Modding PSONE LCD Mod
Discussion in 'Article Discussion' started by macroman, 6 Jul 2004.
  1. Veer
    Veer What's a Dremel?
    3 Dec 2004
    thanks for the screenie. There is no such option with my ati 9600, for some reason. Apparently there seems to something like that with ati catalyst. However I just still can't get it to work for some reason. :sigh: Even though everything is connected properly.
  2. Brunosso
    Brunosso What's a Dremel?
    26 Aug 2005
    thers's a difference between the NTSC & PAL screen?...NTSC is only interlaced, and PAL screen is intelaced & C-Sync...help me!
    is right that the NTSC accept only 640x480
    and PAL accept only 720x576???? :confused: :confused: :confused:
  3. Brunosso
    26 Aug 2005
    you have pvt!
  4. Krypto
    Krypto What's a Dremel?
    29 Oct 2005
    I need some help. My vga cable that I bought has different color wires than the one in the how-to. I have red, blue, green, brown, white, black, and orange. Red, blue, and green are bigger then the other 4. With just the red, blue, and green soldered to where the color code says I get a constant flurry of downward flashes on the lcd screen. Can someone tell me where I am suppose to solder the black, white, orange, and brown wires? Thanks!
  5. effbee
    effbee What's a Dremel?
    15 Jan 2005
    You also need a ground for the RGB wires. You'll have to break out the multi-meter and find which pins are grounds and what color wire they go to.
  6. nukm69
    nukm69 What's a Dremel?
    2 Nov 2005
    my lcd mod
    hey all, this is my first case mod ive ever done.
    after using this and other sites i decided to make my own lcd mod
    check out my site for full pictures and what.
    http://aarons_webpage.tripod.com/lcd/1.html
    i went with a s-video -> rca -> 3.5mm jack
    my card is retail ati 9600xt 128mb
    took about 20-30 hours i think. but lots of fun
    let me know what you think
    i didnt need to use power strip, the new catalyst software took care of everything
  7. enterprise
    enterprise What's a Dremel?
    8 Oct 2005
    great stuff man, looks good but i have 1 question, can u please tell me where you connected the switch to? photos are good but if its too much hassle, can u just tell me where abouts cuz i can't figure it out by myself . . . :D thanks in advance and once again, great stuff!
  8. nukm69
    2 Nov 2005
  9. enterprise
    8 Oct 2005
    sweet, thanks . . . man u reply fast!
  10. tombo
    tombo What's a Dremel?
    5 Nov 2005
    I have a question on how to use the two connectors on the main psb for S-video without having the little pcb and power connector dangling off of it.
    Does anyone know the id of each wire on the 12 pin connector? I could not find a circuit diagram with this information.
    Here is a pic of the main pcb connectors, both have a red rectangle around them:
    The white plugs at the bottom of the main pcb, just below the lcd.
    My goal is to connect a S-video cable and 7.5v power source to it, getting rid of the mini pcb, powerplug, and possible the right ribbon connector all together.
  11. enterprise
    8 Oct 2005
    man those pics are still on your comp, you need to upload them up to a server so we can view em, imageshack is a good start
  12. xmas111
    xmas111 What's a Dremel?
    27 Sep 2005
    I guess if any of you want a easy way to get a 4" LCD working this might be the way.
    I haven't seen it in use so I can't say how good the pic is.
    Easy hook up
  13. enterprise
    8 Oct 2005
    that screen looks nice but look at the price, the psone lcd mod cost me a ltlle over $15 in total, big differnce there
  14. Brunosso
    26 Aug 2005
    what's the timings for a MAtrox G200 AGP?...please i don't find it in this forum!
  15. Jellyman_4eva
    Jellyman_4eva What's a Dremel?
    13 Oct 2005
    Stupid question maybe?!
    Hi all,
    I too am really interested in this mod, and have done the S-Video to RCA to 3.5mm jack method to get it up and running. It works fairly well in my opinion, however I would like to have a bit better quality, and as such go the VGA way...
    So I got a 15 pin vga cable (Which has pin 9 as I am in UK using a PAL Sony LCD) and I cut off one end. All good so far... now however there are several thicker wires, three of which have their own shielding and are red green and blue in colour, so I assume thats what they are!
    But for the other wires, and essentially pin 9, how do I test the pins to find out which is which?! I know it involves a multimeter but how do you apply voltage to it etc?!
    This is really simple to some people just not me!!
    Thanks
  16. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Set your voltmeter to continuity, it should beep when the two probes touch. If your multimeter doesn't have this setting, set it to resistance and when there's no contact it'll skyrocket, when a contact is made it'll go down to a few mΩ.
    Using either method, touch one probe to a pin on the socket, and using the other go round the exposed wires until you get a hit, labeling them as you go.
    Most monitor cables don't carry pin 9 any more, so if it's missing you have to find an alternative source of 5v to switch the screen on. There's a few posts about this (with pictures :) ) back in the thread (~page 19 I think).
  17. Jellyman_4eva
    13 Oct 2005
    problems!
    Hi,
    I found the right wires and attempted the solder... my god is it hard...
    Has anyone got a good method of actually getting it right...
    I ended up with a huge blob of solder which went across multiple pins... solder sucker got rid of it though so I am back to square one!!
    How do people do this?!
    Is there anywhere in the UK where I could even send it to get it done?!
  18. koola
    koola Minimodder
    11 Jul 2004
    This is easy:
    1) make sure you have some solder on your tip.
    2) Put the wire onto the solder area (use something heavy to pin the wire down)
    3) Place the soldering iron tip on the wire/pcb and quickly tap with your soldering wire until it melts.
    4) Gentally pull the soldering iron tip off the wire/pcb.
    If all goes acording to plan, you should end up with a nice neat connection :D
  19. Mugen
    Mugen What's a Dremel?
    17 Nov 2005
    Hello all, im from spain and this is my first post :blush: ,i read the entire thread (my eyes are broken :eeek: ), some days ago i bought a lcd screen, i did the mod and my x850xt pe vivo didnt reconized the lcd. After reading the entire thread, the only solution for playing something on the lcd are: 1) Buying a pci radeon 7000, 2) plug the lcd into the s-video, 3) throw the lcd trought the window?? I will very pleased to who answer me. Thanks a lot and best regards from spain.
  20. The_Dude2040
    The_Dude2040 What's a Dremel?
    25 Nov 2005
    Ah finaly i can ask my question,
    ok 1st hello, i'm new i've been trying for 2 days to sort out my old account so i gave up and made a new one. so hello!
    ok here's my problem. my screen is hooked up to a d-sub on and AGP 5200, it turns on but it flickers like mad and the screen is split....don't really know how to put it. insted of the edges being at the edge their in the middle. so i get left hand side on the right and the right hand side on the left with a big black line down the middle. i've chacked the wireing a few times but to no avail. i know the screen works. unless i busted it when i opened it. i don't know what to do. also it's a pal screen (U.K.) so i don't know if that makes a diffrence??
    any idea what to do.
Tags: Add Tags
