Modding PSONE LCD Mod
Discussion in 'Article Discussion' started by macroman, 6 Jul 2004.
  1. dom_
    dom_ --->
    4 Jan 2004
    omg why is this thread still going!
  2. elmodder
    elmodder What's a Dremel?
    13 Mar 2005
    whats wron about it ?
    many new people find the mod and want to do it, and new questions apear
    then new guides apear too, and new problems :p
  3. Pelihirmu
    Pelihirmu What's a Dremel?
    2 Jan 2005
    Help!
    I bought PSone lcd, but now I don't know what to do next :blah:
    This model isn't the same as all the other and haven't found any guides how to mod this kind of PSone lcd. So I thougth someone could help me :)
    Here's some pics for you:
    Is this the same as this
    [​IMG][​IMG]
  4. Nexxo
    23 Oct 2001
    The 9800Pro still has a hardware dip-switch on the PCB to switch between NTSC and PAL (per default it is set to NTSC). However I find that with the ATi Catalyst drivers you can simply switch between NTSC and PAL from the desktop, regardless of the position of this switch. So yes, PAL screens will work perfectly fine on a US Radeon 9800.
  5. dastt
    dastt What's a Dremel?
    23 Apr 2004
    can someone lemme know what the specs on the power adapter for a official ps1 screen? i bought a wall adapter that goes to 7.5v(which i know i need) but only has 300mA of power. is this enough to run the screen? when i turn it on it flashes on for a second then goes blank, even when i have the screen plugged into my ps2 to test it.
  6. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I'm doing this mod right now and I am at the stage where I need to connect this thing to a VGA cable. I have got hold of an old cable with all the pins, but some of the wires are missing so its useless. Would it be possible to actually solder the wires from the LCD to one end of a double male ended vga cable?
  7. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    7.5v 3000mA (3 amps). Classic brown out symptoms there, get a real one and it'll work fine.
  8. ElThomsono
    18 Mar 2005
    Yes it would :D
    That's how I did mine, no parts of the PS cable, just leads straight from the screen to the graphics card (hardwired onto the back, but a VGA connecter would work just as well.)
  9. MrWillyWonka
    25 Jul 2004
    Theres another question, how long have the colours of the wires inside the VGA cable been standard for? Because in the cable I cut up, the wire colours were completely different to the ones specified in the guide.
    What if I can't find a cable with the DCC pin? Is the DCC completely necessary for PAL screens?
  10. ElThomsono
    18 Mar 2005
    Find the wiring out using a voltmeter, it's the only way to be sure. The DCC pin is neccecary to activate the screen, but can be taken directly off of the PCB itself. You just need to figure out which wire it goes to and then solder it onto the board.
    Shown is my screen with the DCC pin directly on the PCB.
  11. MrWillyWonka
    25 Jul 2004
    I have the same LCD as you, so which wire did you solder onto the PCB?
  12. ElThomsono
    18 Mar 2005
    Looking at the picture, there are two connectors to the screen. It is the wire on the very left of the right connector, roughly here:
  13. MrWillyWonka
    25 Jul 2004
    And that is connected directly to the PCB?
    Thanks! And sorry for the so many questions, I don't want to make a mistake and fry the thing or something!
    Now I'm just waiting for my car adaptor to arrive on monday...
  14. elmodder
    13 Mar 2005
    if im not mistaken, you need 1 o 2 A for the backlight to switch (and stay .p) on.
    the one that 3a 7,5v is for powering the lcd + ps one console.
  15. truewarlord
    truewarlord What's a Dremel?
    7 Aug 2005
  16. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
  17. pman09012
    pman09012 What's a Dremel?
    27 Oct 2004
    I've looked in the forums, and searched online, but i cant find a touchscreen that i can add to my psone screen to make it more useful, can anyone help
  18. sui_winbolo
    25 Sep 2004
    Probably not, I've only seen touch screen covers that range from 15-21" monitors. I think the only thing you'll find is a small lcd with built in touch screen.
  19. MrWillyWonka
    25 Jul 2004
    I don't know, but you could try a touchsreen from a PDA?
  20. pman09012
    27 Oct 2004
    damn, i was hoping it would be a little easier to get this thing working, thanks for the help so far guys
Tags: Add Tags
