios, you have to make the pci card primary. then in windows make monitor connected to agp primary.
    4. if using an onboard chip and an pci cad, you cant use the uppermost pci slot for the card. dont rememeber exactly why, has something to do with onboard video addressing and sharing the same addy as the pci slot or something
    i am thinking of adding a psone lcd. you can never have too much real estate and i am getting tired of my 2X16 crystal fontz lcd. good luck with the multi mon
  16. WILD9
    13 Sep 2001
    hmm, that might be awkward, ati cards didnt have ccync untill quite recently afaik i was hoping to be able to use something like a matrox millenium with my radeon 9600pro
  17. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    I think that matrox is pretty tolerant also, I have a 9700pro, and an old as hell pci matrox card. It could be that its old as hell, or it could be thats its matrox, idk, never really mattered that much.
    How much did all those screens cost you?
  18. kevplus2
    23 Mar 2004
    the center 19" viewable sony was the only really pricey one and i got it though a deal due to overstock. the flatpanels are microtek 15" viewables so they were relatyively cheap (in comparison to nice flat panels). they work great for most stuff, but i wouldnt want to game on one. all told probably a grand (but i definitely didnt buy them all at once)
  19. bee2643
    7 Mar 2002
    update
    im still surprised by the quality of the vga, so i too ka billion more pics but only one turned out, its hard because the surface is reflectable so a flash reflects, and no flash makes for a blurry image, so i could only take a pic at an angle so its sharp but dark because the flash isnt hitting it 100%
    hope you guys think its alright
    thats the Quiet Riot - Bang Your Head music video btw...very awesome :naughty:
  20. TheMightySpud
    18 Feb 2004
    Okay, Samurize......
    Where do I download it?
    I've been to the site, but all there is there is news, and no working pics.....
    What's the deal ?
    TheMightySpud
