Modding PSONE LCD Mod
Discussion in 'Article Discussion' started by macroman, 6 Jul 2004.
  1. gstlouis
    gstlouis What's a Dremel?
    23 Jun 2005
    You will need 3 if you are going that route. Just to let you know, you will have to do some modding to get it to fit. A better option would be to find a case that has either a door, or a large open area that you can cut into
  2. smithm5
    smithm5 What's a Dremel?
    2 Mar 2005
    need help with NTSC settings on a radeon 7000. if you have the lcd working on this card....PLEASE post pics of the settings....
  3. gstlouis
    23 Jun 2005
    I've got the card, I'll post when I get back to my computer. You shouldn't need to manually put in the settings. As long as you've wired the thing right, when you go into power strip and load the 640x480i (arcade) settings, it should work alright.
  4. Nexxo
    23 Oct 2001
    That shouldn't happen. I've been playing a range of games (Eve Online, UT 2003, Darwinia, Quake (memories...), Startopia, whatever) and Samurize is unperturbed by it. What error are you getting?
    The PS1 should be set at a default 60Hz.
  5. smithm5
    2 Mar 2005
    i made a thread about the radeon settings....search for my thread...has pics...
    here are some pics of my install.....
    some things i learned:
    extend the screen to the LEFT of you main moniter regaurdless, and it wont change resolution or anyhting if you launch a game that changes resolutiuon of main monitor....
    powerstrip will take forever to setup....
    problems im still having :
    if the screen saver starts, when i come back it shifts the image on the LCD about half an inch up, and cant figure out why....
    whenever i boot i have to tweak powerstrip settings to get screen to be centered...if i increase one setting screen starts scrolling vertically, and then i have to click at the exact right time to make it stop in the center... (help?)
    mike
  6. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
    Alrighty, getting a little ticked off since I still have yet to figure out how to use this screen.
    Nexxo: How is your PSOne LCD and Dell LCD connected? I'm assuming Dell-DVI and PSOne-VGA. If so, how is it detecting the PSOne screen? Or do you have to do a swap each time?
    I've seen the dummy VGA mods, but that doesnt work when I dont want to have to do a swap. I want to turn it on and have Windows find a) my Dell 2005FPW DVI and b) some unknown monitor on the VGA (just detect it!)
  7. yatesy
    yatesy What's a Dremel?
    10 May 2005
    HI
    I am interested in doing this mod, but need to know- how many 5 1/2" bays does it take up, if mounted in those bays??
    Many Thanks
    Yatesy
  8. gstlouis
    23 Jun 2005
    It will take up about 2.5 bays. You will have to do some plastic work as well to fill in the gaps.
  9. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    It depends. The screen itselft fits exactly in two bays, if you include the frame it will fit in 3 bays. But if you leave the circuit board at the back of the screen it will take up 4 bays, only just though. You have the option of extending the LCD ribbon to the board, to move the circuit board elsewhere.
  10. chronic9
    chronic9 What's a Dremel?
    22 Aug 2005
    where can i get a cable to hook up the screen to my PC via S-video? can someone link me to a online store or a retail outlet? thnx
  11. Nexxo
    23 Oct 2001
    I understand your frustration... However my 5" TFT (a "generic" screen, not a PS1 LCD) is connected by S-video. I may not get quite as sharp a picture (although tweaking the little pots on the back of the screen helps), but my PC recognises it on boot-up without any hassle and it doesn't act weird.
    Pictures of the current setup below:
    Sharp enough for me. :cooldude:
  12. chronic9
    22 Aug 2005
    where did u get ur s-video cable for this screen? did you buy the 3.5mm to RCA converter somewhere?
  13. user0001
    8 Sep 2004
    Pots! :jawdrop: Actually, I was thinking about leaving the RCA/SVideo open for something else. Would use a PCI card, but with 2 slots on the DFI board, doesnt seem like a good idea (may run dual soundcards down the road unless X-Fi delivers). Also thought about using a USB video card, but am not sure if its always on. Bit pricey as well
  14. Nexxo
    23 Oct 2001
    Actually the required cable (with tulip plugs) and a din socket to tulip plug converter thingy came with the graphics card. But I'm sure the local video hardware/electronics shop can help you further.
  15. user0001
    8 Sep 2004
    Eh, I ended up buying an x300 PCI-Express card today for $23. Has VGA and S-Video. So I definately can hook it up now. Just have to wait for it to get here...
  16. canucker
    canucker What's a Dremel?
    9 Sep 2005
    hello all.i am new to this forum.i joined specifically for all the info on the psone mods here.WOW,that was a lot of reading.i have`nt hacked up the psone yet.i have it hooked up using the s-vid connector.i have tried everything i can think of to get the screen activated in windows.everytime i try to set it within windows display properties-extend this monitor to desktop and hit apply it just goes back to being unchecked.the screen does power up properly etc.i did buy the screen used,and they said it has a 90 day warranty.
    would it be safe to test the display
    if i hooked the screen up to something with a s-video connector,like a vcr or something,to see if i can actually get a picture on the screen
    no sense me tearing this thing apart if i cant get it working within xp.
    thank you for any info in regards to this
  17. invalid
    invalid What's a Dremel?
    23 Jan 2005
    Quick question and I am sure its dumb.
    My video card has dual dvi and thats it. Will the vga mod for the ps1 work with this video card if I use a normal vga to dvi extension?
    Thanks for answering anyone. :)
    EDIT: Found the same question on page 1! :duh:
  18. invalid
    23 Jan 2005
    Hey guys quick question. I am doing the vga mod and I ran into something.
    I cut open my vga cable and am going to use a toner to figure out what pin is what wire. But the one thing I need help on is that 3 of the wires have another wire inside of it. What are these? Are they the ground? If I end up toning and figuring out that one of these is the wires I need, what do I solder the outside wires, or the inside one?
    Thanks for any help.
    PICTURE:
  19. chemo
    chemo True Jungle Brother
    20 Feb 2005
    im pretty sure you will need the inside wires, and the outside stuff is the earth for each one.
    but wait til someone can confirm before going on my word
  20. gstlouis
    23 Jun 2005
    Yes, each of those wires is the R,G, and B wires. The inside wires are the actual signal, and the outside wire is the ground.
Tags: Add Tags
